Rust behind body armour? - JeepForum.com
post #1 of 11 Old 05-09-2005, 05:49 AM Thread Starter
Korruptor
Washed my gf's 2004 TJ yesterday with her and found a few scratches on the body below the door. I think it's from feet hitting it as people climb inside the Jeep.
She said she wanted to get some of that diamond plate body protectors for the side of the Jeep and my dad started saying how he would worry that water could get behind there, and then start to rust out the body.
Anyone have this problem? Is it a big risk? She already has the plastic door jam guards.
"THIS is my BOOMSTICK! You can find it in Aisle 5 of the sporting goods department... Shop Smart, Shop S-Mart!"
Korruptor is offline
post #2 of 11 Old 05-09-2005, 06:08 AM
RockRunner85
I have scratches on the side from people feet. Really started to scratch away the paint. Its on the drivers side though so its my fault, I figure its no worse than the other scratches. This was with the stock diamond plate rubi rocker guards. They come about half way up.
I do have rocker guards on the side that cover all the way up to the door (thus no more scratches). However I pulled them off today to repaint them since the paint it starting to come off (the paint didn't adheare well in the winter when I put them on). Anyways they have eating through the paint in areas.
Places do sell this plastic striping you can put on the back of the sliders to keep the water from getting in. I had these when I had the rubicon stock guards. They didn't keep the water out, and the paint still got messed up. It is duller and faded where the plastic rubbed against it.
Either way if you put something on the paint well be messed up underneath. Not to mention you have to drill numerous holes to mount these things, so no going back.
Personally I like my rocker guards, but I use them for functionality purposes. Wish I had them to begin with so I wouldn't have this nasty dent in the side.
Some people use silicon caulking, etc to seal them up, not sure how good this works.
2004 Black Rubicon w/ 5 spd
RE 3.5 SuperFlex & Front Trackbar / JKS 1.25" BL & MML / 35x12.5 MTRs on 15x8 AR-23s / Currie Anti-Rock / Jeeperman Bumpers / Rokmen Sliders / York OBA / Harbor Freight 8k Winch
RockRunner85 is offline
post #3 of 11 Old 05-09-2005, 10:11 AM
Av Native
the silicone caulking seems to work good, I havent taken mine off but the silicone seals it real good
04 Silver TJ
4" rough country lift
1" currie MML/BL
JC fab rockers and 1" seat lift
33"BFG MT's
Nth degree adjustable upper arm
Nth degree lower arms
Power trax front locker
Av Native is offline
post #4 of 11 Old 05-09-2005, 10:14 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The tub's sheet metal is hot-dipped galvanized, I wouldn't sweat it.
Jerry Bransford is online now
post #5 of 11 Old 05-09-2005, 10:39 AM
CNY
I've read that some sealants actually PROMOTE rust. What's good as a sealer AND rust inhibitor? 100% silocone?
CNY is offline
post #6 of 11 Old 10-23-2005, 06:56 AM
CNY
Winter (and salt) is coming, anyone have a suggestion?
CNY is offline
post #7 of 11 Old 10-23-2005, 09:49 AM
mphudak
I used Locktite "right stuff" when I installed mine. From years of working on watercraft I swear by the stuff. I coated my bolt holes/rocker guard holes as well as a nice thick bead and the top of my rocker before installation. Anything you do, considering it is done right, is only a precaution it's never a guarantee.
Mike H
04 Unlimited-RIP
99 XJ 3 Linked w/3" lift on 37's
mphudak is offline
post #8 of 11 Old 10-23-2005, 10:01 AM
FlatlineCowboy
FlatlineCowboy's Avatar
if your worried about rust behind diamond plate then I would scuff the area down to rough it up, use some good spray on primer and coat over the area with rubberized undercoating, then apply your diamond plate over it.
White Jeep Club Member #513
2002 Jeep Wrangler Sahara Edition
White / Spice
4.0L, Auto, Soft top, D30-F / D35-R
30x9.50x15 Wrangler GSA
(4) 100watt driving lights & (4) 55watt reverse lights
Silverstar headlights & paint bezels black
FlatlineCowboy is offline
post #9 of 11 Old 10-23-2005, 10:20 AM
Dirty Backroads
Dirty Backroads's Avatar
Well, my powdercoated rockers have only been on my Jeep about a month and they are scratched/scuffed up on the sides from everyone getting in and out of them. I imagine that if the rockers weren't there it would've happened to the paint. I thought powdercoating was more resistant than scratching than paint so I'm a bit surprised it happened this quickly. Maybe it's because the black rockers show scratches more readily than the yellow paint. When I had the rockers put on the paint was just fine. Once you drill those holes and put those rockers on then you've pretty much gone down a one-way street.
The scratches on the rockers are cosmetic/superficial. They are from everyone jumping in and out of the Jeep, especially while wheeling. I'm debating whether to paint over the powdercoating so I can touch them up from time to time, especially the bars, which are really scuffed up and will only get worse over time. I'm sure a few rocks will hit 'em eventually too so I like the idea of being able to repray them once in awhile so that rust doesn't start to develop.
As for rust behind the rocker guards, I would think the main problem would be rust forming around any holes that were drilled into the tub so I would think that it's very important to spray paint into the holes when installing the rockers. When I wash the Jeep I make sure to blast water into the rockers top and bottom until the water runs out of them clear and get all dirt/debris out. I plan to do this regularly in the winter time once the snow hits the ground and the salt trucks do their thing.
Anyone paint over their powdercoated rockers to touch them up? If so, how did you do this and how does it look?
2005 Solar Yellow TJ Sport
Yellow Jeep Club Member #123
Originally Posted by Sniper111
Nothing like going topless with some Kid Rock blasting looking down on the rice boys with their dropped Civics wondering what Japanese steel would look like under the Mickey Thompsons.
Dirty Backroads is offline
post #10 of 11 Old 10-23-2005, 10:24 AM
Frooch
Why wouldnt you do that over the paint with a self etching primer? Wouldnt you want more coats of protection and not less?
Frooch is offline
post #11 of 11 Old 10-23-2005, 10:34 AM
roketman
I had mine covered by Line - X. They look great and no more scratches.
02 Yellow TJ Sport. The axles and transfer case are 2004 Rubicon with Solid diff covers. Rubicon Express 5.5 long arm with Rancho 9000 shocks. PSC hydraulic steering. Poison Spyder tube fenders rockers and crusher corners. Blue Torch Fab front stubby, winch plate, and rear bumper. ORF cage with Rockhard harness bar. Corbeau CR-1 seats with Corbeau 4 point harness. 35" Hankook MTs on Raceline Rock Monster beadlocks. Warn M800 winch.
roketman is offline
Body Armour? KnightofMopar YJ Wrangler Technical Forum 10 02-24-2009 11:52 AM
body armour for 02 TJ jeepin_in_fl TJ Wrangler Technical Forum 13 12-06-2008 12:26 PM
How are Body Armour with swing out? jrnjay YJ Wrangler Technical Forum 7 02-02-2006 01:08 PM
Body Rust Maine-yj YJ Wrangler Technical Forum 14 02-07-2003 06:37 PM
Body Rust Protoxis YJ Wrangler Technical Forum 5 12-17-2002 04:09 PM
