Seat Belts FUBAR "Add It To The List" - JeepForum.com
post #1 of 7 Old 09-27-2006, 01:04 AM Thread Starter
badkarma61
I started to remove my roll cage last night, to prep for spray in bed liner. When I disconnected the seat belt retractors, the remaining material was rolled in with the spring tension. I tried to retract the seat belts from the roller now they are stuck in and will not let out. How can I get them to start to let out again?
Thanks in advance
badkarma61 is offline
post #2 of 7 Old 09-27-2006, 01:16 AM
TruckMuddr
Always Something
TruckMuddr's Avatar
I'm pretty sure if you hold the bottom part level, like it would be if it's hooked up in the jeep, it should work.I heard that if you bolt the bottom up first then hook up the top part it will work also.
Richard Harvey Jr.
'04 TJ, X, 4.0, Auto, Silver, D30/D44 w/LS & 4.56's, RC 4" Series II, PA 3" BL, Advanced Adapter's TC Bracket, 15x12 Eagle Alloys 058, 15/35-15 TSL, 4x K/C DayLighters & Windshield Mounts, Ventvisor's Bugsheild, Door Sill & Window Vents, Fabtech Front Bumper & homemade Rear W/ Backup Lights, Hurculiner.
"It's Always Something And It's Never Good" - TruckMuddr
TruckMuddr is offline
post #3 of 7 Old 09-27-2006, 01:26 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
yep
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #4 of 7 Old 09-27-2006, 01:47 AM
j.Russ
j.Russ's Avatar
Here is a link with the same issues should help you out try attaching the bottom end with the spool first and then the other end.
http://www.jeepforum.com/forum/showt...light=seatbelt
j.Russ is offline
post #5 of 7 Old 09-27-2006, 05:40 AM
Thump85
Thump85's Avatar
correct, first attach the bottom part then pull the top part back up
2003 Wrangler Sport
-Specs in profile
-Support your local wheelin' club.
Thump85 is offline
post #6 of 7 Old 09-27-2006, 06:17 AM
cheesycook
Accident Prone Bonehead
cheesycook's Avatar
I thought mine were broke for a week. As soon as I bolted them back in they worked.
98 TJ 4.0 Stick 30 Lock-Right/44 True-Track,4.56. Fire RED. Optima Red top. 3" Full Traction lift, Cragar 352 Street locks w/3.75 BS. 32" BFG AT's. Sailcloth top.
tubular fenders. AtoZ Fab rockers and front and rear bumpers. TBT sportsbar and rear spreader. VDP 6 speaker bar. 2K Intake Manifold. Tuffy Speaker lock boxes. Power inverter. Cobra CB. Magellan GPS. Bed lined tub. 3core HD radiator. Olds airbox with Hummer snokle. Besttop seat covers with heaters. All running lights LED.Steering and oil pan skids. Mile Marker PE8000 winch. Currie Anti-Rock. Olympic trunk. Tuffy Console....and Buddha on the winch. :) And a child seat stained with mud.
Hermiston, ORL
, because I don't have a clue, but Stu does!
cheesycook is offline
post #7 of 7 Old 09-27-2006, 06:28 AM
mattman8706
mattman8706's Avatar
2009 JK Wrangler
I thought mine were broke too
So I bought some new ones
and then I found out you bolt the bottom one first
-Matt
mattman8706 is offline
Creating a "master list" of writeups, post yours here rustywrangler YJ Wrangler Technical Forum 35 10-15-2009 09:48 AM
my seat belts dont "click" hemmer TJ Wrangler Technical Forum 1 12-15-2007 06:17 PM
"Racing" Seat to OFFROAD Seat Conversion? HowIRoll TJ Wrangler Technical Forum 3 08-07-2007 10:49 AM
anybody know what this means is "next" on the to-do list? BigWaylon TJ Wrangler Technical Forum 10 09-26-2004 01:33 AM
Need to make a "Jeep" List... shebas04TJ TJ Wrangler Technical Forum 11 09-19-2004 02:23 PM
