Savvy Corners with PSC Rear Stinger - JeepForum.com
post #1 of 11 Old 05-19-2011, 04:19 AM Thread Starter
nibblesupreme
Howdy,
Is anyone running this setup [Savvy Corners with PSC Rear Stinger]? I'm seriously considering it, but I'm wondering if I'll have to drill holes into the Savvy Corners to connect the Stinger, or if the existing holes match up like they do on the PSC Corners..
I can't be talked out of the Stinger, even though the shipping is ridiculous and there's arguments that it is useless... I LOVES how it folds down, and it looks bada$$.
So anyone freak with this? Thank in advance.
~Nibbles
nibblesupreme is offline
post #2 of 11 Old 05-19-2011, 05:24 AM
goody6691
i have rockmen corners and my stinger should be on the way soon. so what if you have to drill a few holes. it will all be worth it in the end
o3 tj, yellow, currie 4 in,savvy arms, 1in bl, mml, ramsey 9500, synth line, 8.8, 456's, arb's. 35x12.5x17 mtrk's, 17x8.5 raceline beadlocks, aem, banks exhaust, psc rear stinger, no limits front stinger, rockmen corners, a-z cage, piaa lights, rampage softtop, anti-rock, AA shifter, UCF aluminum skid.........98 audi a4, fully built, 350 whp awd, yellow
goody6691 is offline
post #3 of 11 Old 05-19-2011, 06:09 AM Thread Starter
nibblesupreme
I guess it would be different if I could see the products.. (or the Jeep for that matter), so I'm trying to make an educated decision regarding the whole stinger, corner sitch.. do you already know how you'll install the stinger? I'm wondering if I should stand down on installing bedliner until all that stuff (stinger, corners).
post #4 of 11 Old 05-19-2011, 08:27 AM Thread Starter
nibblesupreme
What's the standard time limit until you continuously bump until you get everyone's attention?
post #5 of 11 Old 05-19-2011, 08:27 AM
Garza
You will have to drill extra holes into the Savvy corners. I would definitely wait until you had all the products you want to install so you can see how they will work together or have to be modified. As far as the bedliner.....whats the worst you have to do drill a couple of holes through it? Also you will not be able to run the Savvy rub rails if you wanted to....just a heads up.
RG
Garza is offline
post #6 of 11 Old 05-19-2011, 08:42 AM Thread Starter
nibblesupreme
Thanks! I was actually thinking about going with the UPol, and I think if I drilled though it and messed it up, I could just re-apply. Now what about Savvy rub rails? I did my homework, never heard of these...
post #7 of 11 Old 05-19-2011, 08:50 AM Thread Starter
nibblesupreme
Oh! No. Not into those. Thanks for the heads up though.
post #8 of 11 Old 05-19-2011, 07:38 PM
fsSnowboard
you'll probably have to drill holes in the Savvy corners
My Build -> http://www.jeepforum.com/forum/f22/fssnowboards-2005-tj-x-1133763/
fsSnowboard is offline
post #9 of 11 Old 04-26-2012, 02:13 PM Thread Starter
nibblesupreme
How did this end up working out for you? I never ended up getting the savvy corners, now I'm looking at the rokmen, like you have.
post #10 of 11 Old 04-26-2012, 03:55 PM
goody6691
i still had to drill holes, whats a few more? i meen you have to drill to install the armor anyway. just do it. get a swag tailgate conversion while your at it, that way you can still crack the tailgate open to take the top down and not have to drop the stinger.
post #11 of 11 Old 04-27-2012, 07:23 AM Thread Starter
nibblesupreme
Thanks bro. I think I will! Did you have to modify anything because of the corners?
Pics?
What to use for sealant on savvy corners? EdinMN TJ Wrangler Technical Forum 1 03-09-2011 07:03 AM
Savvy rear receiver bumper rouxbicon TJ Wrangler Technical Forum 34 01-17-2011 06:27 AM
Savvy Rear Bumper Install jermeyg TJ Wrangler Technical Forum 5 11-27-2010 09:53 PM
Savvy Sliders and Corners - Trail Tested Niceface TJ Wrangler Technical Forum 0 10-19-2010 11:49 AM
PSC Crusher Corners, Rocker Knockers, and trail stinger Zacb262 TJ Wrangler Technical Forum 30 12-30-2009 01:13 PM
