Saving up for a lift. Suggestions? - Page 4 - JeepForum.com
post #46 of 56 Old 10-20-2012, 04:54 PM
Imped
Imped's Avatar
Originally Posted by Jeffro06 View Post
I went with the Old Man Emu HD 2" lift, and ran 32's without a problem, on stock control arms, steering and drive shafts. I did add the Currie Antirock front sway bar at the same time as the lift. It's a very good lift, ride quality is great, despite it not being Currie. I have since added Rokmen control arms, but it wasn't because I needed them, it was because I wanted them....again, not Currie.
Quit being silly Jeff...you have Currie parts where it matters. OME 2.5" springs are well known to kick ***.
OlllllllO
IndyORV
Imped is offline
post #47 of 56 Old 10-21-2012, 06:26 AM Thread Starter
Stickzz
Liking the fact that everyone says that about OME, lol.
Stickzz is offline
post #48 of 56 Old 10-21-2012, 07:03 AM
dgi
I've been planning on doing a lift to my TJ for quite some time... other projects and interestes have always gotten in the way. I've always planned on going with OME from DPG since its all I need. Since i've made my choice on kit, other companies (Currie) have come out with arguably better kits, but my needs are still the same. Should I pay more for a "better" kit that does more than I need? Or just save my $$$ and put it in other areas that I need... I'll be ordering from Dirk when the time is right.
dgi is offline
post #49 of 56 Old 10-21-2012, 08:23 AM
4wdjeepguy
Just run Currie links and throw the OME coils in there. Worth every penny.
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
4wdjeepguy is offline
post #50 of 56 Old 10-21-2012, 09:50 AM
Jeffro06
Jeffro06's Avatar
I do have Currie steering components, that's true. But my suspension is Rokmen and OME, except for the Antirock.
As much as I like Currie, I won't say it's them or nothing, when it comes to suspension components.
Jeffro06 is offline
post #51 of 56 Old 10-21-2012, 11:27 AM
4wdjeepguy
Rokmen aka Currie
IG: CS_OFFROAD
YOUTUBE: CS OFFROAD
post #52 of 56 Old 10-21-2012, 11:38 AM
GMBNT42
Originally Posted by unlrubicon05 View Post
Rokmen aka Currie
Don't the specific Currie mfg'd control arms have one big flaw in them being not being able to adjust short or long enough? I thought I read somewhere that they have an issue with that, when needing to dial in the axle pinion angle.......maybe someone could clarify?
GMBNT42 is offline
post #53 of 56 Old 10-21-2012, 11:49 AM
Imped
Imped's Avatar
Dude, you have JJ's....you have Currie parts where it matters. You won't find anyone saying that the actual Currie arms are superior to Rokmen arms. They're identical where it matters except that Rokmen uses thicker tubing.
OlllllllO
IndyORV
Imped is offline
post #54 of 56 Old 10-21-2012, 12:02 PM
Jeffro06
Jeffro06's Avatar
Technicalities...
Jeffro06 is offline
post #55 of 56 Old 10-21-2012, 12:44 PM
biffgnar
biffgnar's Avatar
You've been reading old posts. A couple years since they addressed that.
Romney in 2020!
biffgnar is online now
post #56 of 56 Old 10-21-2012, 12:48 PM
GMBNT42
Ah, OK, gotcha.......so the current Currie branded arms are fine and fully adjust like all the other top tier brands then. Good to know.
GMBNT42 is offline
lift , tj
