Savvy/Currie 3" TJ/LJ Suspension Lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Savvy/Currie 3" TJ/LJ Suspension Lift
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 04-13-2011, 11:10 AM   #1
Savvy
Savvy Off Road
Savvy's Avatar
IN STOCK! Optional aluminum uppers in stock! Can be configured with 3 or 4" springs!
The new Savvy/Currie 3" or 4" TJ/LJ Lift was introduce at Moab during 2011 Easter Jeep Safari. It performed very good! The 3" kit is a true 3"lift height.
The Savvy/Currie 3" or 4" TJ/LJ Lift kit will include:
Savvy Specified Currie 3" or 4" Progressive Springs
Savvy Specified Currie fully adjustable Upper Control Arms (more length and JJ on both ends in the rear and aluminum arms are optional)
Currie Lower Control Arms (optional aluminum arms)
Savvy Designed Rear Track Bar w/ housing extension (more clearance and better articulation)
Currie Anti Rock
Currie Extended Rear Sway Bar Links
Currie Bump stops
Optional Aluminum arms!
Pricing is close to the current Currie 4" lift and we will be the only ones offering this kit. It is in stock!
Email me for the fastest response: gman@savvyoffroad.com
Like us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
http://www.savvyoffroad.com
Savvy Spartan 2004 LJ
2012 JKU Test Mule
2006 LJ Unlimited Black Hole
2005 LJ Test Mule
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote
Unread 04-13-2011, 11:16 AM   #2
Savvy
Savvy Off Road
Savvy's Avatar
We are currently working on the shock specifications for this lift as we would like to maintain the travel we currently have. We are looking at some shorter body shocks with close to the travel we currently have with the Ranchos or Bilsteins.
2012 JKU Test Mule
2005 LJ Test Mule
Unread 04-13-2011, 11:18 AM   #3
hustler905
Will the "Savvy Spec" UCA's and rear track bar, or other components be available separately?
hustler905 is offline   Reply With Quote
Unread 04-13-2011, 11:21 AM   #4
Savvy
Savvy Off Road
Savvy's Avatar
Yes, the new arms and rear track bar will be stand alone products.
2012 JKU Test Mule
2005 LJ Test Mule
Unread 04-13-2011, 11:28 AM   #5
0blcktj6
The Savvy UA has been described as being desinged for predominant use with the Currie 4" kit and that lower lifts may experience some contact between the engine brace and control arm mount. Will your 3" kit mean a redisign for the engine brace or is that not low enough to cause any possible issues?
3" Currie progressives, OME Shocks, 1" BL, 1" MML, 35x12.50" KM2's, 4.88's, Detroit in rear, Vanco BBK, Currie CA's
My Build Thread:
http://www.jeepforum.com/forum/f22/v...ck-now-908246/
0blcktj6 is offline   Reply With Quote
Unread 04-13-2011, 11:29 AM   #6
Melissas6570
Its about time you did this. LOL
I DO IT WITH MY TOP OFF!
Melissas6570 is offline   Reply With Quote
Unread 04-13-2011, 11:33 AM   #7
Savvy
Savvy Off Road
Savvy's Avatar
I know!
2012 JKU Test Mule
2005 LJ Test Mule
Unread 04-13-2011, 11:34 AM   #8
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
uh oh! yall might be called a LCG lift now!
tell me a bit more about the bumpstops and what shocks you're going to run...how much uptravel are you expecting vs the 4" or a 2.5" OME? whats the bumpstop requirement going to be? what are you doing for the front track bar?
speaking of track bars, uptravel & LCG...when is somebody going to design a nice adjustable front track bar that clears most diff covers at full stock bump...hint hint. double shear would be swell
Unlimited04 is offline   Reply With Quote
Unread 04-13-2011, 11:35 AM   #9
Savvy
Savvy Off Road
Savvy's Avatar
We are looking into the contact and are considering a running change on our engine brace. We have seen it in a couple of stock height Jeeps so we are looking into it.
2012 JKU Test Mule
2005 LJ Test Mule
Unread 04-13-2011, 11:36 AM   #10
0blcktj6
Good stuff, thanks.
My Build Thread:
Unread 04-13-2011, 11:38 AM   #11
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
I can't imagine a better combination for a suspension lift, Currie's quality and Savvy's enhancements. As said above, it's about time!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Unread 04-13-2011, 11:43 AM   #12
Savvy
Savvy Off Road
Savvy's Avatar
A 3" lift can hardly be LCG!
Currently working with a shock manufacturer to provide shocks for this kit.
The 9120TJS front track bar works for most diff covers and we aren't tackling that one yet.
As for bump stops, we can't go much farther up so we want to increase the lower to maintain travel. Currie bump stop kit has some room for height adjustments.
2012 JKU Test Mule
2005 LJ Test Mule
Unread 04-13-2011, 11:45 AM   #13
Savvy
Savvy Off Road
Savvy's Avatar
You know the saying. "All good things come to those who wait."
I hope you're doing well.
2012 JKU Test Mule
2005 LJ Test Mule
Unread 04-13-2011, 11:48 AM   #14
Moto4x4
wow maybe that 2" BDS kit wont be on as long as i thought
Moto4x4 is offline   Reply With Quote
Unread 04-13-2011, 11:50 AM   #15
chmo
if
1. the front track bar to diff clearance is maximised similar to stock.
2. if the bump stops are minimised/shocks with shorter body/uptravel maximised
then THIS would be something to ditch my OME lift for !!!
I was looking at the currie control arms and springs for a long time now ... long enough then
chmo is offline   Reply With Quote
