Savvy aluminum armor, what tube flares? - JeepForum.com
post #1 of 12 Old 12-18-2009, 01:08 PM Thread Starter
pjku79
I have been looking at armor for a little while and am thinking about going with Savvy's aluminum corners. My concern is that since they are aluminum I will not be able to weld on most rear tube flares. What suggestions do you guys have? I am looking at least 4.5 probably more like 6" flares so they match my fronts. I guess they would have to be bolt on steel ones or aluminum ones (if I wanted to weld them).
97 TJ, d44 arb locked, 2.5" bds lift, 35" tires, JKS adjustable control arms
pjku79 is offline
post #2 of 12 Old 12-18-2009, 02:55 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I neither condone, nor understand the value of a steel welded on flare that unforgiveably increases the width of your vehicle on the trails.
When I get some spare R&D time, I will build a bolt on aluminum flare that can be removed for the trails if you're in danger of damaging them.
Besides, there's nary a thing wrong with putting the factory flares right back on over the aluminum armor. At least you won't be denting the tube with them when you drag them across the rocks.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 12 Old 12-18-2009, 03:26 PM Thread Starter
pjku79
I agree, I am looking for something that I would likely take off while on the trail. I actually regret making my front so large, but it was my first go at it. I have stuck them into a few rocks.
If aluminum flares were available that would be my best option (depending on cost). They wouldn't even have to be that sturdy since they wouldn't be trail flares.
pjku79 is offline
post #4 of 12 Old 12-18-2009, 03:49 PM
dabprice
This is a kit to make stock flares quickly removable. Click on "Expedition Flare Kit".
Rocodile Off Road
dabprice is offline
post #5 of 12 Old 12-18-2009, 04:11 PM Thread Starter
pjku79
I just found these which might be a good option. They are steel, but can quickly be taken off while on the trail and would still look similar to my front flares.
MetalCloak, home of the Arched Jeep TJ / LJ / YJ Tube Fender.
They are on sale for $224.
pjku79 is offline
post #6 of 12 Old 07-11-2010, 01:06 PM
bobbyp10
pjku79 sugst. is whats up those are really nice
bobbyp10 is offline
post #7 of 12 Old 07-11-2010, 01:09 PM
ZeroGravity
Has anyone ever tried using Velcro to attach their flares?
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #8 of 12 Old 07-11-2010, 01:11 PM
Apex
Recon death squad
Apex's Avatar
Speaking of flares on Savvy corner armor...
Today I went outside to wash the Jeep and noticed my stock flare was peeled away from my Savvy corner a touch. Now I knew I crushed the flare into a rock (hooray for stock plastic flares) and that it and the corner took some rash...what I didn't realize is that my stock flares tore out the screws and nutserts that hold them in in the process.
Can anyone tell me what might have happened had these flares been metal and welded on? Yea, not good...
I'm now flareless since the stock nutserts pulled out and it was useless to put them back on with only half the screws in.
Apex is offline
post #9 of 12 Old 07-11-2010, 01:21 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Is it okay if I just show you?
I am Savvy
mrblaine is offline
post #10 of 12 Old 07-11-2010, 01:30 PM
Apex
Recon death squad
Apex's Avatar
Great visual...exactly why I went with a corner without a permanently attatched flare.
Apex is offline
post #11 of 12 Old 07-11-2010, 01:36 PM
DBLJ
DBLJ's Avatar
Except you need about $700 in other parts to mount those.
DBLJ is offline
post #12 of 12 Old 07-12-2010, 07:05 AM Thread Starter
pjku79
nah just a few bolts
pjku79 is offline
Savvy vs. Rokmen Aluminum Corner Armor eblack TJ Wrangler Technical Forum 47 04-24-2012 12:08 PM
Aluminum vs Steel Armor? TJoshX TJ Wrangler Technical Forum 14 07-11-2010 02:08 PM
Aluminum corner armor? czjeeper YJ Wrangler Technical Forum 12 10-15-2009 08:41 AM
Savvy offroad aluminum gas tank skid plate mustgooverit TJ Wrangler Technical Forum 0 08-26-2009 11:48 PM
Savvy Aluminum Skid Before / After Kilby robncar TJ Wrangler Technical Forum 242 06-16-2009 10:09 PM
