Is the Sahara fender different than sport or x fenders? - JeepForum.com
post #1 of 8 Old 10-09-2013, 06:29 PM Thread Starter
TJJeepJosh
Let me point out that I am talking about the inner metal fender. Not the flare.
My passenger side fender is rusting through from what seems like the middle of the fender. I can't find any rust on the under side of it yet there's almost a pit on the top of it from where I have sanded it down to get rid of rust in one area.
Anyways, my question is are the Sahara fenders different than other trim model fenders? I don't see why there would be a difference but I found a fender on amazon and it specifically points out that it is a jeep wrangler/Sahara fender.
Jeeps are like strippers...they should be topless as often as possible.
TJJeepJosh is offline
post #2 of 8 Old 10-09-2013, 06:58 PM
Necko2529
Necko2529's Avatar
No, there's no difference. If you look underneath you will see what i think is an reinforcement plate that leaves a 1/4" gap where water and crud collect and rust the fender from the inside out. It has openings on the corners but its not enough to keep em dry and clean, every time i wash my Jeep i put the nozzle up to the opening on the corner of reinforcement and blow water thru to keep it clean.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #3 of 8 Old 10-09-2013, 07:29 PM Thread Starter
TJJeepJosh
Thanks, thought that was the case, wanted to confirm it.
Wondered what that plate was. Good idea for washing it. Wish it was possible to remove that plate. doesn't look too easy.
post #4 of 8 Old 10-09-2013, 08:34 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Some mounting points for accessories and holes differ from year to year on TJ inner fenders...
Knuckelhead is offline
post #5 of 8 Old 10-09-2013, 08:49 PM
Necko2529
Necko2529's Avatar
Tub mounting holes should be the same, no?
post #6 of 8 Old 10-09-2013, 09:26 PM
Knuckelhead
AFSOC Retired
Yes, but early grill mounts may differ...
post #7 of 8 Old 10-09-2013, 09:34 PM
Necko2529
Necko2529's Avatar
Could be, i wouldnt kbow. The oldest I've owned was an 01 60th Anniversary but have not taken off the fenders or done pretty much any kind of body work. Im pretty familiar with 03-04 from owning both.
post #8 of 8 Old 10-10-2013, 04:43 AM Thread Starter
TJJeepJosh
I'll have to just match it by looks or find one locally to test it.
fender , replacement , sahara
