Runs terrible for 3 minutes .....then fine
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Almost like a sticking cold choke, my 97 wrangler runs terrible for the first few minutes. Once is passes the sputtering, back firing stage it runs fine. This happens on a start up, even after Its been off for a few minutes. I changed plugs,wires,air filter and still no change. It also runs a bit loud in the beginning like a possible exhaust leak that heats up and seals itself. Could this be the problem?
Any ideas? Thanks in advance.. Joe
#2 | |
[U][B][SIZE=4][FONT=Comic Sans MS]Black Jeep Club Member #64[/FONT][/SIZE][/B] [/U] [COLOR=darkolivegreen][U][B][SIZE=4][FONT=Comic Sans MS]New Jersey Jeep Club Member #1[/FONT][/SIZE][/B] [/U][/COLOR] 1997 Jeep Wrangler 4.0L Sahara (Mine) 2005 Jeep Liberty 3.7 4x4 (mom's) |
#3 |
Does not burn oil, but I do have some timing chain noise..
#4 |
I have a 97 and mind did the same thing.
I took it to the dealership and thought it was my fuel pump and the couldn't figure it out. It would start but run like crap for a few minutes and act like it was going to run out of gas. Turned out it was my front O2 sensor. Once I replaced that a few thousand miles ago, it's been great. |
#5 |
I asked this question in other thread a few minutes ago ..... an codes?
I am trying to learn .... if there is any code present .... it may be easier to pinpoint
97 Green Sahara - [CENTER] Powertrain envy sufferer - Softop tinkerer [/CENTER] |
#6 | |
2000 TJ - Patriot Blue Same stuff as most of ya got. =) |
#7 |
Electrpnic air control valve?
#8 |
check to see if any of the exhaust manifold bolts are missing.. i had the same problem and my rear stud was sheared off. sounds like you have an exhaust leak to me. very notorious for these jeeps. i would also check the o2 sensors as earlier stated.
if it does go away when the jeep is warm i am 90 percent sure it is an exhaust leak or the o2's
[CENTER] 98 tj ar23's with 31's 4.10 gears [COLOR=Red]red jeep club member #283[/COLOR] [/CENTER] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
