Rythmic Vibration over 60 mph - JeepForum.com
post #1 of 46 Old 11-18-2007, 03:31 PM Thread Starter
steveinmedford
steveinmedford's Avatar
2014 KL Cherokee
Rhythmic Vibration over 60 mph
Hey all
Lately I've ben experiencimg a rhythmic vibration when highway driving at speeds over 60mph. Feel vibe at 60, worsens at 65 and starts to get rhythmic there after. Dont really feel in steering wheel. More feel in gas pedal/floor/seat. Can almost hear it too. Not sure though.
By rhythmic I mean I feel a harsh vibration which briefly disapears then returns. At 70 the vibration cycle is harsh vibe for 3-4 seconds, smooth for 1-2 and repeats...etc..
Have new tires with <10K and have had them re-balanced. Shop said that they were out-of-balance but are alright now. I agree...don't feel out-of-balance shake in steering wheel as I did before re-balance. Also have new shocks.
Could the tires have started to wear funny since they were out-of-balance for awhile? No visible uneven wear. What else should I look for/check-out?
Have 2" bb, 1" bl and 1" mml. 100k miles. Need more info? Please ask away.
Thanks Steve
Steveinmedford
2014 KL, Cherokee Latitude, 2.4, auto
steveinmedford is offline
post #2 of 46 Old 11-18-2007, 04:53 PM Thread Starter
steveinmedford
2014 KL Cherokee
btt on one?
Steveinmedford
post #3 of 46 Old 11-18-2007, 06:46 PM
00jeepsahara
00jeepsahara's Avatar
ive had a similar vibration for a while now, mine starts earlier though at about 35 mph, wasnt a bad u joint or tire, still trying to figure it out, ill let you know if i get it, or will check here to see if anybody has a solution.
2000 Jeep Wrangler Sahara
113" Wheelbase
42 Iroks
17" Allied Beadlocks
D60/14BFF
00jeepsahara is offline
post #4 of 46 Old 11-18-2007, 08:54 PM
DevEmp
Fill out your profile... that way no one will have to ask about stuff like the year of the Jeep, lack of a SYE, etc etc.
DevEmp is offline
post #5 of 46 Old 11-19-2007, 05:16 AM
Saubaer
Saubaer's Avatar
We had a similar vibration problem on one of our Vans a while back. Shop replaced the driveshaft and the vibe was gone.
Maybe there is something going on with the u-joints or centering ball.... Check the Control arm bearings too, maybe a worn bearing brings the driveshaft angles out of whack.
olli
'03 Rubi
Just cuz you got the power, that don't mean you got the right!
Saubaer is offline
post #6 of 46 Old 11-19-2007, 07:24 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
To help you narrow it down and start the process of elimination, remove the driveshafts one at a time and drive it.
That will tell you real quick if its the front or rear driveshaft that is causing the problem.
Wheelin98TJ is offline
post #7 of 46 Old 11-19-2007, 08:00 AM
00jeepsahara
yeah thats a good idea.
113" Wheelbase
42 Iroks
D60/14BFF
post #8 of 46 Old 11-19-2007, 09:44 AM
Jerky bump
I have had a similar experience with mine- from new. The cycles are more like 1sec. on 1sec. off, though- around 70+ most noticeable too. I think it's actually body shudder because of its' poor aerodynamics.
Jerky bump is offline
post #9 of 46 Old 11-19-2007, 10:05 AM
05tjx
did it start out of the blue did you go wheeling then came home and it started up. i bent my skid plate a little so now mine vibrates at about 35 top 45 mph. i got a new skid plate just to lazy to put it on
05 tj x, 4in procomp stage 2, aem intake, tbs, jet chip, 3312.50 15 on 15x10 weld supersingles, quick discos, 4.56s, detroit truetrac in the front and super 35 kit with a detroit in the rear,and other stuff
05tjx is offline
post #10 of 46 Old 11-19-2007, 11:25 AM Thread Starter
steveinmedford
2014 KL Cherokee
Sort of out of the blue. Don't usually drive that fast so not sure how long it may have been there. Not from wheeling or any rough stuff.
Like previously noted, knew there was a tire balance problem that was taken care of.
Drive shaft balance, hmmm, I'll check into that. U joints? Ball joints?
Sounds like there could be a number of causes. Exploring.....
Thanks all respondents, past and future?
Steve
Steveinmedford
post #11 of 46 Old 11-19-2007, 11:34 AM
FrankGG
I have that rhythmic vibration too!!! (2005 Rubicon)
It happens pretty suddenly once I hit ~73 mph, sometimes it moves up or down a few miles per hour, but yeah, I get about 1 second of vibration I can feel through the lower 1/2 of the cab, then 1 second of no vibration. No real vibrations on the steering wheel.
Its happened ever since I got my Jeep (I bought it used around July)
I was actually meaning to call Jeep and get it looked at, but I keep putting it off, though I should do it soon.
I asked a while ago about it and people seemed to think it was the driveshaft.
FrankGG is offline
post #12 of 46 Old 11-19-2007, 12:07 PM
Diz
I have been having the same deal, mines about a 1 second on 1 second off kind of thing.
But i dont understand how a driveshaft can be causing this pulse. If the driveshaft is always moving at the same speed, or relatively the same speed, how can the pulse completely stop and start like this, constantly?
I thought it had something to do with the belts or some other engine parts, but i really have no idea.
03' Rubicon
Diz is offline
post #13 of 46 Old 11-19-2007, 12:10 PM
Dravintoad
Dravintoad's Avatar
03' Rubicon
Just so you know, the driveshaft doesn't constantly move at the same speed.
Nothing to see here.
Move along.
Dravintoad is offline
post #14 of 46 Old 11-19-2007, 12:22 PM
doublins
03' Rubicon
It's pulsing because there must be two slightly different frequency vibrations going on that are causing "beats," where they alternate between cancelling eachother out and amplifying one another- the result is a slow and rhythmic "WHIRR...... WHIRR....WHIRR.... WHIRR....". Probably has to do with a vibration in the driveshaft that is not supposed to be there, interacting with some other normally negligable vibration, coming from somewhere else in the drivetrain or from the tires.
-C
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
doublins is offline
post #15 of 46 Old 11-19-2007, 12:55 PM
hoseclamp
hoseclamp's Avatar
I had the harmonic cycing vibes too. Did a 3.5" lift, 1" BL/MML, rear CV DS, no TC drop. I read somewhere it could be the thin metal skid emitting vibes, so I built a 1/4" thick steel one, even with a bit more clearance, smooth as silk.
'04 Rube
JEEPS ARE NOT CARS, STOP CALLING YOUR JEEP A CAR!!!!!!!!
hoseclamp is offline
Bad Vibration. Please Help? metal_kid17 YJ Wrangler Technical Forum 8 10-26-2009 02:52 PM
Rythmic Wrangler emischel TJ Wrangler Technical Forum 10 01-06-2009 01:55 PM
Odd vibration JeepPirate TJ Wrangler Technical Forum 4 01-14-2008 12:03 PM
Vibration henri TJ Wrangler Technical Forum 13 04-13-2005 07:25 AM
still getting vibration redwolf_747 TJ Wrangler Technical Forum 7 01-11-2005 07:36 AM
