Sanity check:Low Center of Gravity Build Plan - Page 2 - JeepForum.com
post #16 of 57 Old 07-21-2010, 07:18 AM Thread Starter
UncleWilson
UncleWilson's Avatar
Originally Posted by freeskier93 View Post
Tube fenders are a good idea. Metalcloak makes insanely awesome fenders that give you the most clearance you can get without trimming. They are pricey, but they are fully bolt on, come with inner wells and mounting hardware for the battery and intake. Plus you can sell you old fenders for some dough.
Once this becomes a dedicated offroad vehicle i will move to the tube fenders. However until then i travel in and out of states that have those stupid fender laws
2006 LJ Rubi JKS BL/MML, Curries Arms, 3", UCF Skids, Riddler, 35 GY MTR W/K, Black Rock 909's, Black Magic, Rokmen Sliders, Savvy GTS, Cloaked, 4.88
o[__Q_]o
(OIIIIIO)
[]==O==[]
UncleWilson is offline
post #17 of 57 Old 07-21-2010, 08:18 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by UncleWilson View Post
Okay, I'll switch my TB plan to the Currie TB
add 2" bumpstop extensions up front with that to keep the TB off the diff cover. that will also allow you to run N66L front shocks instead of the N66's.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #18 of 57 Old 07-21-2010, 01:27 PM
rs4race
If your set on getting an adjustable trackbar then wait until you install it and then see if it hits. I recently have seen a similar setup not hit the trackbar. 2.5" ome lift, jks trackbar, no diff to trackbar hitting. I would however go with the currier or jks as it seems to have the most clearance out of all of the adjustable track bars.
If you stick with the stock trackbar and 2.5" lift you should only be off about .25" which if you go to bigger tires later on will be better. On 35's and 2.5" lift there is nothing really on the passenger side to rub, but driver side you will rub on the steering box bolts. having it offset .25" will help on the drivers side.
Myself personally I dont want to raise mine higher than 2.5" of total lift, but if I was willing to do 3.5 I piece it together. I think 2.5" springs, 1" body lift, relocated shock mounts with 10-12" shocks, outboard the rear shocks, of course get the adjustable arms on there if you want them too.
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #19 of 57 Old 07-21-2010, 01:51 PM
ROLLTIDEtj
In the picture is a link to a set up currie short arms with JJ's. The two arms in the top left corner are the front upper arms and notice how it has the bracket on one end instead of a JJ. This is because of the type of stock mount on the front axle.
Currie Enterprises CJ Axle Parts
In order to have a JJ one each end of the front upper CA you need to buy this kit from currie. You basically cut the top half of the axle bracket off, and this sits down inside and is welded to the bracket. Currie Enterprises CJ Axle Parts
Scroll down the the 7th picture in this thread and you can see the above kit installed on the new axle and the old bracket and rubber bushing on the old axle.
http://www.jeepforum.com/forum/f9/lo...0-swap-694533/
Thanks for the kind words!
2004 Rubicon - 4.0 - 5 speed manual - Rough Country 4" Stage II lift, RC front adjustable track bar, 2.2 shocks, 33x12.5x15 Goodyear MTR with Kevlar on Crager soft 8's, 4 Hella Black Magics, Edge Trail Jammer with Intake, JL TR 2-ways in the pods, Kenwood Excelon deck in the dash, Rough Country Stinger & Winch Plate, Trail Gear rear bumper w/ tire carrier, HiLift, Rock Krawler X Factor Plus Steering
ROLLTIDEtj is offline
post #20 of 57 Old 07-21-2010, 02:15 PM Thread Starter
UncleWilson
Okay I was confused by your statment earlier then. I knew about the axle mounts but got confused an thought you said the body mount brackets wouldn't accept the JJ's. In the end, I think i've got it and I'd rather ask and get the correct answer, than not and be EFed
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #21 of 57 Old 07-21-2010, 02:30 PM
pdangerp
pdangerp's Avatar
why are you looking into a trackbar bracket and an adjustable trackbar in the rear?
pdangerp is offline
post #22 of 57 Old 07-21-2010, 05:02 PM
solarpower
You want a plan?? Here is a plan..
