Saving up for a lift. Suggestions? - JeepForum.com
post #1 of 56 Old 10-17-2012, 07:55 PM Thread Starter
Stickzz
So, I'm saving up for a nice lift on my '03 TJ. Read good things about Old Man Emu and Rubicon Express. RE seems a little expensive, OME seems like a nice choice.
Current Specs:
Tire/Wheel -29 x 9.5 R15
Axle - Dana 44 / 3.73 Ratio
Trans - 5 Speed (fyi -shrug-)
Wanting -
Tires - 32s or 33s (suggestions?)
Lift - Suspension, 2-3" (suggestions/tips?)
Able to have the 32/33s a good look while being functional.
Don't want a body lift.
I'm going to be doing some offroading, but nothing extreme. It's my daily driver, use it on highways (55mph). Also live in PA, so I'll be dealing with some snow if it matters. Max budget is $1k.
Friend is going to be teaching me how to install it, he's lifted 2 YJs, but I thought I'd get the forums view.
If you guys need more info from me, feel free to ask.
Stickzz is offline
post #2 of 56 Old 10-17-2012, 08:19 PM
Davf24
Current Specs:
Wanting -
I would suggest that when you get the lift make sure it comes with new lower four links the stock ones get very noisy and lose
Davf24 is offline
post #3 of 56 Old 10-17-2012, 08:24 PM
austeezy
Metal Cloaks. Or some kind of tube fenders. They look awesome, you'll easily clear 33's, and you won't have to deal with all the issues that come w/ a lift. Cloaks will be my next mod but I wish I would've started w/ them instead.
2004 Khaki LJ
3.25" Suspension 1" BL
33" Falken Rocky Mts
austeezy is offline
post #4 of 56 Old 10-17-2012, 08:35 PM Thread Starter
Stickzz
Sorry, a bit new to to Jeeps (mechanics in general, lol). I don't know what part you're talking about, will it be listed in the parts of the lift, are they cheap/easy to find/buy?
Stickzz is offline
post #5 of 56 Old 10-17-2012, 09:01 PM
Davf24
some lifts will include them, they are the lower links, when you look under your jeep they are the bars that connect from the frame to the axel (there are two top and two bottom per axel). I did a 3" lift and that did not come with new links and mine are lose and make lots of noise, I have also seen stock links fail. The key thing to do is figure out what kind of wheeling you plan on doing, do you want to go every weekend, once a month, what kind of wheeling will you be dong, lots of rocks, mud sand dirt trails combo of all. start small and figure out what you like to do then build your rig, I would keep it stock or start with a 2" easy lift add 31x10.5x15 A/T's or Mud tires that way you can get a sense of what type of wheeling you want to do, then built your dream rig.
Davf24 is offline
post #6 of 56 Old 10-17-2012, 09:31 PM
Bills03tj
1992 XJ Cherokee
I did the Zone 3" lift and I'm very, very happy with it. Mine rides better than stock and it does very well off road. The people at Zone were very helpful when I had questions. They are an advertiser here and I would recommend checking out the feedback here also. The kit I got is very affordable and I did add their sway bar disconnects.
Bills03tj is offline
post #7 of 56 Old 10-18-2012, 10:37 AM Thread Starter
Stickzz
Really can't find what item you mean. Is it also known as a stabilizer or control arm? Or is it, for example, part of the Rubicon Express kit with "Tri-Link"?
Stickzz is offline
post #8 of 56 Old 10-18-2012, 10:42 AM
TexasTJ
No Longer DD
TexasTJ's Avatar
I've heard nothing but good things about the Zone 4.25" kit (3" SL 1.25" BL and 1"MML). Why don't you want a body lift? I'll be getting the 4.25" kit in a few weeks hopefully, or you could just order the 3" SL from Zone Offroad for $459.99 http://zoneoffroad.com/prod-display?ca=1&ma=6&mo=56
May TJ of the Month 2015
TexasTJ is offline
post #9 of 56 Old 10-18-2012, 10:48 AM Thread Starter
Stickzz
I've heard of mixed feelings about body lift, I don't think i'll need that BL with a 3" suspension/ Don't want to go too big for fear of death-wobble on the highway.
Edit: Does that kit include lower four links that Davf was talking about?
Stickzz is offline
post #10 of 56 Old 10-18-2012, 10:58 AM
ctorres018
1930 JK Wrangler
Why would you think you can get a death wobble with a lift over 3inch?
ctorres018 is offline
post #11 of 56 Old 10-18-2012, 11:01 AM Thread Starter
Stickzz
Not really sure, lol, it was my understanding that after 4" or so it happens at high speeds.
Stickzz is offline
post #12 of 56 Old 10-18-2012, 11:11 AM
rchase559
Not at all
rchase559 is offline
post #13 of 56 Old 10-18-2012, 11:17 AM Thread Starter
Stickzz
Originally Posted by rchase559 View Post
Not at all
Hmm...
Stickzz is offline
post #14 of 56 Old 10-18-2012, 11:17 AM
rda616
There is plenty of misinformation here already. Here are some suggestions. Call dpg and order an ome kit, add a 1.25" body lift and 1" motor mount lift. There is nothing wrong with a small body lift, it's when you get over the 1.25" mark problems seem to persist . If your factory lower control arms aren't wore out then don't bother change them until you can afford to buy a set with johnny joints at both ends. The cheap arms offered in kits like zone offer use polyurethane bushings in a tube design that doesn't flex and puts unnecessary stress on mounts causing them to crack, or even fail completely.
rda616 is offline
post #15 of 56 Old 10-18-2012, 11:22 AM Thread Starter
Stickzz
http://dpgoffroad.com/products/old-m...-wrangler-kit/ -- Correct? This is the kit I've seen. (but this is on the DPG site)
Mind me asking why you prefer DPG?
Edit: Also why would I need motor mounts?
Stickzz is offline
lift , tj
