in
this forum
in
the entire site
Advanced Search
Cancel
Login / Join
What's New
Forum Listing
Products
Marketplace
Showcase
Gallery
Advanced Search
Members
FAQ
Dark Mode
Light Mode
menu
Log in
Sign up
Home
Forums
Models
Jeep Wrangler Forums
TJ Wrangler Technical Forum
Follow Forum
Create Thread
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
Filters
Show:
Loading…
1
1 of 6746
Go to page
Go
6746
Sticky
Diagnosing Death Wobble and Fixing Non-DW Shimmies and Wobbles (TJ Version)
planman
Apr 25, 2014
19
20
21
406
148K
Dec 31, 2023
by
BeachTJ
Sticky
Beware of Scammers contacting members through PM's
cranbiz
Jan 15, 2020
14
8K
Apr 17, 2022
by
Krazymaan
Sticky
Rules and Guidelines, keep posts TECH related
igofshn
Jan 7, 2003
Locked
1
45K
Jun 15, 2009
by
Wheelin98TJ
Sticky
TJ Forum FAQ
Wheelin98TJ
Oct 6, 2008
Locked
4
298K
Oct 6, 2008
by
Wheelin98TJ
Sticky
Stock TJ Specifications
Wheelin98TJ
Aug 22, 2007
Locked
10
1M
Aug 25, 2007
by
Wheelin98TJ
Sticky
Attention all new members... please read this immediately.
Jerry Bransford
Apr 15, 2007
Locked
0
74K
Apr 15, 2007
by
Jerry Bransford
Help With Head or Head Gasket Replacement on 2000 Wrangler TJ 4.0
OldJeepBum
Jan 15, 2024
8
366
53m ago
by
OldJeepBum
I
Clock spring with cruise control
iceman4450
3d ago
5
156
2h ago
by
iceman4450
Gimme some answers! (pulls to left when braking, pulls to right when off the gas)
dz1087
Jan 8, 2008
23
5K
11h ago
by
Mr. Bitey
M
2.5L with 32” tires automatic transmission gears
MattOSJ
Feb 27, 2024
3
170
12h ago
by
BobF90
A different reason for TJ lift springs knowledge
1BADCJ8
14h ago
1
108
13h ago
by
TheBoogieman
K
Flashing CEL after new CPS sensors
Klinestine
Mar 9, 2024
7
222
1d ago
by
Klinestine
C
06 TJ unlimited (LJ) differences from TJ
ChadH
3d ago
29
436
1d ago
by
Digger84
05 Rubicon fender flares (factory) color
JonMopar
Mar 9, 2024
13
333
2d ago
by
TheBoogieman
Y
P0301 Misfire Cylinder 1 Help
YinzPgh1
4d ago
2
127
2d ago
by
bobjp
N
2000 Jeep TJ Long crank before start
Nav232
3d ago
3
196
2d ago
by
TheBoogieman
J
1998 Jeep TJ Sahara 4.0. Hazards and Blinkers not working
Jwags001
2d ago
3
124
2d ago
by
Digger84
C
NP231 Kicking Out of 2WD
CristianVelez
Mar 9, 2024
6
254
3d ago
by
grogie
S
Cigar lighter keeps blowing the fuse!
szyJYM
Jan 26, 2010
20
12K
3d ago
by
Offroad Hopeful
New Head Needed For My 2000 TJ 4.0
OldJeepBum
4d ago
4
172
3d ago
by
OldJeepBum
A
How to remove broken bolt from rear upper control arm joint
AWheeler
5d ago
10
280
3d ago
by
Digger84
B
Mysterious off and on vibration
budro69
Jun 6, 2022
11
528
3d ago
by
budro69
C
Suspension overhaul
ChadH
May 26, 2023
28
1K
4d ago
by
ChadH
B
Transfer case noise diagnosing
budro69
7d ago
3
192
4d ago
by
budro69
J
99 wrangler 4.0 stall at idle in gear
Jonboy75098
4d ago
3
147
4d ago
by
Jerry Bransford
What did you do to your TJ today?
exc911ence
Feb 7, 2006
5929
5930
5931
119K
11M
4d ago
by
OldJeepBum
C
Can anyone help me identify what I bought? Suspension/Steering specifically
cecoen
4d ago
4
155
4d ago
by
cecoen
M
windshield replacement on a 1999 TJ
matsprt
Feb 7, 2024
Locked
9
511
4d ago
by
ColdCase
M
06 TJ 42rle to ax15/nv3550 swap complete... with some kinks to work out !
Mike1080p
Dec 17, 2017
19
6K
5d ago
by
ecobb.kcs
[CHECK GAUGES], Dropping Voltage, All Lights Failed, But Still Drives and Starts???
Rivka
Mar 11, 2024
6
229
5d ago
by
wranglerfix
W
Random Misfires, No Codes
WillJeepForFood
Nov 17, 2023
2
3
88
3K
6d ago
by
WillJeepForFood
F
Regulator?
Fyre23
7d ago
4
176
6d ago
by
Rubi4MyMrs
What wheel lock exactly do I get?
Aurorawolf2012
Oct 21, 2023
9
446
Mar 11, 2024
by
dbbd1
A
Suspension Upgrade for TJ
Adam.TJ
Mar 8, 2024
15
367
Mar 10, 2024
by
Adam.TJ
U
Rythmic Banging (matches engine speed)
ulkster007
Oct 21, 2023
5
328
Mar 9, 2024
by
ulkster007
H
Soft top rear window for 2001 Wrangler Sport 4X4 Sport Utility 2DR
harrisma
Mar 9, 2024
2
152
Mar 9, 2024
by
TheBoogieman
Z
03 TJ won’t start. (Free floating shifter)
zek1200
Mar 8, 2024
4
167
Mar 8, 2024
by
zek1200
W
Replacement Distributor
WillJeepForFood
Mar 3, 2024
13
318
Mar 8, 2024
by
WillJeepForFood
J
Radio doesn't work while engine running.
jreuscher
Mar 30, 2006
12
21K
Mar 8, 2024
by
donniep43
C
LJ 4" coils?
cjstefan
Feb 29, 2024
13
459
Mar 8, 2024
by
RockWoRM
0
My 1st tj
01blkxj
Mar 7, 2024
2
173
Mar 8, 2024
by
TheBoogieman
1
1 of 6746
Go to page
Go
6746
2.8M
posts
548.3M
views
Third generation of the classic Jeep - manufactured from 1997 till 2006. Known by the coil springs and round headlights. Includes the Rubicon and Unlimited editions as well
Show Less
Join Community
Grow Your Business
Forum Staff
View All
Wheelin98TJ
Super Moderator
Top Contributors this Month
View All
TheBoogieman
D
Digger84
C
ChadH
Recommended Communities
AVS Forum
1M+ members
The Jeep Recon
180+ members
Jeep Wagoneer Forum
3K+ members
Home
Forums
Models
Top
