Rusty 44 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rusty 44
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 02-16-2006, 07:39 AM   #1
Nitromoose
Rusty 44
I was checking out a saraha the other day (thinking about trading) and I checked the rear end out to see what it had, and I found the D44 , but it looked like it had some rust on it, kinda like it has been painted with rust, and that was peeling off. Know what I mean?
Is that something that could just be knocked off with a wire wheel/brush and repainted with rustoliem, or should it be a show stopper? I checked the rest of the frame and undercarrage, but I did not see any other rust spots (other than the regular exaust spots like the cat and such)
It's a 99 or 00 saraha, 5 spd, I6, with about 50K. What do you think?
Nitromoose is offline   Reply With Quote
Unread 02-16-2006, 08:26 AM   #2
Viet15philong
you can wire brush it and repaint it. From Factory the paint on most axle are not done very well.
Anthony
Viet15philong is offline   Reply With Quote
Unread 02-16-2006, 08:29 AM   #3
JPJeeper
I am not from the rust belt but I would think it would take a awefull lot of rust to make a Dana44 not worth anything. I would say you could brush it... nuetralize it, and paint it pretty easy.
2006 Unlimited Rubicon
1990 Wrangler YJ
1987 Wagoneer FSJ
1975 J20 Jeep Truck
1967 J3000 Jeep Truck
JPJeeper is offline   Reply With Quote
Unread 02-16-2006, 10:34 AM   #4
Miller57
I just bought a 98 with rust on the axels and frame, just enough to make the paint peal. I wouldn't worry about the axels, what you should look at is the brake lines, and body mounts, that it where the trouble will be. My brake lines are rusted and i will be replacing them, the body mounts look good, but some of the brackets on the axels will need to be replaced down the line. Pull the carpet and look at the floor boards also, if there is no rust coming thru form the under carriage I say go for it.
98' White Sahara 4.0 3 spd auto D44
RE 4.5 Superflex, 35x12.50.50's on black steelies
96 Red Cherokee Country
Family Wheeler
Miller57 is offline   Reply With Quote
Unread 02-16-2006, 02:53 PM   #5
Nitromoose
Good deal, thanks guys
