seafoam - JeepForum.com
post #1 of 24 Old 02-23-2007, 08:38 PM Thread Starter
drew76924
drew76924's Avatar
seafoam
i picked up a can of seafoam today at autozone beucase it was on sale and i thought that i would try it. But where should i put it...
1. in the TB
2. in the Oil
3. in the gas tank
ive never used seafoam before so i just want to make sure i do it right i read 1/3 in the tb and the rest in the tank. just wondering if that is correct.
drew
RIP: 97' TJ on 35's (rolled)
03' Mustang GT Turbo Vert
drew76924 is offline
post #2 of 24 Old 02-23-2007, 08:42 PM
ptowntj
ptowntj's Avatar
It's up to the user to put it where you want it as needed. I just did it to my ranger the same way you did, and it helped...it did smoke a bit.
next time, please do a search, there are a ton of questions on seafoam.
8 lug xj.
ptowntj is offline
post #3 of 24 Old 02-23-2007, 08:44 PM
Michael_K
Michael_K's Avatar
http://dailydriventj.com/seafoam.shtml
YMMV
DailyDrivenTJ.com
JUST For Jeep TJ Owners Around the World!
Michael_K is offline
post #4 of 24 Old 02-23-2007, 08:46 PM Thread Starter
drew76924
drew76924's Avatar
ya i did search and i didn't really want to read through the 25 page thread about it. I just was basically wondering if put it in my tb and then in my gas tank if that is the right way to do it?
post #5 of 24 Old 02-23-2007, 08:52 PM Thread Starter
drew76924
drew76924's Avatar
Originally Posted by Michael_K
so the best thing would be to suck it up with the vacum line. just wondering but is that the same as pouring it into the tb?
drew
post #6 of 24 Old 02-23-2007, 09:07 PM
Michael_K
Michael_K's Avatar
It is different because of several reasons.
You can control how much Seafoam is going in by using the vacuum pretty well compared to pouring it into the throttle body. If you dump enough you can cause damage in your engine because it is not just the water that doesn't compress. It is liquid that doesn't compress causing hydrolock.
You don't need any tool to use the vacuum line vs. removing the air tube to get to the throttle body.
You are also risking soaking IAC which I managed to damage when I was cleaning the throttle body using carb spray.
Michael K.
DailyDrivenTJ.com
post #7 of 24 Old 02-23-2007, 09:10 PM Thread Starter
drew76924
drew76924's Avatar
alright so into the vacume line it goes...
i'm gunna wait until morning so i can see all the cool smoke lol
thanx drew
post #8 of 24 Old 02-24-2007, 08:53 AM
commodog
commodog's Avatar
i did the vacuum line seafoam on my ranger, let it sip it very slowly, must have been dirty cuz it caused a lot of smoke.
3 days later had to replace my front o2 Sensor.
Coincidence? not sure but it cost me 82 bucks
commodog is offline
post #9 of 24 Old 02-24-2007, 08:56 AM Thread Starter
drew76924
drew76924's Avatar
dang i don't want to have to replace my o2
post #10 of 24 Old 02-24-2007, 08:56 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
It would have smoked just as badly had your engine been brand-new and pristine inside.
Getting Savvy...
Jerry Bransford is online now
post #11 of 24 Old 02-24-2007, 09:13 AM
Fargo
Super Seafoam Mister
Those who've been around a while will remember this story!
But to answer your question just let the vacuum line suck it in. Its also good to just dump it in the fuel tank from time to time.
6spd manual
LJ Owners Group member #110
Fargo is offline
post #12 of 24 Old 02-24-2007, 10:11 AM
Michael_K
Michael_K's Avatar
Well, I have different experience from Jerry. I have put in Seafoam in various vehicles, 1999 V8 WJ, 1996 Nissan Quest v6, 2004 Toyota Camry 4cyl, and 1998 TJ 6cyl.
WJ emitted barely any smoke which had 40K miles on it. Nissan with 160,000 miles had almost no smoke, Toyota Camry with 30k and TJ at 70k, 80k, 96k, 100k miles did a lot of smoke.
One thing I noticed, WJ was barely choking with the seafoam being sucked in as compared other engines that I had pace how much was going in to keep the engine alive; must have been the bigger displacement.
Michael K.
DailyDrivenTJ.com
post #13 of 24 Old 02-24-2007, 11:26 AM
BoHeck
my 99 tj 4.0 smoked a good bit for a few seconds but for the rest of the can, not really that much...im just glad i did it cause it helped me find a hole in my exhuast manifold.
BoHeck is offline
post #14 of 24 Old 02-24-2007, 11:52 AM Thread Starter
drew76924
drew76924's Avatar
how will you be able to tell if there is a hole in your exhaust manafold will liquid come out or will it smoke out of the hole?
drew
post #15 of 24 Old 02-24-2007, 11:59 AM
fire239
Smoke will come out of the hole, if ya have one
fire239 is offline
seafoam! bmx_hb_guy YJ Wrangler Technical Forum 0 05-11-2008 08:01 PM
seafoam? bmx_hb_guy YJ Wrangler Technical Forum 4 05-07-2008 07:40 PM
Seafoam chriscisme YJ Wrangler Technical Forum 24 05-05-2008 08:35 PM
Seafoam ????'s 01amberfirewv TJ Wrangler Technical Forum 5 09-01-2006 05:00 PM
seafoam markbento TJ Wrangler Technical Forum 15 08-17-2006 12:00 AM
