school me on door surrounds - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > school me on door surrounds
Brand New! Quadratec LED Headlights!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 03-16-2014, 07:10 AM   #1
Bigdude408
So, Im ready to replace my soft top on my jeep. I just purchased some full doors for her, it came with half doors and no surrounds. there always seemed like it was missing something around the top half of the door, it just looked unfinished. doing a little research, it seems like I should have surrounds, but the last replacement top must have been the one without them.
I'm looking for any suggestions on what soft top to get... I was thinking the bestop frameless, but does one come with the surrounds, or would it be better to find a stock set and install before I get the top?
thanks in advanced!
Bigdude408 is offline   Reply With Quote
Unread 03-16-2014, 07:31 AM   #2
thethirdeye
If I remember correctly, the bestop trektop nx comes with new door surrounds, the rampage does not, I don't know about any others, a lot of the replace-a-tops don't use door surrounds, they are set up more like a YJ, where they use the "b-piller" bar and upper bar from the top frame to make the top and rear door seals, but thats only if they have an aftermarket softtop frame
thethirdeye is offline   Reply With Quote
Unread 03-16-2014, 07:31 AM   #3
TJJeepJosh
I have the rampage frameless soft top. Personally I love it. Window storage right under the top and easily in safari mode or taken off completely. You would need a bestop or similar windshield heard for a top like this though.
http://www.quadratec.com/products/11122_02_07.htm
As far as door surrounds go, it would be expensive to buy new and most aftermarket ones aren't as good as factory. Keep an eye out on craigslist until a set comes up that you can grab.
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline   Reply With Quote
Unread 03-16-2014, 07:52 AM   #4
BorderTJ
Originally Posted by TJJeepJosh
I have the rampage flameless soft top.
Nice! I hear flameless tops are preferred for re-entry into earth's atmosphere! Haha
BorderTJ is offline   Reply With Quote
Unread 03-16-2014, 08:41 AM   #5
TJJeepJosh
Oops didn't see that there
Unread 03-16-2014, 09:51 AM   #6
Line58
You can probably get one from somewhere like Daveys Jeeps.
[URL="http://whateversclever.userboard.net/"]http://whateversclever.userboard.net/]Whatevers Clever Forum[/URL]
[URL="http://www.jeepforum.com/forum/f9/ax5-ax15-swap-write-up-murphys-law-edition-1515070/"]TJ AX5 to YJ AX15 Swap[/url]
Line58 is offline   Reply With Quote
Unread 03-16-2014, 12:48 PM   #7
nichelsond
sent you a pm
nichelsond is offline   Reply With Quote
Unread 03-16-2014, 02:06 PM   #8
Bigdude408
ive seen them on craigs list for 75 or 80 bucks a few times, looks like I should have bought them up. I didn't know they was that valuable.
