Running the RE3.5 with no SYE/CV DS, does anyone do this? - JeepForum.com
post #1 of 11 Old 03-28-2009, 12:20 PM Thread Starter
chaznad
I just bought the RE 3.5 superflex with shocks , front/rear adj trackbar, front/ rear lower CA ,f/r sway links and front upper control arms ( no rear uppers), 1.25 BL / 1" MML
I cant afford the sye/cv right now but eventually plan on it. My buddy will install it for me next saturday but i want to make sure i will not have bad vibes, I already have a 1.5" tcase drop on it.
Also i heard that I am required to have rear upper CA's if i have now SYE?CV is this true? the person i bought this kit from didnt
97 TJ 4.0 , 3spd Auto , D30/44 , 3.25 RC lift w/ 1.25" BL / MML , ( 5 )33x12.50x15 Goodyear Duratracs
“Too many people spend money they haven't earned, to buy things they don't want, to impress people they don't like.”
chaznad is offline
post #2 of 11 Old 03-28-2009, 01:29 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
You shouldn't.Why do you have a 1.5" t case drop with a 2" BB?
TheBoogieman is offline
post #3 of 11 Old 03-28-2009, 01:38 PM
RoughRider0923
shoulddnt need the tcase drop but if you plan to go bigger it will help are u doing the sye and cv shaft cause u got vibes back there ? might try takin t case lowerin kit off before moneys spent my buddy has 3 inch lift and tcase made his vibe and was fine w/out so tinker with it before spending lots good luck enjoy
2005 WILLYS EDTION
41MB-05TJ
LIFTED AND ON EDGE
RoughRider0923 is offline
post #4 of 11 Old 03-28-2009, 01:56 PM Thread Starter
chaznad
The previous owner installed it because he said he got vibes at 50mph , it probably didnt need that much of a drop though
chaznad is offline
post #5 of 11 Old 03-28-2009, 01:57 PM Thread Starter
chaznad
Im not doing the SYE/CV kit anytime soon,, my kit is to be installed next week, currently i have no vibes because the tcase was dropped for the 2"BB because there was vibes
chaznad is offline
post #6 of 11 Old 03-28-2009, 01:59 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
every jeep is different.
if you had vibes at 2" and needed drop to fix it, 1.5" more of lift is going to give you vibes again.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 11 Old 03-28-2009, 02:05 PM Thread Starter
chaznad
I know thats why i bought the MML hoping to prevent that, i guess ill just have to see what happens.
So it is not necessary for rear upper control arms for the install?
chaznad is offline
post #8 of 11 Old 03-28-2009, 04:47 PM
steviej35
Junior Member
steviej35's Avatar
I just installed my 3.5 lift today and have a 1" t/c drop in it have a slight vibe at about 30-35 mph. You may want to just keep the transfer case drop in that you have now, But Your defiantly going to need the sye/cv kit for sure. I have to wait a month or two for the combo myself (wife got sticker shock from the price of lift wheels and tires) As far as rear upper control arms I've read they help with the pinion angle with cv driveshafts not sure if they help with the stock driveshaft at all (getting the vibe to go away)
steviej35 is offline
post #9 of 11 Old 03-28-2009, 05:53 PM
andrew383
adjustable rear upper's will help correct the pinion angle tha is why they would be needed
97 tj-Locked up on 33's
andrew383 is offline
post #10 of 11 Old 03-28-2009, 07:12 PM
JESSETHELJ
JESSETHELJ's Avatar
What is the correct pinion angle?
2004 LJ*RIP Love * Ex-Wife Stole you and Sold you *Current 1999 XJ Heep
JESSETHELJ is offline
post #11 of 11 Old 07-07-2009, 03:11 PM
csabo98
Do you correct pinion angle even with a stock drive shaft? I have vibes but will not be able to afford a SYE for a few months. Will installing and adjusting upper control arms help a little even with the stock shaft.
csabo98 is offline
why is my 4.0L running like a 4 cyl? Iamjr TJ Wrangler Technical Forum 2 08-23-2009 02:57 AM
anyone running the bds 4.5 str8stock4l TJ Wrangler Technical Forum 2 08-20-2009 05:52 PM
Running Lights running all the time. Wolf92XJ TJ Wrangler Technical Forum 3 08-25-2008 09:37 AM
Running really really bad! caper YJ Wrangler Technical Forum 2 04-04-2004 03:57 AM
car running bad..NEED HELP!!!!! NBarile22 YJ Wrangler Technical Forum 2 04-03-2004 05:50 AM
