seat riser question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > seat riser question
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFS: Wranger BRIGHT License Plate LED! Just $3! Great valueRough Country Lift Kits and Parts!
Unread 03-24-2012, 07:28 AM   #1
Trendsetter75
Trendsetter75's Avatar
2010 JK Wrangler
seat riser question
I want to do the (2) hockey puck seat risers just wondering what size screws Im going to need and do I need washers as well?
2010 JKU (6-spd)
Trendsetter75 is offline   Reply With Quote
Unread 03-24-2012, 07:45 AM   #2
athos76
3 x 8mm 1.25mm pitch 70mm long bolts (65mm will also work) Grade 10.9
1 x 7/16-20 X 2-3/4" (2-1/2" will work also) Grade 8
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline   Reply With Quote
Unread 03-24-2012, 07:49 AM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
I'd rethink that.You can order PA 1" BL blocks for 99 cents each.
http://www.jeepforum.com/forum/f9/gr...ebate-1074733/
When I had 3.07s I would draft behind birds as an attempt to do the speed limit.
Originally Posted by Jeepsr4me View Post
Yeap its your nuts that giving you the trouble here...... Get the right ones
TheBoogieman is offline   Reply With Quote
Unread 03-24-2012, 09:25 AM   #4
armyRN
armyRN's Avatar
I went with the Rough Country 1.25" seat riser kit; it was like $35.00 or so to do both passenger and driver's side. Came with new hardware.
I was getting leg cramps driving long distances (I'm tall) with the Jeep, and I was considering dropping some serious money on Corbeau aftermarket seats, but thought I'd try this first. It did the trick - no more leg cramps. I drove the Jeep to Moab last year (2200 miles round trip) with no leg cramps.
armyRN is offline   Reply With Quote
Unread 03-24-2012, 09:52 AM   #5
2004sahara
Love my RC seat riser kit.....but it was missing 2 spacers out of the box. I only lifted the drivers seat. My mrs picked up the kit as a gift, I am not sure where the other 2 spacers went...but I can make a good guess!!
2004 sahara, 2 inch BDS spring lift, BDS discos, 31bfg at, on ravines.
2004sahara is offline   Reply With Quote
Unread 03-24-2012, 10:01 AM   #6
biffgnar
biffgnar's Avatar
I went with the Buchanan aluminum ones. A bit more than using BL pucks. Generically very happy though with seat higher.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote
Unread 03-24-2012, 08:02 PM   #7
Trendsetter75
2010 JK Wrangler
Decided im going with RC 1.25 seat risers it comes with everything I need.
2010 JKU (6-spd)
Unread 03-24-2012, 11:03 PM   #8
aparke4
aparke4's Avatar
I have the RC kit... simple install. really feels better being able to see over the front of jeep... after a week of driving your body adjusts (shifting and seat edge under knees felt weird at first when shifting)...
aparke4 is offline   Reply With Quote
Unread 03-24-2012, 11:18 PM   #9
TJRHD
I need to see one of these in person. I cant figure out why anyone would need seat risers. I am not far from the roll cage as it is.
NOT A HATER
TJRHD is offline   Reply With Quote
Unread 03-25-2012, 07:44 AM   #10
TheBoogieman
Demonic Jeep Freak!
You have short legs and a long torso. They lowered the seats in 03'.
* Seat Changes:
o Additional 20 millimeters of rearward travel
o Taller seat backs
o Softer seats
o Seats are lower sitting (more like a car)
Unread 03-25-2012, 08:00 AM   #11
TJRHD
* Seat Changes:
o Taller seat backs
o Softer seats
I kinda have long legs too but you are right about the torso. hmmm
NOT A HATER
Unread 03-25-2012, 08:14 AM   #12
Necko2529
For guys that have these installed, are there any problems tilting the seats forward?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
[B]RIP "Prescott 19"[/B] Prescott Fire Department
Necko2529 is offline   Reply With Quote
Unread 03-25-2012, 08:31 AM   #13
TheBoogieman
Demonic Jeep Freak!
I never had a problem with any of mine.
Unread 03-25-2012, 08:35 AM   #14
Necko2529
Thanks Boogie
Unread 03-25-2012, 08:44 AM   #15
biffgnar
biffgnar's Avatar
If your seats tumble it can lead to seats hitting steering wheel/windshield a little easier. In fact, I think there was a thread once where somebody cracked their windshield on the passenger side. Personally, no problems.
