Running 33's on only a 2"BB? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Running 33's on only a 2"BB?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineCount Down to KOH Sale!The Original 3/8" Ruffstuff Diff Cover!
Unread 03-20-2009, 11:04 AM   #1
bdupont21
Ok well im looking at upgrading my jeep. I will be purchasing a 2" RE BB. In the thread "What does my TJ look like with a lift" there are photos of a jeep the same year and make as mine running 33's with only a 2" RE BB. Is this actually possible? or is there alot of rubbing/bottoming out along with this? I would rather the 33's if they run well, but can go 31's if it works better. Opinions or comments?
bdupont21 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:06 AM   #2
gisriel06
you gonna have to put a 1" body lift on there as well to run 33's..33's will fit but you wont have much room
gisriel06 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:07 AM   #3
90SaharaJeep
2" BB works best with a 32" tire I think. That was my first lift.
90SaharaJeep is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:11 AM   #4
gisriel06
i wouldnt go more then 31's
Unread 03-20-2009, 11:18 AM   #5
IslandTJ
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
There are also other things to consider when making the jump to a larger tire size, the first one you are already pondering - clearance, the second - torque and power. What gear ratio do you currently have? Will it be sufficient for the tire planned?
1998 TJ Moss [COLOR=darkgreen][B][SIZE=3]Green[/SIZE][/B][/COLOR] Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:23 AM   #6
DBLJ
DBLJ's Avatar
I had 33's with a BB. I then added in a BL.
What I think you should do is get the rear 2" spacers, some V8 Grand Cherokee front springs and some longer shocks instead of the BB. Add in a BL and you will be good. I have this on my TJ and it looks good, was fairly cheap and you won't have a raked look.
Or you can just buy the Rough Country 2.5" kit and toss on some 33's.
Buy my transmission cooler. Derale TJ cooler.
http://www.jeepforum.com/forum/f126/...0561-a-2936825
DBLJ is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:23 AM   #7
CCJ
You sir, didn't search. Click here for other thread that shows pics and discusses this.
But you'll notice my profile states I have 2" BB w/ 33's. For me and the wheelin I do it's fine. It's all about wheel backspacing. And if you plan on running your stock wheels I don't recommend 2" BB w/ 33's. However, my aftermarket wheels work great stagger the tires out past the flare and since I don't do any rock crawling (yet) this combo is fine. I don't rub. See my profile and that link above for pics.
CCJ is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:28 AM   #8
champelite210
It can be done. My buddy has a 97 2.5 liter with a 2" BB. He has 33x12.50x15 on 15x10 rims. It looks like hell. Has no power. But even when we unhook the sway bar it only rubs a little. 31x10.50 on a 15x8 stock off set rim is the best combo for a BB if you ask me.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:49 AM   #9
mdm
Farm Wheeler
2-1/4" spacers + shocks + 1" body lift + trimmed front flares + stock wheels + wheel spacers = 33x12.5 tires with anti-sway bar disconnected and no rubbing.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:50 AM   #10
cadencedad
are wheel spacers safe?
cadencedad is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 11:53 AM   #11
DBLJ
DBLJ's Avatar
If you put them on right yes.
Unread 03-20-2009, 11:57 AM   #12
mdm
Farm Wheeler
It depends on what you do with them. Install and maintain them properly? Yes, they are. Don't install them properly or maintain them? No, they aren't.
Now that the discussion has taken this turn, I'm sure that the naysayers will soon be here to tell you that running spacers will kill the next three generations of your family and cause the nation's banks to fall into ruin.
Unread 03-20-2009, 11:59 AM   #13
cadencedad
i ask because i have gamblers and im not sure i can run 33's with a bb without rubbing im not off roader
Unread 03-20-2009, 12:59 PM   #14
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
Welcome to JF.My neighbor has been doing it for 3 years and has no problems.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 03-20-2009, 01:08 PM   #15
fr0st_m0nkey
I have 33s on 2.5" and it looks fine, I can't imagine a .5" would make THAT much of a difference. Just get a 2.5" BB instead of a 2".
White 2006 TJ X - 6 Speed - 4.0L i6 - 2.5" Rough Country - 33x12.5 Toyo Open Country M/Ts
fr0st_m0nkey is offline   Reply With Quote Quick reply to this message
