Savvy Under Armor - Page 17 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Savvy Under Armor
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Weekend Sale at JeepinOutfittersPoison Spyder from CCOR!
Unread 06-13-2010, 08:30 PM   #241
LuckRider
LuckRider's Avatar
Originally Posted by explorerlyon View Post
3-4" extra ground clearance. The transfer case is raised something less than that amount since some of the clearance is the way the skid fits. I have an 05 LJ Rubicon with a 3" lift. I understand I will need adjustable control arms, but what about a CV shaft? If so, how do I go about determing the proper length CV shaft before installing the arms and TT?
Jack the frame of the Jeep up 3", that should work
Support Our Troops!
ALL WK2 Owners, Click Here
JFI Member #7: Helping out the Scammed
2004 Rubi: Ready to Kill the Chrome!
Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s
LuckRider is offline   Reply With Quote
Unread 06-13-2010, 08:31 PM   #242
Savvy
Savvy Off Road
Savvy's Avatar
The right way to do it is install everything and then measure the distance. Then give Tom Woods a call. You can also talk with them and they can get pretty close if you can't wait.
Email me for the fastest response: gman@savvyoffroad.com
Like us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
http://www.savvyoffroad.com
Savvy Spartan 2004 LJ
2012 JKU Test Mule
2006 LJ Unlimited Black Hole
2005 LJ Test Mule
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote
Unread 06-13-2010, 08:32 PM   #243
biffgnar
biffgnar's Avatar
Nope. The TC case is bolted to the transmission. The transmission mount which holds the back of the transmission rests on the skid. If the skid goes up, it pushes the transmission up which takes the attached TC up with it. The TC output shaft moves up however much the bottom of the skid moves up (minus any savings from the low profile Trans mount).
2013 NORRA Mexican 1000 - Co-Driver #199
2012 King of the Hammers - Hammerking Productions "Intern"
HELP KEEP JOHNSON VALLEY OHV AREA OPEN: http://www.savethehammers.org/
biffgnar is offline   Reply With Quote
Unread 06-13-2010, 08:42 PM   #244
LuckRider
LuckRider's Avatar
I think he is talking about the low profile mount when he mentions the difference in skid raise between t-case raise. That is the "...is the way the skid fits." thing.
Support Our Troops!
Unread 06-13-2010, 09:03 PM   #245
mrblaine
mrblaine's Avatar
Just to clarify, the t-case mount does not rest on our skid. It has exactly nothing to do with our skid.
The new mount we supply with the Under Armor package bolts to the stand alone crossmember and the new exhaust hanger bolts to the side of the mount.
You all can hash and crunch numbers until the cows come home and it won't change the height down from the frame and the amount of distance there is between the bottom of the frame and the bottom of the tub. We've forced everything to be as tight as possible and still not rattle or rub.
I am Savvy
blackmagicbrakes.com
mrblaine is online now   Reply With Quote
Unread 06-13-2010, 09:13 PM   #246
lumpster
i know it wont rattle or rub, but id take a little bit of it to get rid of my shovel under my jeep. Of course i would call you immediately if it did rattle Blaine.
to anyone that is worried about the rear drive shaft on an LJ, your better off getting a SYE and good double cardan rear drive shaft rather than to worry if its going to work or not. I didnt need one when i put my 4 inch currie lift on, but i did it anyways, i figure im getting the savvy under armor anyways so why not just prepare for it. I dont Blaine to say no to me when it comes time to beta the rubi skid because i dont have all the stuff i need to test fit it correctly!!
Originally Posted by SuperWade2 View Post
Blaine asked me before we left camp if I'd ever been wheeling before, I said "sure, of course I have"... about 50 feet onto the trail, he said "Wade, you f'in lied to me, you've never been WHEELING before"... I think he was right! :rofl:
Want to STOP?
JEEP Co-op parts, DELRIN DOOR BUSHINGS, TRE inserts, poolball shifters, tierod flip kits
My Goodyear tire experience
lumpster is offline   Reply With Quote
Unread 06-13-2010, 09:20 PM   #247
LuckRider
LuckRider's Avatar
Correct me if I am wrong, but isn't the 241 shorter than the 231? That reasons to stand that a Rubi has less of a chance to get a vibe than a regular TJ or LJ (comparing a TJ Rubi to a TJ and an LJ Rubi to an LJ). 4" is pushing it even for an LJ, I think the shorter case is helping.
Support Our Troops!
Unread 06-13-2010, 11:10 PM   #248
lumpster
The rubi case doesnt have a slip yoke like the stock 231. But i think if you put a ss sye on a 231 its shorter than a rubi case. Anyone that would add a double cardan rear driveshaft to a 231 wouldnt have the problem your talking about, they would be adding a sye.
Want to STOP?
Unread 06-13-2010, 11:13 PM   #249
LuckRider
LuckRider's Avatar
I was talking stock compared to stock. I actually thought a 231 with a regular SYE is a tad shorter than the 241. I was just bringing that up because it could be why you don't have vibes with 4" on an LJ when others might.
Edit: If anyone has the sizes for the different t-case setups, that would be pretty awesome.
Support Our Troops!
Unread 06-14-2010, 07:36 AM   #250
sanchagrins
I can't wait to get one! Looks super sharp guys!
sanchagrins is offline   Reply With Quote
Unread 06-14-2010, 07:48 AM   #251
Savvy
Savvy Off Road
Savvy's Avatar
I'm hoping today the shop will tell me the date when I can start shipping units. The LJ when together well except the new exhuast hanger needed a tweak. We'll see the revision and should be good to go.
Then I'll be contacting everyone who fits our criteria.
Thanks,
Gerald
2012 JKU Test Mule
2005 LJ Test Mule
Unread 06-14-2010, 09:33 AM   #252
DaleII
Thanks,
Gerald
If it matter I don't have stock exhaust.. But i have a muffler and it dumps right before the rear differential. could tell you guys if people with aftermarket exhausts will have the same problem as stock exhausts.
2005 Silver LJ
DaleII is offline   Reply With Quote
Unread 06-14-2010, 11:57 AM   #253
biffgnar
biffgnar's Avatar
Understood. Thanks for the clarification. Makes sense given the pictures you've shared of the new cross member. I think the point I was making to the other poster still stands though about the amount of lift the driveline is seeing. Based on stock setup which does rest on the skid not sure of any way to move things up without moving up the TC output shaft.
Unread 06-16-2010, 10:24 AM   #254
NotURMailman
NotURMailman's Avatar
Any news?
My RHD TJ - Savvy equipped... And loving it! - Durty Rok Carolina Offroad
I drive on the right side, what's wrong with you?
Be very careful with the wife mod. Uninstallation can be extremely expensive. Wife mods have been known to take the Jeep and all other mods during the uninstall process. Also, make sure you service your wife mod properly as often as humanly possible. Wife mods not properly serviced may malfunction or uninstall themselves at any time.
NotURMailman is online now   Reply With Quote
Unread 06-16-2010, 11:37 AM   #255
Benderff
MEMBER
Benderff's Avatar
Yeah I keep checking my email, and carrying my phone everyplace.
Benderff is offline   Reply With Quote
aluminum , belly up , crossmember , high clearance , savvy , savvy under armor , t-case , t-case skid plate , transfer case , transfer case skid , under armor
