seafoam in TB? - JeepForum.com
post #1 of 61 Old 09-17-2009, 12:29 AM Thread Starter
G-MANtj
seafoam in TB?
ok, so i bought a can of seafoam the other day and used it in my gas tank. it seemed to help a little bit but i was really looking to get rid of the knocking that seems to be coming from the lifters. i read on the xj forum where you put the seafoam directly into the throttle body and it would clean out all of the build-up. i was wondering what the best way to go about this on a tj was. i took the hose going into the TB off today but was reluctant to just pour the liquid in. what exactly do i do?
/| ,[___],
|---L-o||||||o-
()_)-()_)-o-()_)
G-MANtj is offline
post #2 of 61 Old 09-17-2009, 01:22 AM
TXjeepTJ
TXjeepTJ's Avatar
you should use a vacuum line going into the throttle body or intake, i think i read somewhere with seafoam(as it is a liquid) you pour it into a bowl, then have a rubber line going from the vacuum port to the bottom of the bowl- to where the vacuum sucks the seafoam in at it's own pace
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #3 of 61 Old 09-17-2009, 05:17 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
It's not going to help your problem.Just use carb or fuel injector cleaner.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #4 of 61 Old 09-17-2009, 07:32 AM
-dirt-
On my TJ, I administer(?) SeaFoam thru thee brake booster hose. Its the big thing opposite the firewall from the steering wheel. Has about a black hose coming off it. Pull the hose off and *Slowly* pour the SeaFoam in the hose while running. MAy or may nor help your particular problem. Be ready to change your spark plugs if you go this route, as this stuff can dissolve a bunch of crap that has to be burned up in the engine.
-dirt- is offline
post #5 of 61 Old 09-17-2009, 07:48 AM
TheBoogieman
Originally Posted by dirt_j00 View Post
On my TJ, I administered SeaFoam through the brake booster hose.
Fixed it 4 U.
post #6 of 61 Old 09-17-2009, 08:00 AM
-dirt-
One time I forget to hit spell-check
-dirt- is offline
post #7 of 61 Old 09-17-2009, 08:03 AM
jbach
it does work. i would just use water thru the TB though. it's free.
jbach is offline
post #8 of 61 Old 09-17-2009, 08:06 AM
Faramir66103
I just pour it SLOWLY directly into the throttle body. If you pour it slowly and use the throttle to keep the RPMs up, it works just fine. I've had the best results by slowly pouring in about two thirds to three quarters of the can and then dumping in the remainder and letting it choke out the engine. Then I let it sit for 5 minutes or so while I replace the air intake, clean up and close it up. Then I crank it up and then drive it at highway speeds and higher RPMs which seems to clean it out pretty well. I don't recall where I read these directions, and I've been told that Seafoam works no better than tap water with this proceedure, but there you have it. YMMV, use this procedure at your own risk, observe safety protocols, the usual disclaimers etc.
HTH,
Adam
'99 TJ Sport, 4.0 I6, 5 speed manual transmission, Hi Lift w/offroad kit, Viair 450C compressor, Garmin GPS, Skid Row Engine/Transmission, steering box & radiator skid plates, Kilby gas tank plate, AtoZ Fab full length rocker guards, Performance Accessories 1" Body Lift, OME 2.5" HD springs & shocks, JKS trackbars front & rear, BFG AT 33x12.5r15, EBC Yellow pads and Centric rotors
Faramir66103 is offline
post #9 of 61 Old 09-17-2009, 08:13 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
to clean out the build up in the intake and throttle body all you need is throttle body cleaner.
stick a flashlight in the TB and see if yours is this clean:
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #10 of 61 Old 09-17-2009, 08:13 AM
LandoCommando
The directions actually say to pour it in until the engine stalls and then let it sit for 15 minutes then start it back up.
Signatures are for attention whores.
Oh the irony.
LandoCommando is offline
post #11 of 61 Old 09-17-2009, 08:14 AM
Mino
I'm thinking I'm gonna use seafoam pretty soon. I'm just waiting for my next oil change because I heard you need to change your oil soon after using this stuff. Any truth to that? Now I just read in a post above that you should also change your spark plugs. How true is that? How much seafoam should I use? Thanks.
'05 Jeep Wrangler X
Rocky Mountain Edition
3" suspension lift, K&N cold air intake, Pro Comp MX6 shocks, JKS Quicker Disconnects & Front Track Bar, Dynomax Cat-Back system, SYE kit, Pro Comp Rock Crawler Wheels, 33" BF Goodrich A/T, Aussie Locker, and Warn XD9000i winch
Mino is offline
post #12 of 61 Old 09-17-2009, 08:17 AM
Mino
I've always taken my TB off to clean it with the TB cleaner. Is it safe to spray the TB cleaner in and around the TB and manifold? Thanks.
'05 Jeep Wrangler X
Mino is offline
post #13 of 61 Old 09-17-2009, 08:23 AM
Unlimited04
I removed the TB to clean the intake manifold and sensors attached to the TB. No problem for you to remove the TB to clean in and around it. Just don't drop dirt & junk adjacent to the manifold inside the intake.
I see you have a K&N - good luck cleaning, you'll be there for a week. After you see the mess the K&N creates you'll remove that worthless POS.
Useful Write-Ups:
Funny:
post #14 of 61 Old 09-17-2009, 08:39 AM
Mino
Actually I just cleaned the TB about a month ago after using the K&N setup for about 1 1/2 years and it wasn't bad at all. I was very surprised, especially after hearing all the horror stories on here. I know the bad rap the K&N filter gets on the forum but it's worked for me.
As for the intake manifold, as part of preventive maintenance, should I spray TB cleaner inside the intake? Sorry if that's a stupid question but I'd rather ask it than just wonder. Thanks.
'05 Jeep Wrangler X
Mino is offline
post #15 of 61 Old 09-17-2009, 08:54 AM
Unlimited04
Yes, and yes
Useful Write-Ups:
Funny:
seafoam! bmx_hb_guy YJ Wrangler Technical Forum 0 05-11-2008 08:01 PM
seafoam? bmx_hb_guy YJ Wrangler Technical Forum 4 05-07-2008 07:40 PM
Seafoam chriscisme YJ Wrangler Technical Forum 24 05-05-2008 08:35 PM
Seafoam ????'s 01amberfirewv TJ Wrangler Technical Forum 5 09-01-2006 05:00 PM
seafoam markbento TJ Wrangler Technical Forum 15 08-17-2006 12:00 AM
