#1 | |
Fish fear me
Seat heaters?
OK, call me a woos if you have to, I can take it. Has anyone installed aftermarket seat heaters into their ride, and if so how what brand and how well did they work. I am getting ready to give a set a try but had to ask before I started. It gets cold here in Oregon and I thought they'd be a nice luxury when having the top off/down. I already bought a set so hopefully there's no horror stories.
2003 Lt. Khaki Rubicon automatic Supercharged 4.7 stroker w/ Hesco aluminum head 70mm F&B throttle body Kieth Black forged 944 pistons Comp Cams custom ground camshaft 505 Performance PCM Split Second Engineering fuel/timing management Tom Woods CV driveshaft 50 lb/hr Trick Flow injectors 4" Full Traction LA with Bilstein 7100's JKS 1" MM,BL. TeraFlex engine and steering armor 4.88's w/ 35 " Toyo Open Country m/t's Moser Chromoly axle shafts front, Superior D44 rear Warn 9.5ti on a M.O.R.E hi clearance bumper Reid racing knuckles, Warn premium hubs PIAA 525's, and 510's XBOX Gamertag- ISHAGDyurGURL For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30 |
#2 |
I know AEV install them in some of their Jeeps but I'm not sure what brand. I'm sure they wouldn't put them in their rigs if it couldn't be done right.
Clint Colorado Jeep Club Member #60 My Jeep "If we weren't all crazy we would go insane" J.B. |
#3 |
"FREEDOM ISN'T FREE" http://redrock4x4.com For the Rocks: 01 TJ For the Trail: KFX 400 For the Street: 3.2 Aucra TL For the Track: Yamaha R1 |
#4 |
We saw a few sets at SEMA......not much money either.......
Looks like you take off the seat covers install the heaters and wire them up.... Did not look to bad on the install.... Biff
Wheel Spacers? Aluminum Fairleads? Winch Rope? LEDS? Winches? Accessories..... [URL=http://www.Offroadoverstock.com ] Visit Offroadoverstock.com [/URL] Biff |
#5 |
I'm planning on getting some along with the Iggee synthetic leather seat covers I'm getting. Let us know how you like them and how they work, etc.
[FONT=Franklin Gothic Medium]2005 Unlimited Rubicon Light Khaki Metallic [/FONT] [COLOR=Sienna]RE 3.5" SF w/ RE adjustable CA's/ JKS 1.25" BL/ JKS BMML/ OME LT Shocks/ Monroe Stabalizer/ 255/85R16 Trxus MT's/ JKS Quicker Disco's/ Custom Rockrails/ Iggee Seat Covers[/COLOR] |
#6 |
there's a thread over in jeeps unlimited on seat heaters:
http://jeepsunlimited.com/forums/showthread.php?t=685016&highlight=seat+heaters |
#7 | |
Lifted/Locked/Rolled/Sunk
I plan on getting my heaters from 4WDH though, a bit cheaper than the link posted above: http://www.4wd.com/shop/productdetail.asp?model=tj&productsku=S225
I need a 35" tire for spare. PM me if you have something. My Hummer Hole video SIRA 4x4 club I'll be Savvy someday!
#8 |
#9 | |
Gray Goose
For Sale: WJ Dana 44a w/ 3.73 gears and Varilock - Will part out if someone doesn't want the whole axle. 2004 Jeep Grand Cherokee Limited - January 2011 Grand Cherokee of the Month Build Thread: http://www.jeepforum.com/forum/f197/gray-goose-build-thread-1089523/ http://www.nebraska4x4.org/ |
#10 |
Get a heated jacket liner. You'll be more comfortable when driving with the top off with it than just having your backside warmed with seat heaters.
#11 |
Would the seat heaters work OK if I put them under my Wet Okoles? Or do they really have to go under the actual seat material??
#12 |
i brought a pair of the gm licensed ones from the autport site. pricey, but i figured if i am going to go to that much work to install them, i want them to last. i love them. three heat settings, feedback controlled, one hour "sleep" timer. full power on them is plenty hot. i was (still am) driving the jeep around with no top in 40 degrees staying nice and toasty. i get crazy looks, but, whatever! it took me a full day to install, but it was completely worth it.
'05 Unlimited, 3"+ AEV/Frankenlift 35X12.5 Toyo M/Ts on 16" Allied beadlocks 1.25" JKS BL + MML Eaton elockers/4.56s/alloys F&R lots of armor, bunch of other goodies Baystate Jeepers member |
#13 |
$79.00 each! TJ's are on the list of aplications.
#14 | |
Fish fear me
#15 |
that is the set, but i think they were 280ish for the pair.
you could install them underneath your seat covers, but they use an adhesive backing to stay in place. the adhesive "becomes stronger as it is heated" (from their install video, which is sweet by the way) so it would be almost impossible to remove the seat heater element without ruining it if you ever took off your seat covers. the adhesive is extremely strong, once i had it positioned on the foam, there was no going back.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
