Is it safe to drive w/o Tcase skid?
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
Junior Member
I need to replace the threadnuts on my 98 TJ & I was wondering if it is safe to temporarilly city drive without the skidplate?
#2 |
No - The skid plate holds up the transmiision / Transfer Case
Friends don't let Friends run Bosch My Wifes Cake Site - Check the Jeep Under Carved & 3D |
#3 |
Do it right or not at all
![]() Join Date: Jan 2003
While I wouldn't do it for long, the rear of the tranny/t-case is held up by a heavy bracket welded to the frame so you'll be ok for a while. I used to say it wasn't ok to do so either as Pillswoj suggests but I was recently reminded of that support bracket that does provide a good solid support for the rear of the engine/tranny/t-case assembly. I had forgotten about that support and bracket even though I had been required to remove and reinstall it several times this past year.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#4 | |
You can't remove the t-case skid and drive. You can't even remove it without supporting the drivetrain - it holds the drivetrain in the vehicle!
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#5 |
That's odd, my '97 does... it did with the first AX-15 it came with from the factory, and it was retained with a different bracket when I converted to the automatic tranny last year. Blaine's (mrblaine) two TJs are the same way, he was the one who reminded me of the support rod and bracket's presence when I previously said the rear of the drivetrain was supported only by the skidplate.
#6 | |
heres a JeepMedic install on a 2005, with lots of pictures, and no extra bracket: http://www.wanderingtrail.com/Mods/TJLJmods/Medic_tummytuck/Medic_tranny.htm
#7 |
None of those pics show the area where it would be, up inside on the passenger side.
Here is a photo of the rear transmission support rod and bracket I am referring to. ![]()
#8 |
I'll crawl under there and look again today to make sure, but that doesn't look familiar. Is there adjustment?
#9 |
No, it's just a simple bolt-on bracket and support rod.
#10 |
#11 |
I have that same rod you're talking about, but it only goes to the exhaust. Where does it bolt to on your Jeep?
2005 LJ- Mostly stock/ DD 2000 TJ- Slowly Rebuilding 1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti | |
#12 | |
#13 | |
Crawl under your Jeep and look again. The mount attaches the exhaust to the tranny, to keep the exhaust from rattling. I just got done cutting mine off. ![]() |
#14 | |
I have the same bracket bolted to my tranny but other than being bolted to the skid it has no other attachments other than the rod that gos to the exhaust Do you have a pic of the other end of the Rod shown in your pic Steve |
#15 |
Jerry, I hate to say that I think you're wrong, but I think that you're wrong. I've pulled the tranny and transfer case on a few 4 cyl TJs, and I never remembered seeing/dealing with that bracket, but I figured maybe I was just forgetting it. With that being said I just went and looked under my Jeep to double check that I'm not an idiot, and sure enough there is no bracket that goes to the frame. I'm willing to go take pics if you still don't believe me. Maybe that bracket is just a 6 cylinder thing? Your guess is as good as mine.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
