Running too rich, P0170 or P070? - JeepForum.com
post #1 of 3 Old 06-21-2011, 08:18 PM Thread Starter
mightydog78
I got my codes checked today because the check engine light came on.
ive been having tons of trouble with rough idle and horrible gas smells.
I wrote the code down but can't remember if it was 0170 or 070 or 0107. but underneath the reader it said "System is too rich"
So I have a list of things that I think could be the problem (in order of most likely):
1. Clogged cat. (getting a new exhaust this weekend)
2. Bad O2 sensors (due to clogged cat.?)
3. fuel filter
4. vacuum leak
5. bad spark plugs
6. bad fuel injectors
7. dirty throttle body
8. TPS or MAP sensor
looks like I have my hands full, need opinions!
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #2 of 3 Old 06-21-2011, 08:39 PM Thread Starter
mightydog78
i will be checking to vacuum hoses near the throttle body tomorrow and will update as well. as well as the battery grounds (shouldnt be that sense my lights dont flicker)
need advice on what you guys think
2013 JKU Sahara
Mechanical Engineer
post #3 of 3 Old 06-22-2011, 04:12 PM Thread Starter
mightydog78
dang... anyone?
2013 JKU Sahara
Mechanical Engineer
running very RICH!!! help jptaylor2 TJ Wrangler Technical Forum 6 10-04-2007 10:11 AM
4.0L Running Way to RICH - HELP! Goose346 TJ Wrangler Technical Forum 1 03-10-2007 09:19 AM
YJ running to rich. loborojo338 YJ Wrangler Technical Forum 0 09-03-2006 09:21 AM
Running Rich? tennisjon2002 YJ Wrangler Technical Forum 7 10-25-2005 02:31 PM
Running rich. MAjeep87 YJ Wrangler Technical Forum 9 07-21-2003 08:40 PM
