For the Savvy amongst us - Page 185 - JeepForum.com
post #2761 of 2766 Old 02-23-2011, 09:39 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Originally Posted by bandit455 View Post
i had this issue and i actually found that the gasket had not seated properly between the tank and pump.
i found this out while on the trail with a full tank of gas, fuel went everywhere, very scary.
This happened to me. I had the same fix. But I did get a CEL with a code for vacuum leak.
Group W Bench
CRAWLING 98 is offline
post #2762 of 2766 Old 03-12-2011, 08:36 AM
Yellow TJ
<--------is now savvy!
and its official, i win my bet (god i love my wife), so I will be looking forward to the 97-03 underarmor for 5speed
Yellow TJ is offline
post #2763 of 2766 Old 04-07-2011, 10:22 AM
hustler905
Originally Posted by Savvy View Post
I'm thinking vent tube not snapped all the way on. Are you getting any codes? If not, don't touch the lines as it can create more problems. If you are getting codes, then a vent line is not on or cracked.
For the benefit of the other GTS users, I fixed my vent issue. The T that connects the evap lines had a split in it. If you're suspecting an issue, check the obvious stuff first.
Thanks for the push in the right direction Gerald.
hustler905 is offline
post #2764 of 2766 Old 04-07-2011, 03:22 PM
MountainMan864
Updates on the tire carrier by chance Savvyman?
MountainMan864 is offline
post #2765 of 2766 Old 05-06-2011, 03:18 AM
inglisleslie
x2, and front sway bar
/l ,[ ______],
l---l_--OllllllllO- My BUILD Thread----> http://www.jeepforum.com/forum/f22/white-l-cog-1074040/index10.html
()_) ()_)--O-)_)
inglisleslie is offline
post #2766 of 2766 Old 04-24-2015, 05:56 PM
97Heep
Finished installing my Savvy GTS :-) I couldn't be happier with the fit, look, and additional clearance. Also got my LED tail lights all wired up and working :-D
'97 Jeep Wrangler Sport TJ 4.25" lift 33x10.5x15 KM2's (Sold)
'04 Jeep Wrangler Rubicon TJ - She's Savvy
97Heep is offline
aluminum , bumper , fairlead , front bumper , savvy , savvy front bumper , winch bumper
Savvy Tub Rub Rails **** Spy Photos **** Savvy TJ Wrangler Technical Forum 167 05-02-2013 10:16 AM
Savvy at KOH!! DevilDogDoc Wrangler General Discussion 11 02-13-2010 01:40 PM
Savvy Bumper ksm279 TJ Wrangler Technical Forum 4 02-12-2010 10:15 AM
Savvy Offroad LED tailights fratis YJ Wrangler Technical Forum 2 07-16-2009 01:36 AM
Savvy LED Tail Lights Savvy TJ Wrangler Technical Forum 1 06-25-2009 09:26 PM
