School me on my D44 blow up. - JeepForum.com
post #1 of 12 Old 06-06-2012, 01:40 PM Thread Starter
Benderff
Benderff's Avatar
Long story short. I though I had a U-joint going bad. I pulled the shaft even though it seemed fine. Tracked down the drivetrain noise to this. (Yes it's an OX locker, don't hold it against me.)
I don't think the shims should be out, let alone move all over.
The gears and locker where set-up over two years ago. Last time I looked the pattern was fine. Now it's out at the edge. After talking to a mechanic friend of mine i'm guessing it's a bearing failure?
Using a ruler the backlash is roughly around 1/16th" I can pry the locker side to side about 1/8th".
Gear set-up is the only thing I have paid to have done, cause I don't know **** about it. What are your guys thoughts?
Benderff is offline
post #2 of 12 Old 06-06-2012, 02:09 PM
clintrivera
Shouldn't be any play side to side. There should be preload, as in you should have to pry the carrier to get it out. I'm not sure how OX specifies setup, but the shims were probably supposed to go between the carrier and bearing.
clintrivera is offline
post #3 of 12 Old 06-06-2012, 02:17 PM
ftgiles
OX gets shimmed on the outside and uses the same shims and bearings as an ARB.
ftgiles is offline
post #4 of 12 Old 06-06-2012, 02:23 PM
ftgiles
It is always a little tough to tell exactly because the original cause is often hidden by more destruction caused by metal pieces floating around. My guess would be a bad bearing, too. But did the bearing go bad first and then a chipped tooth? Or a tooth chipped and caused the bearing to go bad?
A poor setup usually shows up pretty quickly in either breakage or noise, so I doubt setup was the original cause.
ftgiles is offline
post #5 of 12 Old 06-06-2012, 02:28 PM
mdm
Farm Wheeler
The OX is shimmed the same way the stock carrier is. Where are the shims on a stock D44?
How do the bearings look? There are only a couple of ways the shims could be loose like that, improper set up or bearing failure.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #6 of 12 Old 06-06-2012, 02:53 PM
ftgiles
Dana shims both ways. Old D44s where shimmed between the bearing and the carrier. Newer D44s are shimmed between the bearing and the housing.
ftgiles is offline
post #7 of 12 Old 06-06-2012, 03:38 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
2015 JK Wrangler
I hope your locker survived? I'm still learning about gear set up and such, but I wonder if the axle housing itself got bent allowing the preload shims to become loose? I'm glad you caught it before a catastrophic failure though! Hopefully your OX locker is still in good functional condition and all you need is another ring and pinion and a rebuild.
My newest build:
Necromancer_tat is offline
post #8 of 12 Old 06-07-2012, 01:51 PM Thread Starter
Benderff
Benderff's Avatar
That was my understanding. It has a ton of side play. Most guys around here don't want to work on an OX locker because they don't see many.
I have not pull caps off to see yet. I will get some pictures when I do. At this point I'm pulling the whole assembly out.
It's been two years and about 12,000 miles, so bearing failure seems like the problem.
I hope so to, just because I'd rather not spend the money. If it is dead, ARB time.
I have been putting off building a 4 link for about a year now. Pulling the housing out now. Going to have it looked at and fixed as needed. Working on all the little crap I have needed to do, cutting the mounts off, and getting it all ready.
Benderff is offline
post #9 of 12 Old 06-07-2012, 02:11 PM
JWebber
Are your bearing caps imprints match housing imprint for same side? Thats the only thing I can think of how the shims walked past the bearing caps. I can't tell in the photo tool in the way.
JWebber is offline
post #10 of 12 Old 06-07-2012, 02:36 PM
mdm
Farm Wheeler
How would putting the caps on wrong allow the shims to move? The bearing caps are align bored with the housing to properly center the carrier in the housing. Putting the caps in wrong can cause bearing wear but the shims won't be moving around or the carrier be loose until the bearings are worn to the point that you get slop in there.
mdm is offline
post #11 of 12 Old 06-07-2012, 02:37 PM
Robert J. yates
Stock D44 housings are interesting... yes they are a D44 but there are shortcuts that Jeep took that result in less than desirable longevity. The bearing surfaces for my 44 are not the biggest and with deflection and hard use, lets just say that one day my air locker quit working. Took it to my gear guy and we caught it in time before it damaged the gear set but he basically told me that eventually, my housing is going to be toast and what he described as toast seems pretty close to your damage. 4:56's and 35's are basically max for this axle.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #12 of 12 Old 06-07-2012, 04:17 PM
clintrivera
I can't recall any dana axle I've seen where the shims weren't covered by the bearing caps.
Oil Blow by on 88 4.2 YJMonster YJ Wrangler Technical Forum 8 04-17-2016 08:04 PM
blow by MegaCabMan YJ Wrangler Technical Forum 4 01-31-2012 05:21 PM
blow by....... busadave YJ Wrangler Technical Forum 3 04-05-2009 08:27 PM
I think I have blow-by YJames90 YJ Wrangler Technical Forum 3 03-26-2008 08:39 PM
oil blow by natedawg87317 YJ Wrangler Technical Forum 7 11-15-2005 06:54 AM
