01-07-2012, 10:27 AM
#751
Mall Crawler
Originally Posted by Fuzzcheek1
Could someone with the 4" lift and fox shocks take a measurement of how much shaft length is showing at ride height on the rear shocks? Mine doesn't appear to have a whole lot of up travel and I'm wondering if that's normal.
Could you post a pic?
When someone tries to tell you that nothing is impossible, ask them to dribble a football!
Originally Posted by misterpookie
my best recommendation is keeping a dictionary in the restroom.
word to the wise: dictionary pages are generally thin and not quilted. :nono:
Originally Posted by 1999TJRED85000
Are you on crack?
I think you're a little off. The shell on a turtle is thicker by a factor of 1.6783 while compared to the speed of a Puma, when chasing a rabbit. Therefore, if you hit a nail with a 4 lb. hammer, the thickness of the wood needs to be 4, and your grip should be on your lower regions.
Project "Wrong Way" Jeep build ----> http://www.jeepforum.com/forum/f22/p...g-way-1293197/
Project "Bassakwards" Jeep build----> http://www.jeepforum.com/forum/f22/b...build-1483076/
01-07-2012, 11:25 AM
#752
The picture is in the post
01-07-2012, 12:59 PM
#753
Uncle Buck
I actually had this exact same conversation with Gerald. The bumpstops included with the kit might not be the correct length to use. You need to cycle the suspension with the springs removed to make sure your bumpstop length is right.
Indeed. I'm going to put a 3/8" metal disk under the rear bumpstops, and maybe 1/4" disk under the front bumpstops, and I think that will be perfect for mine. Right now they measure just about identical (with the fronts being a little closer), but I know with some heavy loads hitting the bumpstops they will compress a little bit, so I'm gonna give a little extra bumpstop.
01-07-2012, 01:57 PM
#754
Cheese
Thanks for the picture! I'll post up a picture of mine when I get home, but it's certainly under 3" of travel.
01-07-2012, 04:26 PM
#755
Cheese
Something has to be wrong with mine. Maybe I have the wrong springs or the wrong shocks.
01-07-2012, 04:31 PM
#756
TJ Truck?
That's not good at all.
01-07-2012, 04:34 PM
#757
If you are at ride hieght there and it has the right amount of lift then those must be the wrong shocks...
"Betsy" 2005 Unlimited Rubicon Sahara Edition #603 of 1000
Originally Posted by Necromancer_tat
I like having my panties in a wad though, because when I get DW they rub me in just the right way! :D Wadded panties plus DW equals Jeepgasm! :D :kiss:
01-07-2012, 04:38 PM
#758
Cheese
I just measured between the top of the spring to the bottom of the spring and it looks like I'm about 10 3/4 inches. So that would be approximately 2 3/4 inches of lift.
Could that be because of my hard top and tire carrier?
01-07-2012, 04:40 PM
#759
You could easily lose 1/4" of advertised lift to weight in your rig, but the shock body looks way too long on your photo. Even with losing that little bit of lift you should still have travel available... double check your shock part numbers.
01-07-2012, 04:43 PM
#760
Cheese
I'm supposed to have the 4" kit though.
01-07-2012, 05:03 PM
#762
Well, that kinda sucks. I went with my specific set up on Gerald's recommendation.
01-07-2012, 05:08 PM
#763
Cheese
Me too! This the 4" savvy/currie, and the fox shocks right from their website. I only posted the link to quadratec because that's what came up when I googled the part number.
01-07-2012, 05:11 PM
#764
wow 2" of uptravel...something isn't right
01-07-2012, 05:16 PM
#765
Even if you had 4" springs it wouldn't make up the 3" I have on you (nothing personal 😃  . Something has to be installed wrong or those are super long shocks!
