Rust on frame - JeepForum.com
post #1 of 9 Old 08-09-2011, 11:32 AM Thread Starter
mracoker
Rust on frame
I was looking under my jeep, 98 wrangler, to see where a body lift would be installed and I noticed some rust on the frame. I'm not sure what the technical name for the pieces are, but its where the body sets on the frame. Not all are rusted but these are and I wanted to know what my options are for fixing it and what would happen if I did nothing at all. And would this cause a body lift to be a pain?
Thanks in advanced!
mracoker is offline
post #2 of 9 Old 08-09-2011, 11:47 AM
PeteYJTJ
That looks more like BODY rust than FRAME rust. It's above the body mounts.
Probably a good chance that when you go to loosen the body bolts you'll pull 'em right out, break out all that rust, etc.
Good luck.
Pete
88YJ:SOA/locked/35s/Superwinch=Wheeling Jeep.
04WJ:4.0/3"+10mm/Superwinch=DD & Expedition Jeep.
PeteYJTJ is offline
post #3 of 9 Old 08-09-2011, 11:54 AM Thread Starter
mracoker
OK thanks for clearing that up. I'll have to research how to fix that, I worry that the new spacers, if that what the black rubber things are, will just go into the body.
mracoker is offline
post #4 of 9 Old 08-10-2011, 07:19 AM Thread Starter
mracoker
Body Rust at Body Mount
I went home and did a little poking around with a screwdriver and found that there are two that look bad. I have some pictures of them below.
As I understand it, my TJ has 11 body mounts. So should I worry that only 2 are in bad shape? Also what can I do to prevent the other 9 from rusting out also? I would love to fix this myself, even if it means cutting and welding. It would give me a good excuse to buy a mig!
Thanks!
mracoker is offline
post #5 of 9 Old 10-14-2012, 11:18 PM
WsRpAoNrGtLtEjR
Sorry for resurrecting an old thread, but how did you go about fixing this issue? I've got the same problem, on only 2 mounts (1 right under each front seat/door).
WsRpAoNrGtLtEjR is offline
post #6 of 9 Old 10-15-2012, 09:16 AM
Trisalsa
Trisalsa's Avatar
I'm in exactly the same boat. Just the ones under the doors. All the rest look good. My plan was to either cut it out myself and weld in new metal on the body or bring it to a shop to do the same. Recommendations welcome.
1999 TJ Sport
2010 XK Limited 5.7
Trisalsa is offline
post #7 of 9 Old 10-15-2012, 09:22 AM
yamaha225
Rust will have to be cut out and new metal with a nut for the body mount welded in.
1997 TJ, 2.5 4 cyl, AX-5, Hella 700's
Black Jeep Society, Eagle Scout Jeepers
yamaha225 is offline
post #8 of 9 Old 10-15-2012, 12:04 PM
TurtleTamer
same problem here. im assuming you have remove the tub to fix this... not looking forward to that..
Giraffes are so freakin' cool.
TurtleTamer is offline
post #9 of 9 Old 10-15-2012, 12:21 PM
sailsurf7713
http://www.jeepforum.com/forum/f22/o...h-33s-1307968/
YtownTJ did a great job fixing that same problem. Also Classic Enterprises makes those sections, but they're pricey. I have to do the repair as well. Just gonna bend up some 1/8" and weld a nut to it and weld it in like YtownTJ did.
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
98 wrangler , frame , rust
Frame rust? lil-jmart13 TJ Wrangler Technical Forum 9 06-20-2011 01:05 PM
Frame Rust - What would you do? Sabreman YJ Wrangler Technical Forum 17 10-30-2010 08:09 PM
need help with frame rust maxumum2 YJ Wrangler Technical Forum 21 12-13-2009 02:31 PM
rust in the frame, what to do? mwc TJ Wrangler Technical Forum 2 12-15-2006 12:10 PM
Frame rust bigstinger YJ Wrangler Technical Forum 4 07-22-2006 04:40 PM
