Savvy LJ Test Mule - Page 12 - JeepForum.com
post #166 of 1329 Old 02-17-2010, 12:39 PM
gcally
Originally Posted by ocTJ View Post
lmao so It works just not when you off road it? Awesome!! BUT the good news is at least it's available and it's another excuse for on board Air.
At $600 it is not worth it. The rumor is that savvy has one in the works that is going to cost far less that the ORO kit. I think a lot of jeeps that are daily drivers would benefit from a dual rate sway bar. The only problem is most people including me will not shell out $600 for a sway bar.
gcally is offline
post #167 of 1329 Old 02-17-2010, 12:44 PM
ocTJ
I agree mine is a DD I'm considering just removing the rear sway but I don't know how adverse an impact that will have on the road manners or how much benefit I'll get in articulation...would be nice
"People most often miss opportunity because it is dressed in overalls and disguised as work." Thomas Eddison
2002 Apex Jeep TJ Lifted, Locked, geared and ready for more
ocTJ is offline
post #168 of 1329 Old 02-17-2010, 12:52 PM
06WranglerX
The Anti Rock yes but it's not a true disconnect and depending on how you want the road manners... Not a CURE all. I'm not saying this is a priority to me I just think a simple cheap product would sell well. PS for Imped I had not investigated the swayloc manual disconnects before so that was enlightening. But your right at 700 dollars that's not something i'll be getting either.
To make the question even easier... What suspension parts list is on that LJ!!! and how well do those coils twist? That looks like a pretty Heavy Duty coil is that what comes in your 4" kit? And are you running any sway bar in the rear?
Its not suppose to be a true disconnect the point of having the anti rock is to provide stiffness when climbing rocks and being off chamber, you want the feedback the torsion bar in the cross member provides.
Originally Posted by lumpster View Post
he made it clear when he said he was. He didnt ask for a photo ID of you did he.
People need to be a little more trusting, Its not like we are on a convict and rapist forum.
Upon further reflection I've decided I've had enough of this BS and you are now on my ignore list.
06 Red Wrangler X 6 speed hard top
Ford 8.8 Detroit locked, 4 inches of lift, 33 inch BFG KM2's and some other stuff.
06WranglerX is offline
post #169 of 1329 Old 02-17-2010, 01:40 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Why do you think removing the rear bar will have any benefit?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #170 of 1329 Old 02-17-2010, 01:43 PM
Imped
Imped's Avatar
Why in the world would you not want a rear sway bar? You have coil springs--rear sway bars are good. Remove it--you won't like it.
OlllllllO
IndyORV
Imped is offline
post #171 of 1329 Old 02-17-2010, 01:47 PM
lumpster
lumpster's Avatar
Originally Posted by NotURMailman View Post
Seriously?!...
I put it in the form of an answer on jeopardy. hence the "Alex" for the host of the show.
i know its not the same, but my geo metro doesnt have a rear sway bar, it rusted off. It doesnt corner good at all anymore(not that it did great before). I wouldnt consider taking my rear sway bar off, i would however consider getting a Currie antirock for the rear (of the jeep).
lumpster is offline
post #172 of 1329 Old 02-17-2010, 01:55 PM
ocTJ
am I wrong in thinking the rear sway bar limits articulation of the rear axle?
ocTJ is offline
post #173 of 1329 Old 02-17-2010, 01:59 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Instead of making assumptions, why don't you put the frame on jackstands and remove both tires. Then lower the axle to whatever limits the droop be it trackbar bind, shocks, or swaybar links pulling straight. Then start disconnecting what ever is limiting droop until you find your answer.
I think you'll be surprised to find that the rear bar limits just about nothing except body roll.
I am Savvy
mrblaine is offline
post #174 of 1329 Old 02-17-2010, 02:00 PM
lumpster
lumpster's Avatar
its a pretty thin swaybar, i dont see how it could limit it much. But keep in mind there is a difference in too much flex and usable flex.
lumpster is offline
post #175 of 1329 Old 02-17-2010, 02:00 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
Originally Posted by SuperWade2 View Post
Whats the difference between the CE-9120TJJ and the CE-9120TJS... are these both the "Currie" ones, or the re-badged "JKS" ones?
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #176 of 1329 Old 02-17-2010, 02:02 PM
lumpster
lumpster's Avatar
track bar limits droop in the rear and if it doesnt then the control arms. at least it does with factory trackbar and arms.
lumpster is offline
post #177 of 1329 Old 02-17-2010, 02:23 PM
ocTJ
I was more thinking if I put 1 wheel on a forklift what will limit the other wheel staying on the ground the most.. drop is great but how often are both wheels drooping? (usually your really bum outta luck when both back tires are dropped all the way out)
But thanks for the information hopefully I'll never be too smart to learn something.
soo....the parts list for that suspension?
ocTJ is offline
post #178 of 1329 Old 02-17-2010, 02:56 PM
Mopar Fan
Whats the difference between the CE-9120TJJ and the CE-9120TJS... are these both the "Currie" ones, or the rebadged "JKS" ones?
The CE-9120TJJ comes with a 7/16" housing bolt. The CE-9120TJS retains the stock trackbar housing bolt.
Mopar Fan is offline
post #179 of 1329 Old 02-17-2010, 03:10 PM
SuperWade2
SuperWade2's Avatar
Thanks... since I don't have a stock trackbar, I'm assuming I don't have a stock trackbar bolt.
2017 WK2 Overland
post #180 of 1329 Old 02-17-2010, 03:18 PM
Mopar Fan
You have the RE1600, correct? If so this retains the stock trackbar bolt at the housing, just like the CE-9120TJS.
The CE-9120TJJ requires drilling to accommodate the 7/16" bolt.
savvy , savvy lj , savvy test mule , savvy unlimited
For the Savvy amongst us mrblaine TJ Wrangler Technical Forum 2765 04-24-2015 05:56 PM
Savvy at KOH!! DevilDogDoc Wrangler General Discussion 11 02-13-2010 01:40 PM
Savvy Bumper ksm279 TJ Wrangler Technical Forum 4 02-12-2010 10:15 AM
I'm feeling pretty savvy carsonvogt TJ Wrangler Technical Forum 5 07-25-2009 03:33 PM
YJ buckin like a Mule & my saddle dont fit...HELP! Coolhand1 YJ Wrangler Technical Forum 10 05-05-2007 01:52 PM
