Run Empty Diff for Testing - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Run Empty Diff for Testing
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFree Shipping on Soft ShacklesNew! JK/U skid plate system.
Unread 05-22-2015, 03:04 AM   #1
FarFire70
I limped home last night with a clunk of unknown origin coming from my drivetrain. I jacked up the rear end and ran the engine. When I put the trans in anything above first gear, I could clearly hear the clunk and isolated it to the rear axle. I plan to open it tonight to see if there's obvious signs or damage or wear.
If I drain it and don't find something like a broken tooth or cracked gear, is there harm in running the empty differential for short spurts with the tires of the ground to better identify the problem?
I have an Eaton Elocker so if there's something wrong with the pins I may not be able to determine this without running the diff or tearing it apart.
Villanova Wildcat!
2005 Wrangler Sport, 4.0L, 6spd
2" BB, JKS 1.25" BL & MML, M/T MTZ 33x12.50R15
HP D30: Aussie Locker, D44: Eaton Elocker
FarFire70 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 03:12 AM   #2
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I wouldn't think there would be a problem if you spin it up without going beyond a few minutes using first gear... IMO
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 07:12 AM   #3
Jeepsr4me
If it make you feel better, get a squirt can and spray the bearings with it between runs. Or grease...
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 07:14 AM   #4
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
running the diff empty of fluid is common when testing. disconnect the driveshaft, and use a 3/8" t-handle hex key wrench in the yoke, or you can use a 1-1/8" socket on the pinion to turn it with a cordless power drill. There will be oil sticking to bearings and the gears anyway, they won't be totally dry.
I wouldn't idle the engine to do it...although I've heard of it being done that way. I'd just rather not breath exhaust or listen to the useless noise when trying to listen for a specific noise.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 05-22-2015, 08:07 AM   #5
coyote595
Do you have johnny joint control arms? I had a snap ring pop out of a rear upper axle end johnny joint and it made a loud clunk whenever there was a transition between gas on and gas off. I thought there was something wrong in the diff. While under there during my initial inspection, I noticed the johnny joint snap ring out of place and the guts coming out of the joint. Took the arm off and there was powder coating in the snap ring groove. I cleaned out the groove really well, reassembled the joint and it was perfectly quiet again. I was really relieved. Hope you find something simple as I did. Good luck with your fix.
2001 TJ Sahara, White. Dana 44's, Eaton E-Lockers, 5.25" total lift, JKS Control arms and disconnects, Currie steering, M.O.R.E. Steering box brace, Woody CV shafts, Aluminum Fuel Tank Skid Plate, Undercover Fab Aluminum TC Skid Plate, Skid Row Engine Skid, Ultra Nomad Wheels, 35 inch Mickey Thompson MTZ's
2004 LJ - Just getting started...
coyote595 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 05:41 PM   #6
FarFire70
Thanks all for the input. Good advice but didn't end up needing/using it as the problem was evident.
I pulled the tires, brakes, rotors and ran the end (diff still closed) and continued hearing the clunk. Pulled the DS and ran engine, trans in gear, and TC in 2H and no clunk. So I went to pull the diff cover.
After whacking the diff with a dead blow and getting it broken loss, the fluid started to pour (keeping in the top bolt). As the fluid flowed, plop - something solid fell out. My thought: Well, I've lost a tooth at least...
So I finish draining the fluid and remove the last bolt on the cover. As I pull off the cover, I see a fine threat bolt attached...
Looking further, I found all the ring gear bolts were loose and 3 were missing. One was on the cover and the second was crammed between the ring gear and the carrier (see the attachments). So as the carrier spun, the pinion hit the bolt and 'Clunk!'.
The third bolt is still missing so tomorrow the pinion comes out as I believe its wedges behind the pinion in the oil passageway and magnets wouldn't find it.
The carrier has some dents and the pinion gear teeth (beyond where they contact the ring gear) are chipped. But I'm going to run it until it grenades. I have new ring bolts on order to replace all (despite some appearing passable) and I'll be cleaning everything twice with brake clean and using red loctite on the new bolts.
Villanova Wildcat!
Unread 05-23-2015, 06:54 PM   #7
SkeeterTZX
wow! has anybody been inside that differential before?
SkeeterTZX is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 07:53 PM   #8
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
He has an Eaton, So Yes...
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495 Build thread. http://www.jeepforum.com/forum/f9/my...hread-2778642/
BETTY...94 SE, Stroker 4.6, 4.5,lift,35"s,D30 Aussie, 8.8. Sold
NHfireLJ is offline   Reply With Quote Quick reply to this message
Unread 05-23-2015, 10:27 PM   #9
mukluk
Three missing bolts -- one jammed in the carrier, one in the diff cover, and I'm thinking your initial plop when you broke the cover loose was number three.
2000 TJ SE - Rusty's 3" susp w/OME shocks, Stock CAs&TBs, 4.88, F&R Truetracs, 33x10.5 BFG KM2, Bestop tire carrier, MM10500 hydro
2005 LJ Rubicon - RC 4" X-Series w/Bilstein 5100, Stock TBs, 4.10, 33x10.5 BFG AT, Bestop tire carrier, Warn M8000, 1350 series drive shaft, ZJ HD tie rod
mukluk is offline   Reply With Quote Quick reply to this message
Unread 05-24-2015, 03:49 AM   #10
FarFire70
I was hoping but I ran the fluid through cheese cloth with a rare earth magnet in it to see how much metal I was liking at. Only a few very small pieces are there. I'll grab a pic of the metal that came out today.
Number 3 is still MIA so out comes the pinion.
Villanova Wildcat!
Unread 05-24-2015, 03:53 AM   #11
FarFire70
Yea, 4.56 gears and the Eaton went in 5 years and 50k ago.
Not sure how it went all that time and decided now to let go. I just put in a reman engine last month so my only guess is the rear end looked at all the loving the front was getting and decided to get some attention.
Villanova Wildcat!
Unread Yesterday, 02:56 AM   #12
FarFire70
Pulled the pinion and found the last missing bolt at the very back of the oil passage. Here's a shot of the books and metal that come out. Could have been a lot worse.
Ring gear bolts should be here Thursday so I'll button it up then and see how long it last from there.
Villanova Wildcat!
Unread Yesterday, 03:45 PM   #13
RWKHaus
1990 XJ Cherokee
Those dont even look like Ring Gear bolts. Yes they are close, but the head is larger and looks like the threads are longer.
Use Red Locktite.
Brook "He kissed me at KOH, you should ask him about it…"
RWKHaus is offline   Reply With Quote Quick reply to this message
