Schematics for Fog lamp switch - JeepForum.com
post #1 of 3 Old 06-30-2010, 07:36 PM Thread Starter
scutt72
i have an 04 Wrangler Sport. the switch for the fog lamps wont turn off unless the turn signal switch is in the down position or if push and hold the end of the switch in. was wondering if anyone else had this problem or if anyone has a schematic of the entire steering column. i want to find what wires control the fog lamp switch and just put in a toggle switch, rather than replacing the entire turn signal switch. right now i have the fuse pulled out for it so that it doesnt drain the batteries. any thought or suggestions would certainly be appreciated
thanx in advance
scutt72 is offline
post #2 of 3 Old 07-01-2010, 03:30 PM
krahnilogikal
Try this (not sure about differences from 02 to 04 but it might put you in the right direction):
http://www.rol.ac.psiweb.com/jeep/tj...-8w-Wiring.pdf
words, things, stuff
krahnilogikal is offline
post #3 of 3 Old 07-01-2010, 04:10 PM Thread Starter
scutt72
as far as the column goes, i dont beleive that there is much difference.
thanks for the docs
scutt72 is offline
wiring diagram , fog lamp switch , tj
4wd indicator lamp switch...? burnout189 YJ Wrangler Technical Forum 26 05-13-2010 09:05 PM
4WD Indicator Lamp Switch???? louieberner YJ Wrangler Technical Forum 2 12-29-2009 07:43 PM
fog lamp switch pinout. ancestralworm TJ Wrangler Technical Forum 5 03-11-2008 01:27 PM
Overdrive switch lamp FmrVette TJ Wrangler Technical Forum 3 06-26-2007 08:54 PM
Fog Lamp Switch mossimo19 TJ Wrangler Technical Forum 3 08-11-2004 06:48 PM
