Running 33's on only a 2"BB? - JeepForum.com
post #1 of 23 Old 03-20-2009, 10:04 AM Thread Starter
bdupont21
Ok well im looking at upgrading my jeep. I will be purchasing a 2" RE BB. In the thread "What does my TJ look like with a lift" there are photos of a jeep the same year and make as mine running 33's with only a 2" RE BB. Is this actually possible? or is there alot of rubbing/bottoming out along with this? I would rather the 33's if they run well, but can go 31's if it works better. Opinions or comments?
bdupont21 is offline
post #2 of 23 Old 03-20-2009, 10:06 AM
gisriel06
you gonna have to put a 1" body lift on there as well to run 33's..33's will fit but you wont have much room
gisriel06 is offline
post #3 of 23 Old 03-20-2009, 10:07 AM
90SaharaJeep
2" BB works best with a 32" tire I think. That was my first lift.
90SaharaJeep is offline
post #4 of 23 Old 03-20-2009, 10:11 AM
gisriel06
i wouldnt go more then 31's
post #5 of 23 Old 03-20-2009, 10:18 AM
IslandTJ
There are also other things to consider when making the jump to a larger tire size, the first one you are already pondering - clearance, the second - torque and power. What gear ratio do you currently have? Will it be sufficient for the tire planned?
Now Jeeping in Oregon
IslandTJ is offline
post #6 of 23 Old 03-20-2009, 10:23 AM
DBLJ
DBLJ's Avatar
I had 33's with a BB. I then added in a BL.
What I think you should do is get the rear 2" spacers, some V8 Grand Cherokee front springs and some longer shocks instead of the BB. Add in a BL and you will be good. I have this on my TJ and it looks good, was fairly cheap and you won't have a raked look.
Or you can just buy the Rough Country 2.5" kit and toss on some 33's.
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #7 of 23 Old 03-20-2009, 10:23 AM
CCJ
You sir, didn't search. Click here for other thread that shows pics and discusses this.
But you'll notice my profile states I have 2" BB w/ 33's. For me and the wheelin I do it's fine. It's all about wheel backspacing. And if you plan on running your stock wheels I don't recommend 2" BB w/ 33's. However, my aftermarket wheels work great stagger the tires out past the flare and since I don't do any rock crawling (yet) this combo is fine. I don't rub. See my profile and that link above for pics.
CCJ is offline
post #8 of 23 Old 03-20-2009, 10:28 AM
champelite210
It can be done. My buddy has a 97 2.5 liter with a 2" BB. He has 33x12.50x15 on 15x10 rims. It looks like hell. Has no power. But even when we unhook the sway bar it only rubs a little. 31x10.50 on a 15x8 stock off set rim is the best combo for a BB if you ask me.
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #9 of 23 Old 03-20-2009, 10:49 AM
mdm
Farm Wheeler
2-1/4" spacers + shocks + 1" body lift + trimmed front flares + stock wheels + wheel spacers = 33x12.5 tires with anti-sway bar disconnected and no rubbing.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #10 of 23 Old 03-20-2009, 10:50 AM
cadencedad
cadencedad's Avatar
are wheel spacers safe?
cadencedad is offline
post #11 of 23 Old 03-20-2009, 10:53 AM
DBLJ
DBLJ's Avatar
If you put them on right yes.
DBLJ is offline
post #12 of 23 Old 03-20-2009, 10:57 AM
mdm
Farm Wheeler
It depends on what you do with them. Install and maintain them properly? Yes, they are. Don't install them properly or maintain them? No, they aren't.
Now that the discussion has taken this turn, I'm sure that the naysayers will soon be here to tell you that running spacers will kill the next three generations of your family and cause the nation's banks to fall into ruin.
mdm is offline
post #13 of 23 Old 03-20-2009, 10:59 AM
cadencedad
cadencedad's Avatar
i ask because i have gamblers and im not sure i can run 33's with a bb without rubbing im not off roader
post #14 of 23 Old 03-20-2009, 11:59 AM
TheBoogieman
Disturbed Rubicon owner
TheBoogieman's Avatar
Welcome to JF.My neighbor has been doing it for 3 years and has no problems.
TheBoogieman is offline
post #15 of 23 Old 03-20-2009, 12:08 PM
fr0st_m0nkey
I have 33s on 2.5" and it looks fine, I can't imagine a .5" would make THAT much of a difference. Just get a 2.5" BB instead of a 2".
White 2006 TJ X - 6 Speed - 4.0L i6 - 2.5" Rough Country - 33x12.5 Toyo Open Country M/Ts
fr0st_m0nkey is offline
anybody running 2.5-3" lift, 33's with 4.11 gearing? jh1328 TJ Wrangler Technical Forum 6 07-10-2009 10:06 PM
To people who have 2.5" RC Lift + 1.25" BL running 33's BWFBezerk TJ Wrangler Technical Forum 22 02-07-2009 06:09 PM
33's on a 4 cyl, who is running em? alecmcmahon TJ Wrangler Technical Forum 5 08-30-2008 06:22 PM
Anyone running 3" 3T Teraflex lift with 33's?? need pics trevor98tj TJ Wrangler Technical Forum 12 09-27-2006 11:44 AM
? about running a 2"BB 1"BL & 33's Rjwrangler TJ Wrangler Technical Forum 15 02-22-2004 10:13 AM
