Seat belt retractor release - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Seat belt retractor release
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 07-14-2010, 06:56 PM   #1
gdelong
Help, I took my seat belt retractors loose to line the tub. the belts retracted now I cant get them to release so I can re connect the retractor device to the rool bars. what is the trick mto release these belts.
thanks
gdelong is offline   Reply With Quote
Unread 07-14-2010, 07:02 PM   #2
jdub36
I am not sure if there is a trick to make them release. All of the write-ups suggest tying them up so they don't retract too far. maybe someone will come along with a suggestion to get the belt back out.
jw
jdub36 is offline   Reply With Quote
Unread 07-14-2010, 08:29 PM   #3
GilpinTJ
thanks
I think you need to be sure that the mechanism is vertical - just like when it's installed.
John P.
Colorado Jeep Club Member #494
www.thepokerfloorman.com
GilpinTJ is offline   Reply With Quote
Unread 07-14-2010, 10:17 PM   #4
Jay12
Somebody said in the 1 liner write-up to step on the metal part that goes to the side of the seat with your feet and pull up and try to stand up with the retractor. I tied mine up so I didn't have this problem though so not sure if it'll work.
Jay12 is offline   Reply With Quote
Unread 07-15-2010, 01:09 AM   #5
mJUSTINm
There is a weight inside that has to be at just the right spot to release. Just hold the retractor upright and level and it should release. If not, keep trying. It should come free.
-Justin | Bruised LJ Build
mJUSTINm is offline   Reply With Quote
Unread 07-16-2010, 07:51 PM   #6
gdelong
thanks, holing it in the orginal positon was the trick. released fine
Unread 02-06-2012, 04:21 PM   #7
tomcat9x19
jeep seat belts stuck
I held mine in original position fed more belt in (it was a tight fit) then pulled more out took me about 25 or more times but i finally got enough out that i had more play room to get the rest out. have patience and take your time! best way to fix it is prevent it!
tomcat9x19 is offline   Reply With Quote
Unread 02-06-2012, 04:57 PM   #8
jchou
Junior Member
Same thing happen to me yesterday actually!
Good you find the solution, it took me few try and beers to get it too )
jchou is offline   Reply With Quote
seat belt , seatbelt , retracting , stuck , release , removed
