Running wires through firewall - JeepForum.com
post #1 of 18 Old 01-28-2007, 08:18 AM Thread Starter
MZH29
MZH29's Avatar
2007 WK
I will be hooking up some daylighters next weekend and I was wondering, what is the best way to run the wires from the engine bay to inside the jeep? Is there a pre-existing hole? Or is it just easier to drill a hole? Thanks!
2007 Grand Cherokee Laredo 4.7/ Mopar Bodykit/ Flowmaster 40 delta
MZH29 is offline
post #2 of 18 Old 01-28-2007, 08:20 AM
lj_wil
ekorb mi
lj_wil's Avatar
There is an existing hole right above the gas pedal. I ran some power through there, that grommet is pretty tight so you may have to notch it so the wires don't pinch.
W6FU
lj_wil is offline
post #3 of 18 Old 01-28-2007, 08:22 AM
Rocky529
Rocky529's Avatar
You can make your own too if you want, just make sure you paint it and put a rubber grommet.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #4 of 18 Old 01-28-2007, 08:35 AM
tmwoodall
I pulled that grommet out and cut an x in it and I have lightiing, and amp power coming through that so running just your daylighters through should be no big deal.
tmwoodall is offline
post #5 of 18 Old 01-28-2007, 10:10 AM Thread Starter
MZH29
MZH29's Avatar
2007 WK
Are you talking about the hole by the gas pedal?
Thanks
MZH29 is offline
post #6 of 18 Old 01-28-2007, 10:57 AM
BluesMan
BluesMan's Avatar
This is the one I used for the CB. There's also one over on the left of the drivers side a little lower down.
...Don't follow Chili Palmer into the trees...
BluesMan is offline
post #7 of 18 Old 01-28-2007, 11:33 AM
tmwoodall
Thanks
Yes sorry I should have clarified, but I am talking about the same grommet as everyone else, just letting you know there is plenty o' room
post #8 of 18 Old 01-28-2007, 11:41 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Just make sure you use a wiring harness that uses a relay to provide the working current for the lights. You don't want to run all the current consumed by the lights into the cab and through the on-off switch.
Jerry Bransford is offline
post #9 of 18 Old 01-28-2007, 03:31 PM Thread Starter
MZH29
MZH29's Avatar
2007 WK
Would using the wiring kit that comes with the lights be sufficient? It says they come with a relay.
MZH29 is offline
post #10 of 18 Old 01-28-2007, 05:01 PM
tmwoodall
Yes the relay in the box is perfect for it. If you have a cb or amp that is a perfect place to rob in cabin power for the switch, I just wired up my Hellas and skipped the stock wiring alltogether, they are wired straight through the switch and the battery.
post #11 of 18 Old 01-28-2007, 06:03 PM Thread Starter
MZH29
MZH29's Avatar
2007 WK
What about if I don't have a cb or a amp in the cabin? Where would I power the switch from? Sorry for all the questions, just trying to get as much info before hand so it goes as smoothly as possible.
MZH29 is offline
post #12 of 18 Old 01-28-2007, 06:19 PM
nicolas-eric
i used the hole right above the gas pedal.
4" OME & 1" Spacer & LT Shocks 2" BL 1" MML JKS Discos JKS Rear Links OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 ARB Airlockers ARB Diff Covers 4.56 Gears SS Brake Lines
Warn Skids Genright Rock Slider Smittybilt Rock Crawler Rear Bumper Safari Snorkel OBA
12.000 lbs Winch Synthetic Winch Line 4x 130W Hellas 4x 200W Hellas @ Lightbar E-Fan
nicolas-eric is offline
post #13 of 18 Old 01-28-2007, 06:21 PM
Rule303
I just installed my lights using that same hole about an hour ago!
Rule303 is offline
post #14 of 18 Old 01-28-2007, 07:51 PM Thread Starter
MZH29
MZH29's Avatar
2007 WK
How was did it go? Was it a pita?
MZH29 is offline
post #15 of 18 Old 01-28-2007, 08:13 PM
tmwoodall
I did mine a week ago, it is easy, the grommet will just pop out then cut your slits in it run your wires through it and push it back in. There is plenty of room to work with in the engine bay even.
Running wires through firewall miked2905 JK Wrangler Technical Forum 7 03-24-2010 04:17 PM
Help running wires through the firewall KICKER32 JK Wrangler Technical Forum 15 03-16-2009 09:28 PM
Need to get some wires through the firewall... agent_J TJ Wrangler Technical Forum 4 07-05-2007 07:15 AM
Wires thru firewall question Roothog TJ Wrangler Technical Forum 4 02-27-2006 09:57 PM
wires through firewall ??? muskoka TJ Wrangler Technical Forum 10 11-04-2005 03:21 PM
