Sanity check before I spend all my money - JeepForum.com
post #1 of 12 Old 08-14-2012, 08:56 PM Thread Starter
gmanlax06
I'm looking to lift my LJ with a BB and BL to fit 33's. This is the plan:
-Rubicon Express 2" economy with monotubes
-Daystar 1" body
-Mickey Thomson 15x8 Classic II's
-BF Goodrich KM2 33x10.5
The obvious question is whats the best BB for the money, and what BB is best for the extra weight of a LJ?
I like the idea of the 1" bl combined with the bb instead of going straight suspension lift.
And I'm fairly set on the look and reviews of both the Classic II's and the KM2, although I am shopping around for the best prices.
Lastly, with the LJ do you think I'll need to regear? My thought was that the 33x10.5 would be lighter than the 12.5 and therefore keep me from having to regear.
Thanks
gmanlax06 is offline
post #2 of 12 Old 08-14-2012, 09:10 PM
PurpleTJ
A BB is a BB is a BB. They're all plastic spacers. Shocks are what matter.
What axles do you have and with what gears? If you have a rubi, you won't have to regear, otherwise, you'll probably want to eventually.
How do you / do you plan to wheel your Jeep?
Great choice on the KM2's
Purple Jeep Club member #8
PurpleTJ is offline
post #3 of 12 Old 08-14-2012, 09:16 PM
Stu Olson
Stu Olson's Avatar
In my opinion, an 8" wheel on a 10.5" tire is too wide. Typically, a 12.5" tire is mounted on an 8" wide wheel. Were it me....I would opt for the 12.5" wide tire if I were springing for new wheels.
What is your current gear ratio? Re-gearing depends a lot on what you currently have....with some setups being better or worse than others. That being said, 4.56 gears are a good setup for 33" wheels. It is what I would recommend to anyone looking to mount 33" tires.
A poly spring spacer is a poly spring spacer. I don't see some extra weight factoring in the equation. I've never ran across any "squished" poly spring spacers.
Stu Olson
ARB Locked & Loaded
Stu Olson is offline
post #4 of 12 Old 08-14-2012, 09:24 PM
MayRoll
We would benefit from knowing what transmission he has.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #5 of 12 Old 08-14-2012, 09:31 PM
Stu Olson
Stu Olson's Avatar
IMO, Jeep doesn't offer a stock transmission that is setup to drive 33" tires with the stock axle ratios available. They are all compromises. Now, if a person doesn't mind a compromise, that is fine.
Stu Olson
ARB Locked & Loaded
post #6 of 12 Old 08-14-2012, 09:58 PM
MayRoll
I disagree, Stu. I've found that the NSG370 equiped Rubi (4.10) turns 33's very well. If it has the 42RLE, I wouldn't hesitate to run a 4.88 gear with a 33" tire. No one knows what the OP has.
First of the Breed
03 Khaki Rubi
JF short arm champ
MayRoll is offline
post #7 of 12 Old 08-14-2012, 10:55 PM
MulletHunter
Just don't put chrome/ silver aluminum wheels on a jeep! Black belongs on a jeep. Silver is for sissys!
MulletHunter is offline
post #8 of 12 Old 08-14-2012, 11:19 PM
Stu Olson
Stu Olson's Avatar
It's fine that you disagree. It doesn't change my mind and I still stand by my statement.....and I consider using 4.10 gears on 33" tires to be a compromise....it's just not as much of a compromise as running 33" tires on 3.73 gears. Everyone has different tolerance levels as to what they can put up with. I run 4.56 gears and 35" tires....and that is a compromise as well....and I put up with it.
Edit: And now that I read it....#7 is a compromise too. But that is a different issue for a different day.
Stu Olson
ARB Locked & Loaded
post #9 of 12 Old 08-15-2012, 05:28 AM Thread Starter
gmanlax06
Its not the Rubi, so I'm working with the 3.73 and a manual trans. Thanks for the help fellas... I think I'm gonna start ordering parts, and plan on a regear to 4.56.
As far as wheeling... Im in the military and will be moving 3 times in the next year, TX to FL to Cali (I hope). I want her to be able to be a jack of all trades... on a very basic level.
post #10 of 12 Old 08-15-2012, 05:32 AM
TheRealKTrain
JK Wrangler
http://www.jeepforum.com/forum/f9/fi...ofiles-402432/
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #11 of 12 Old 08-15-2012, 08:02 AM
Stu Olson
Stu Olson's Avatar
And thanks for your service.
Stu Olson
ARB Locked & Loaded
post #12 of 12 Old 08-15-2012, 03:02 PM Thread Starter
gmanlax06
Sorry bout the profile... just finished it.
33's , bb , lj
Sanity Check Low Fuel Pressure scoreboard YJ Wrangler Technical Forum 15 03-04-2012 11:19 AM
Sanity Check on Stock Wheels portabill YJ Wrangler Technical Forum 10 07-05-2010 08:47 AM
Shackle Torque Sanity Check drew2000 YJ Wrangler Technical Forum 3 02-07-2010 04:15 PM
heater core replacement sanity check eruji TJ Wrangler Technical Forum 20 12-07-2009 05:16 PM
Please sanity check for me: 4.88 and arb locker purchase spokanistan TJ Wrangler Technical Forum 15 10-03-2008 07:53 AM
