Sanity check:Low Center of Gravity Build Plan - Page 4 - JeepForum.com
post #46 of 57 Old 07-22-2010, 10:26 AM Thread Starter
UncleWilson
UncleWilson's Avatar
Did you completely miss post #11?
no, you're wrong. the JKS bar (#126) doesn't clear the stock cover either with N66 shocks...needs 2" of bumpstop IIRC.
How about if I add a Riddler Diff Covers? I really don't know anything about it other than it's stronger that stock.
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #47 of 57 Old 07-22-2010, 10:55 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the stock cover is the lowest profile available.
the riddler cover requires ~3.5" bumpstop extension with the #126 track bar. in other words, it hits on the street with normal pot holes, speed bumps and regular road features.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #48 of 57 Old 07-22-2010, 11:11 AM Thread Starter
UncleWilson
Hmm. Does the curried TB give more clearance? I assume yes but still not ideal.
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #49 of 57 Old 07-22-2010, 11:53 AM
Unlimited04
somewhat...the Currie "TJS" TB still needs 2" bumpstops to clear the stock diff cover.
the best combo for a 2.5" lift with 13" collapsed length shocks is one of the following:
1. Crane or Barnett diff cover + stock track bar (drill a new hole & weld reinforcement to bracket)
2. Barnett diff cover, Currie TJS track bar + 2" bumpstop extensions
#2 limits uptravel some, but would allow the use of 15" collapsed length shocks, like OME N66L...which gets a bit more droop out of the front end.
Useful Write-Ups:
Funny:
post #50 of 57 Old 07-22-2010, 01:02 PM
pdangerp
pdangerp's Avatar
Or you could try just a diff cover shield for the bottom portion of the d30.
pdangerp is offline
post #51 of 57 Old 08-20-2010, 11:50 AM Thread Starter
UncleWilson
Well I still haven't figure out what size suspension lif to go with, BUT I have made some progress.
Went to UCF and got the Ultra High Clearance TT with the Lo-Pro rubber transmission mount along with a JKS 1" BL/MML. The BL/MML went in just fine and was pretty simple, just make sure you have vice grips for the MML.
The UCF engine and T-case skid look sweet. Along with the Lo-Pro mount I'm excited to get it installed, but one down side to this setup is the UCF skids require a few modifications to the stock parts and to the UCF t-case skid to get the engine skid mounted. But I'm Stoked!!
Future ideas are still 2.5" OME or 4" Currie and will be going with 35" tires. Also, when $$$ going with Savvy Tank skid.
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #52 of 57 Old 08-25-2010, 11:36 AM Thread Starter
UncleWilson
Lets say i go with #2 (mostly) - Stock Cover, Currie CE-9120 TB, 2" Bumpstop extension in front, OME 2.5" HD but with N66L shocks.
Will I be forced to change Rear TB or Steering right away? I plan on doing them but not willing to shell out $$$ all at one time
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #53 of 57 Old 08-25-2010, 11:43 AM
ekim
Shocks of this length will require extended brake lines too.
ekim is offline
post #54 of 57 Old 08-25-2010, 03:08 PM
chmo
OME 2.5 HD springs might very likely unseat under full droop with N66L shocks!
Rear TB change not neccessary at all with TB relocation bracket. The bracket is actually recommended for rear full droop situations as well, because stock mount prone to bind under full droop in the rear ... might get bent/ripped off the axle!
Steering upgrade recommended for HEAVY tires >=33" ... 31-32" I donno ... should be OK.
chmo is offline
post #55 of 57 Old 08-25-2010, 03:28 PM
Unlimited04
the Currie "TJS" track bar is the one you want. their other version is nothing more than JKS under a different name. the track bar and N66L requires 2" bumpstop extensions in front...just make sure you got that. you're loosing some uptravel vs stock TB + N66, but you'll gain a lot of downtravel.
rear TB is up to you...do you want the axle centered perfectly? I did. the OME bracket places more stress on the stock mount...but the JKS TB by itself places stress on the mount too. you ultimately need to weld some reinforcement on, or better yet - replace the entire bracket.
stock tie-rod will get you around...but its pretty thin/weak/flemsy. the ZJ V8 tie-rod is an easy, cheap upgrade if you don't want to drop the coin for a Currie steering system.
Yup they will. YJ front lines work good, and cheap.
they do, but just barely. still very usable.
the bracket creates a larger lever arm...which eventually rips the stock bracket off the alxe too. pick your poison - either way you need to fabricate reinforcement for the bracket.
the stock tie-rod sucks. upgrading to a ZJ V8 tie-rod is stupid easy, cheap and simple. no reason not to
Useful Write-Ups:
Funny:
post #56 of 57 Old 08-25-2010, 03:57 PM
madmilitia
I live in MI, but travel to MN where they require full tire width coverage. So I think as long as I could flare it wide enough I'm good. I'm really only there for 2 weeks out of the year but don't need the attention from the fuzz.
good news MN doesn't require full tire width coverage, i was born and raised in MN.
drove my jeep with stock flares and 31x10.5 's had 4 inchs of tire out and never once got in any trouble.
i was worried about the same thing so i asked a cop and he said 50% needs to be covered, and then said but rarely will anyone get pulled over for that unless they are spraing mud all over on purpose.
RJC #600
colorado jeep club #269
Don't grammer cop me, if you can't understand what i'm trying to say it's you not me that needs to change.
madmilitia is offline
post #57 of 57 Old 10-19-2010, 08:52 AM Thread Starter
UncleWilson
Sorry I've been MIA. Thank is awesome to know. I really don't need something stupid like that to taint the build.
o[__Q_]o
(OIIIIIO)
[]==O==[]
build , lcog , ome , rokmen , TJ
35" tires - low center of gravity tj bpnielson TJ Wrangler Technical Forum 45 08-04-2010 10:22 AM
Lowering Center of Gravity bigblackblur TJ Wrangler Technical Forum 28 09-07-2009 01:52 PM
center of gravity JeepMKcomin TJ Wrangler Technical Forum 7 08-22-2006 08:23 PM
2" BB-Increased Center of Gravity idgit0488 TJ Wrangler Technical Forum 14 02-14-2006 06:41 AM
Low Center of gravity phattdraggon YJ Wrangler Technical Forum 21 03-31-2005 04:53 PM
