Running hot issues... 04 LJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Running hot issues... 04 LJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 08-07-2013, 07:24 AM   #1
02jeepwrangler
My LJ has a little over 100k miles now. Its always run at 210 exactly no matter what I was doing.
A few weeks ago my temp would be erratic, doesn't matter where you were driving, sometimes it will run hot, sometimes a little cooler.. I figured the thermostat may be sticking. I buy a 192 degree, take it apart, and find the housing was corroded and coming apart. So I bought a new one and replaced the temp sensor while I was at it. Put it all back together and burped the system.. All is good. Runs a little below 210... I drive it out to Moab from Houston tx, it did great. It got up to 210 at times sometimes just a hair over, but I figured it was from all the hills.... Few days after I get back my radiator cracks at the top.. I just got a replacement from Orielly's. now it runs below 210 at all times except 60+ mph. Then it goes over 210 a little bit. Anyone have this issue?
02jeepwrangler is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 07:54 AM   #2
JeffBowser
Sounds to me like you described a perfectly running system. Aside from recently when I had a broken radiator, I ran plus or minus 210 (a needles width, perhaps) from day one.
JeffBowser is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 08:15 AM   #3
phrankenstein
I recently had almost the exact issue you did. One thing I found is that the fan clutch was not operating properly. Even though it felt good and tight, it did not have that tell tale roaring noise when operating properly. I used a Hayden HD from O'Reilly and it really helped. I had to replace the radiator, but the fan clutch definitely helped. Maybe it could be your problem. Good luck!
phrankenstein is offline   Reply With Quote Quick reply to this message
Unread 08-07-2013, 09:17 AM   #4
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Jeeps run at 210, that is perfectly normal.
Sent from my phone where grammar isn't easy.
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 06:51 AM   #5
02jeepwrangler
I know mine used to run right at 210. But now it goes past 210 some on the hwy...
Unread 08-08-2013, 11:07 AM   #6
dayriesw
dayriesw's Avatar
Sounds like you have some junk in the system and need to flush it out.
Jeep LJ on 37s
Jeep MJ for sale for a part out price - http://www.jeepforum.com/forum/f153/...800-a-3086769/
dayriesw is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 11:26 AM   #7
rchase559
The temperature gauge on your 2004 is more of a dummy gauge than anything. It is likely giving you inaccurate readings and may be reporting a lower temperature than actual.
There are some individuals who have a reader that can read the actual temp sensor. They report that on later TJs (2003-2006?) their reader displays different values than the gauge on the dash.
Here's one link that discusses it. I'm sure there are more as well.
http://www.jeepforum.com/forum/f9/tj...rking-1245150/
rchase559 is offline   Reply With Quote Quick reply to this message
Unread 08-08-2013, 12:05 PM   #8
JeffBowser
Jeez folks, a TJ running plus/minus 210 is a normal thing.
