Savvy Under Armor - Page 6 - JeepForum.com
 20Likes
post #76 of 2736 Old 06-07-2010, 02:03 PM
LGriffith
I'll early adopt an exhaust hanger to fix the rattle that came along with my rokmen stuff...
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith is offline
post #77 of 2736 Old 06-07-2010, 02:35 PM Thread Starter
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Originally Posted by biffgnar View Post
Are there going to be any clearance issues with the skid and the common mounting spot for an OBA tank mounting behind the TC? In the midst of OBA install and was just getting ready to mount tank there. Perhaps I should consider other locations.
That will be for you to find out. We have no way of knowing. As long as it is above the bottom of the TC you should be fine.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #78 of 2736 Old 06-07-2010, 02:40 PM
Kiwi
I'd suggest holding off on putting the tank there if you are thinking of going with a Savvy skid, at least until you have the skid on. I had to move mine further back than normal when I went with an Nth skid. I'm going to move mine out of that location since it's got really beaten up, and I don't think I can risk it being in that location any longer.
Kiwi is offline
post #79 of 2736 Old 06-07-2010, 02:42 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Perhaps you should.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #80 of 2736 Old 06-07-2010, 02:43 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Put it next to your hand throttle and buy a Co2 tank.
I am Savvy
post #81 of 2736 Old 06-07-2010, 02:44 PM
Kiwi
That's exactly what I am thinking
Kiwi is offline
post #82 of 2736 Old 06-07-2010, 02:51 PM
biffgnar
biffgnar's Avatar
Perhaps you should.
Will do! Any further developments on the TC shifter? Is the Novak cable shifter for the 231 ready? Or should we be thinking about modifying an AA/Tera adapter? Or has your creativity derived another savvy solution?
Romney in 2020!
biffgnar is offline
post #83 of 2736 Old 06-07-2010, 02:55 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Having used the Novak solution on a couple of 241's, I'd be hard pressed to outdo them and my energies are better spent not reinventing the wheel.
I am Savvy
post #84 of 2736 Old 06-07-2010, 03:22 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
But is Novak ever going to release a 231 Cable version?
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #85 of 2736 Old 06-07-2010, 03:28 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Gerald should be placing an order this afternoon for the first 20 or so off their production line to make it easier for our customers to single source this project.
I am Savvy
post #86 of 2736 Old 06-07-2010, 03:31 PM
jpfelix
Originally Posted by Savvy View Post
I don't know yet. Tomorrow we'll put the whole thing on the scale.
I'm guessing 50 lbs?
We've not weighed any of it yet. I'm going to guess that with the motor mount lift, body lift, skid, wings, crossmembers and all the fasteners, it's going to be between 50 and 60 lbs.
that's close to the weight of my current oil pan skid i made out of 1/4in steel.
jpfelix is offline
post #87 of 2736 Old 06-07-2010, 03:33 PM
biffgnar
biffgnar's Avatar
That sounds good. Hope the stash of cash I have been holding on to for all this turns out to be enough. Maybe I can find somewhere that pays for donation of blood or other bodily fluids if it turns out to be a little short.
Romney in 2020!
biffgnar is offline
post #88 of 2736 Old 06-07-2010, 03:35 PM
SuperWade2
SuperWade2's Avatar
So that's a Yes...Good to hear since I'm not super happy with the Manual Novak shifter conversion I did (as you "heard" a few weeks ago)
2017 WK2 Overland
post #89 of 2736 Old 06-07-2010, 03:40 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
How did you get a yes out of that? I didn't say they were released, nor did I say they were in stock. What I said was G was placing an order for the first ones off the production line. No more, no less.
I am Savvy
post #90 of 2736 Old 06-07-2010, 03:43 PM
SuperWade2
SuperWade2's Avatar
My question was;
Why would Novak take orders for something they were NEVER going to produce. So I took the fact that Gerald was going to place an order to mean that they were going to eventually release a 231 Cable version... still means YES to what I was asking.
2017 WK2 Overland
aluminum , belly up , crossmember , high clearance , savvy , savvy under armor , t-case , t-case skid plate , transfer case , transfer case skid , under armor
For the Savvy amongst us mrblaine TJ Wrangler Technical Forum 2765 04-24-2015 06:56 PM
Savvy Corner Armor Install Write-up SuperWade2 TJ Wrangler Technical Forum 36 03-03-2015 06:06 AM
Savvy vs. Rokmen Aluminum Corner Armor eblack TJ Wrangler Technical Forum 47 04-24-2012 01:08 PM
Savvy aluminum armor, what tube flares? pjku79 TJ Wrangler Technical Forum 11 07-12-2010 08:05 AM
Savvy at KOH!! DevilDogDoc Wrangler General Discussion 11 02-13-2010 02:40 PM
