Scheduled Maintenance - JeepForum.com
post #1 of 9 Old 10-17-2010, 04:43 PM Thread Starter
Acoustaman
The only maintenance done on my 2001 TJ since I bought it new has been a belt change, battery change, air filter change, and regular synthetic motor oil changes. She's at 60,000 miles now and coming up on her 10 year birthday. I don't know what needs to be updated to keep her running in top condition.
Please list what you think I :
a) must do
b) should probably do
c) do if I have money left over
Thanks for the help!
Acoustaman is offline
post #2 of 9 Old 10-17-2010, 05:22 PM
kehoe
Here is the service checklist incase you don't have a service manual:
Jeep.US41.org/service
kehoe is offline
post #3 of 9 Old 10-17-2010, 05:54 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
a. Change the brake, coolent, transmission, transfer case and differential fluids. Change the spark plugs...
b. Fill in your profile...
Knuckelhead is offline
post #4 of 9 Old 10-17-2010, 06:03 PM
wushaw
Rockin jeep
wushaw's Avatar
You gonna need a higher pressure hose than what yo have there to clean off the grill
Differential, tranny, xfer case service.
wushaw is offline
post #5 of 9 Old 10-17-2010, 06:12 PM
Cool92yj
A. Diffs, Transmission, T case, Coolent spark plugs,
B. Brake system/hydraulic clutch flush if it gets below freezing.
1992 YJ 2 Inch BDS Lift, 35 Pro Comp MT'2s, NV3550, ford 8.8,
Lockrights, Metalcloaked, built 4.0.
Cool92yj is offline
post #6 of 9 Old 10-17-2010, 06:17 PM
grogie
M-F: Cell Block #4533
grogie's Avatar
Interesting that he says transmission at 90k. I always thought five years or 50k was a good idea? I recently did mine as it's been five years and 27k.
Red Jeep Club #345
2006 TJ Sport -
2004 KJ Limited
2013 Off-Road Trailer -
from the onslaught of young idealists. -- Don Colacho
grogie is offline
post #7 of 9 Old 10-20-2010, 01:56 PM Thread Starter
Acoustaman
I'm glad wushaw noticed I was finishing up taking a leak in the picture and gladly pointed that out. When you gotta go, you gotta go.
ON to business... thanks for all the advice guys. Here is what I'm planning on doing:
Immediately: Spark Plugs, Differential, Transmission*, Transfer Case*
*Q: Do I need some sort of pump to get all the fluid out?
Later this year: Coolant and Brakes
If you guys can think of anything else please feel free to share!!!
post #8 of 9 Old 10-20-2010, 03:25 PM
kehoe
For trans and transfer case, you can just take out the drain plug to let them drain. No need for a pump to get fluid out. You will need a pump to get the new fluid in.
I am not sure exactly which transmission you have, but this write-up is pretty useful for the general idea if you have not done it before:
Jeep NV3550 Transmission & NP231 Transfer Case Service
kehoe is offline
post #9 of 9 Old 10-20-2010, 06:10 PM
Cool92yj
If you do all the fluids and sparkplugs yourself its not that bad under 200 bucks and a afternoon worth of work.
Cool92yj is offline
maintenance
60K Scheduled Maintenance Irishcopper TJ Wrangler Technical Forum 3 05-06-2008 07:53 AM
Scheduled Maintenance? dallasjetfan TJ Wrangler Technical Forum 5 03-20-2008 07:43 AM
Scheduled maintenance vegas TJ driver TJ Wrangler Technical Forum 2 09-02-2007 08:13 AM
SCheduled maintenance, are you doing it?? GetTwo TJ Wrangler Technical Forum 35 02-25-2007 01:10 AM
What is TJ Scheduled Maintenance Flyusaf2002 TJ Wrangler Technical Forum 1 02-02-2006 11:46 AM