Get all your armor, springs, shocks and tires.
Put it all on and see what you get for clearance and rubbing on the factory control arms, track bar, fenders etc. etc.
The factory arms will flex and twist better than just about any johnny joint. The binding caused by just about every aftermarket control arm will possibly break the bracket on the axle..very common.
The extra armor will weigh your Jeep down some
Different tires will have different dimensions...33 inches is just a "advertised" size.
Many, many guys put 2" spacers on other wise stock Rubicons and ran 33" inch tires with just slight adjustments to bumpstops til the tires wore out...
and if your doing a tummy tuck AND 2 inches of lift you better budget for a rear drive shaft with a CV joint.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #23 of 57 Old 07-21-2010, 05:11 PM Thread Starter
UncleWilson
The bracket comes with the OME kit. I was just listing all the parts.
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #24 of 57 Old 07-21-2010, 05:17 PM
2006_Sport
I'm sorry but you are soo full of it that crap is coming out of your ears.
If you mean the factory arms bend easier than any aftermarket arm on the market, you're correct.
2006_Sport is offline
post #25 of 57 Old 07-21-2010, 05:17 PM
never monday
how's the mall wheel'n in Toledo?
never monday is offline
post #26 of 57 Old 07-21-2010, 05:22 PM
freeskier93
That sucks, I don't know what the laws are here in Colorado, but I do know the cops don't give a crap. If they cared they would be pulling over every other Jeep they saw. Plus I've been driving around without bumpers, flairs, or tailgate for a couple months know why I repaint my Jeep and I haven't gotten pulled over.
Are there laws where you live about fenders or about the flairs? I ask only because the metalcloak fenders have options for 4 or 6 inch flairs. But for the fenders and flairs it is pricy.
freeskier93 is offline
post #27 of 57 Old 07-21-2010, 05:32 PM
solarpower
The mall is just fine here.
04 TJ "U" package
06 XK Commaddy 4.7
post #28 of 57 Old 07-21-2010, 05:34 PM
2006_Sport
That flex is soooo masssive bud, pretty good for a STOCK height rig but nothing to drool over. Saying that the stock flimsy stamped steel control arms with bushings on both ends(that WILL bend) flex better than curries with JJs at both ends is just ridiculous. You must be smoking that good **** because you have no clue what you're talking about. You need to do a bit more research.
post #29 of 57 Old 07-21-2010, 05:41 PM Thread Starter
UncleWilson
That flex is soooo masssive bud, pretty good for a STOCK height rig but nothing to drool over. Saying that the stock flimsy stamped steel control arms with bushings on both ends(that WILL bend) flex better than curries with JJs at both ends is just ridiculous. You need to do a bit more research.
^^^x2
From what I understand the JJ's actually reduce the lateral stress on the CA mounts and in turn on the CA themselves. Has anyone else heard about the trackbar to different cover clearance issues?
o[__Q_]o
(OIIIIIO)
[]==O==[]
post #30 of 57 Old 07-21-2010, 05:45 PM
2006_Sport
^^^x2
Correct, and as far as the track bar issue goes. If you don't get an aftermarket diff cover for the front you should be okay on clearance with the JKS track bar.
build , lcog , ome , rokmen , TJ
35" tires - low center of gravity tj bpnielson TJ Wrangler Technical Forum 45 08-04-2010 11:22 AM
Lowering Center of Gravity bigblackblur TJ Wrangler Technical Forum 28 09-07-2009 02:52 PM
center of gravity JeepMKcomin TJ Wrangler Technical Forum 7 08-22-2006 09:23 PM
2" BB-Increased Center of Gravity idgit0488 TJ Wrangler Technical Forum 14 02-14-2006 07:41 AM
Low Center of gravity phattdraggon YJ Wrangler Technical Forum 21 03-31-2005 05:53 PM
