Savvy Under Armor - Page 162 - JeepForum.com
 33Likes
post #2416 of 2821 Old 06-26-2013, 11:53 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by 2006LWBTJ View Post
So I removed the shroud and the fan spins freely by hand. Hopefully that's a good sign. As far as my options now... I could trim/relocate the shroud,
It shouldn't spin "freely".
Relocate the mounting bolt holes in the shroud, don't trim the shroud...
Knuckelhead is offline
post #2417 of 2821 Old 06-27-2013, 06:14 AM
stwilson74
stwilson74's Avatar
I doubt you'll have much room between the firewall and the bellhousing if you add the extra mml, just open up the holes on the shroud.
"Betsy" 2005 Unlimited Rubicon Sahara Edition #603 of 1000
Originally Posted by Necromancer_tat View Post
I like having my panties in a wad though, because when I get DW they rub me in just the right way! :D Wadded panties plus DW equals Jeepgasm! :D :kiss:
stwilson74 is offline
post #2418 of 2821 Old 11-20-2013, 06:25 PM
jhurt
Update for 32RH? Three years in...I installed (a year and a half ago) Savvy MML, body lift and the Novak shifter in anticipation of the skid and cross member...which still isn't listed on Savvy's site as available for a 2000 TJ 4.0/3-speed auto. I thought I saw somewhere in this 162 page thread someone made their own custom cross member for the 3-speed. Is that the only option? I really don't see it ever being released at this point. Do you modify one of the Savvy cross members? Fab your own? Use one from a different manufacturer?
'00 TJ 3 spd, D30 aussie locker/8.8 E-Locker, Currie springs, Savvy/Currie arms
jhurt is offline
post #2419 of 2821 Old 11-20-2013, 07:35 PM
UTWeezul
I'd just fab a custom crossmember. A couple bushings, some tabs, and some tubing and a few hours of work and it'll be done.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #2420 of 2821 Old 11-20-2013, 10:23 PM
StupendousMan
It can be done but lots of work (32rh)
StupendousMan is offline
post #2421 of 2821 Old 12-03-2013, 10:37 AM
matthew900
matthew900's Avatar
I just did my first oil change since installing the modular armor and I have to say that while I'm happy with the skid off road I'm disappointed that the new version of the armor does not include an oil change door of some kind. Having to remove the engine skid just for an oil change turned a 30 min job into a 2 hour project.
matthew900 is offline
post #2422 of 2821 Old 12-03-2013, 10:51 AM
stwilson74
stwilson74's Avatar
2 hours? It's only 7 more bolts and even with the door there were 4 bolts so realistically only 3 more bolts... I mean ya, it does add a little time but not an hour and a half more and my skid has a good bit of scarring right were that little trap door would be so I'm happy not to have it, I'm fairly sure it would have been compromised by the hit the skid took. You just dropped the front part of the skid, not the whole thing right?
post #2423 of 2821 Old 12-03-2013, 05:20 PM
matthew900
matthew900's Avatar
I tried dropping the front but ended up having to drop the whole thing to get at it properly and not create a mess. All the bolts where coated with a mud/sand/oil mixture that made everything a hassle to get threaded back together. I'm sure my turn around time will go up with practice but it's still inconvenient and will always take longer than it should. You would think that given the fact that the original version had an allowance for efficient oil changes, and that competitive products do as well, it would have been built into this one. I'm recommending he add the oil change door back in.
Iím also concerned that itís going to be a problem having a shop or oil change place do an oil change if I ever donít have time to do it myself.
post #2424 of 2821 Old 12-03-2013, 07:54 PM
stwilson74
stwilson74's Avatar
Ya, but most of the competitors that I have seen with a provision for oil draining is simply a hole in the skid. You can take a hole saw and add a hole at will but I like mine smooth. I remember reading that at least one of the guys with the original UA popped that little panel hard enough to break the welds or bolts, that may have contributed to it's demise and is exactly why I'm fine without it. A cordless impact driver pulls the 4 countersunk screws out super quick and the front 3 bolts are easy, then putting it back on I get the front middle bolt started and slip the other two in place, roll under the middle and get the 4 countersunks in nice and quick and then back to the front to get those three finished up. I don't think it adds more than 15 minutes or so.
This is probably obvious but if you do decide to take a hole saw to the skid, take it off the Jeep first... lol
post #2425 of 2821 Old 12-04-2013, 03:10 PM
OkLaHoMaTJ
Whats the average wait time on getting these?
Some have said a few weeks...others say a few months....he's sold out now according to his website.
On the rubicon models are you guys relocating your locker pumps? Or can they mount to the UA?
I'm ordering my Novak cable shifter soon so that's one piece out of the way. I already have the JKS 1'' MML and Savvy 1.25'' BL.
My Thread - http://www.jeepforum.com/forum/f22/another-lj-rubicon-thread-1516486/
OkLaHoMaTJ is offline
post #2426 of 2821 Old 12-04-2013, 03:24 PM
Ljcrawler05
When I ordered mine it took a few months but I was in no real hurry... just kinda got frustrated with getting a response of maybe next week. Eventually it came and I must say It was worth the wait. Gerald is a great guy and I know he's busy so it didn't bother me a bit but if they are out of stock the skid could be a while.
As far as a relocating the locker pumps I plan on doing that in the near future when my skid goes on (been sitting in the garage for 6 months) over my college's winter break and putting them under the hood. The rear pump is the only one you have to run a new line for based on a few writeups I've read.
Ljcrawler05 is offline
post #2427 of 2821 Old 12-04-2013, 07:02 PM
ctorres018
1930 JK Wrangler
Better order the savvy MML cuz savvy UA won't work with any other MML.
http://www.jeepforum.com/forum/f22/light-sleeper-2-0-a-1800073/
ctorres018 is offline
post #2428 of 2821 Old 12-04-2013, 07:04 PM
Ljcrawler05
True that^^^ I had to sell my jks I picked up when I realized it wouldn't work
post #2429 of 2821 Old 12-04-2013, 10:36 PM
clg82
I believe that Gerald and the savvy crew is preparing for the King of the hammers competition so try and shoot him an email to see the availability of the skid. He's been really fast at getting back to me so give it a try.
clg82 is offline
post #2430 of 2821 Old 12-07-2013, 06:37 PM
OkLaHoMaTJ
I plan on just running the center skid for now. Not the engine skid which requires the Savvy MML. Correct?
aluminum , belly up , crossmember , high clearance , savvy , savvy under armor , t-case , t-case skid plate , transfer case , transfer case skid , under armor
For the Savvy amongst us mrblaine TJ Wrangler Technical Forum 2765 04-24-2015 06:56 PM
Savvy Corner Armor Install Write-up SuperWade2 TJ Wrangler Technical Forum 36 03-03-2015 06:06 AM
Savvy vs. Rokmen Aluminum Corner Armor eblack TJ Wrangler Technical Forum 47 04-24-2012 01:08 PM
Savvy aluminum armor, what tube flares? pjku79 TJ Wrangler Technical Forum 11 07-12-2010 08:05 AM
Savvy at KOH!! DevilDogDoc Wrangler General Discussion 11 02-13-2010 02:40 PM
