Running lights and dash out - JeepForum.com
post #1 of 12 Old 07-10-2012, 09:29 PM Thread Starter
1998tjsport
As the title says guys, I have an 03 Rubicon and when I turn the lights on the running lights and the dash lights do not light up. I have had the truck for 6 months and its all stock. When I got it the fog light switch was broken and it is all in the same place, do you think its a fuse or is that whole switch fubar? Anyone else ever have this problem? Thanks
WTB INCA GOLD HALF DOORS PM ME
Current-
2003 INCA GOLD TJ Rubicon 5 speed 3inch Currie/Savvy Lift, JKS Discos, 305 KM2s
Build Thread
Past-
1994 Grand Cherokee 5 SPEED 3inch lift, tj bumper, 31x10.5s, wheel spacers, rhino liner, ect.....
1998 TJ Sport 5 Speed 31x10.5s, completely murdered out, and a short throw haha (miss that jeep)
1999 TJ SE 5 Speed (ls swap that became a part-out due to excess frame rot)
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
1998tjsport is offline
post #2 of 12 Old 07-10-2012, 09:32 PM
ShakaBrahTJ
I'd start with the fuse first. And if your tail lights aren't on either, probably a fuse.
ShakaBrahTJ is offline
post #3 of 12 Old 07-10-2012, 09:44 PM Thread Starter
1998tjsport
Tail lights and brake lights work. Including the blinkers....
Current-
Build Thread
Past-
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
post #4 of 12 Old 07-10-2012, 11:02 PM
ShakaBrahTJ
Brake lights and blinkers run through different fuses. But if your dash lights aren't on, but your tail lights are, then doesn't sound like a fuse. Wish I could help your further. I'm sure someone else on here has a good idea.
post #5 of 12 Old 07-11-2012, 08:11 PM
SilverJ
SilverJ's Avatar
fuse 4
SilverJ is offline
post #6 of 12 Old 07-11-2012, 08:13 PM
SlackJaw
baby jeep
SlackJaw's Avatar
Originally Posted by SilverJ
fuse 4
Doubtful.
Can you afford the car? Have I provided you all the information you need on the car? Do you like the car? Then buy the car.
SlackJaw is offline
post #7 of 12 Old 07-11-2012, 08:33 PM
SilverJ
SilverJ's Avatar
Sorry fuse 1 behind the glovebox, I blow it all the time with the same symptoms.
SilverJ is offline
post #8 of 12 Old 07-11-2012, 08:48 PM Thread Starter
1998tjsport
cool, why does it go bad? I run the jeep with no roof or doors most of the time....do you think its water or moisture?
Current-
Build Thread
Past-
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
post #9 of 12 Old 07-11-2012, 09:00 PM
SilverJ
SilverJ's Avatar
Likely a short somewhere, mine usually occurs if I smash a taillight into a tree lol
SilverJ is offline
post #10 of 12 Old 07-12-2012, 08:48 AM
ShakaBrahTJ
LMAO!!!
post #11 of 12 Old 07-12-2012, 09:06 AM
SlackJaw
baby jeep
SlackJaw's Avatar
Originally Posted by ShakaBrahTJ View Post
LMAO!!!
+1
SlackJaw is offline
post #12 of 12 Old 07-12-2012, 10:24 PM
ErnieG
ErnieG's Avatar
i had an issue like this when i replaced my head unit i wired it in wrong and it was screwing with my dash lights so if it has a new stereo i would check to make sure its wired in correctly
98 tj nothing special im too poor :(
ErnieG is offline
dash lights just went out, along with running lights, and tail lights. what happened bortz1892 TJ Wrangler Technical Forum 50 09-04-2016 06:33 AM
Running lights and Dash lights wont work!? Help nield13 YJ Wrangler Technical Forum 4 12-12-2009 03:22 PM
Lost running lights and dash lights YJunior YJ Wrangler Technical Forum 4 06-21-2009 11:15 AM
Dash/Running Lights Problem SaucerBoy YJ Wrangler Technical Forum 6 02-22-2005 02:39 AM
Losing dash lights/running lights ridelkagrl YJ Wrangler Technical Forum 1 04-12-2004 09:45 PM
