Runs, but wont rev up...Help! - JeepForum.com
post #1 of 6 Old 01-04-2010, 09:23 AM Thread Starter
taterkins02
my jeep ran, i let it sit for 2 weeks or so, now it will start but wont go past 1200 RPM, what could be wrong?
taterkins02 is offline
post #2 of 6 Old 01-04-2010, 12:42 PM
wushaw
Rockin jeep
wushaw's Avatar
Throttle position sensor is something to look at.
wushaw is offline
post #3 of 6 Old 01-04-2010, 12:56 PM Thread Starter
taterkins02
i just put a new tps on not to long ago, its not acting like the tps..the cat isnt clogged, its getting to much fuel, but not enough air, so would that be map sensor? or mass air flow sensor? how do i tell if theyre bad with out replacing them?
post #4 of 6 Old 01-04-2010, 08:56 PM
wushaw
Rockin jeep
wushaw's Avatar
Check for a restriction in the air intake, filter. I also could be a map sensor but look at the filter first.
wushaw is offline
post #5 of 6 Old 01-04-2010, 10:07 PM
Curly5759
jeeps don't use a MAF (mass air flow) sensor, so that is not it.
Curly
I start what I finish!
77 Jeep Cherokee S
97 Jeep Wrangler
Curly5759 is offline
post #6 of 6 Old 01-04-2010, 10:12 PM
krlntj
check for a clogged cat.
krlntj is offline
Jeep runs, but wont start vtwildabeast YJ Wrangler Technical Forum 15 11-11-2009 09:28 AM
Jeep runs for a minute, then wont start... jetskibob1 YJ Wrangler Technical Forum 8 03-21-2009 05:52 PM
4.0 YJ runs great but wont start without intake cleaner spray. 94whyjay YJ Wrangler Technical Forum 7 03-05-2009 08:50 PM
93 4.0 runs but wont idle flinch YJ Wrangler Technical Forum 6 02-27-2009 09:02 AM
My 87 jeep 258 wont idle and runs poorley please help jeepyjkid YJ Wrangler Technical Forum 5 07-01-2008 10:24 PM
