Quantcast Rugged Ridge Bumper/Tire Carrier - why so cheap? - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rugged Ridge Bumper/Tire Carrier - why so cheap?
Old 12-27-2007, 07:40 AM   #31
ImaginaryFriend
ImaginaryFriend's Avatar
Anyone know the size of the Smittybuilt hinge pin? And is it just surface welded or does the pin run through the bumper and is welded top and bottom?
ImaginaryFriend is offline   Reply With Quote
Old 12-27-2007, 08:37 AM   #32
beryl
it doesn't run through the bumper.
06x-6speed...hard/soft top, BPE's, 2" coils, 1" PA BL, 32 bfg mt's, 15x8 MT alloys, big daddy rocker guards, flowmaster, RE gen II discos, rear bumper and tire carrier, 10" MTX sub with 800watt kenwood amp, mossy oak mats, sony stereo
beryl is offline   Reply With Quote
Old 12-28-2007, 09:06 AM   #33
ImaginaryFriend
Bummer. Don't most other manufacturers through weld them?
Seems like a lot of weight riding on one weld.
Old 12-28-2007, 08:07 PM   #34
apexjeepinjoe
mine did...
btw, mine is textured black. not gloss black
I think all the new Smittybilt stuff is coming textured black. I just got some rocker guards and they are textured black also.
~Joe~
2009 Wrangler Unlimited X(my woman's ride)
2002 Wrangler Apex Edition(with lots of goodies)
1970 Jeepster Commando(a work In progress)
apexjeepinjoe is offline   Reply With Quote
Old 12-29-2007, 06:44 AM   #35
brianarrr
Iron Maiden Fan
brianarrr's Avatar
Chris_ or anyone else whos got the SRC tire carrier,
Do you know if you got part number S/B76621 or S/B76622? All specs are EXACTLY the same at 4wheelparts.com but S/B76622 is $30 cheaper. I'll call them if I can, but its hard to get on the phone around here (Iraq). Don't see why there are two identical items with different prices...
EDIT: my SRC rock rails are textured black as well. And the powdercoat seems to chip away rather easily at the corners, whether you hit anything or not. Still great quality rockers though.
EDIT #2: the 21 is for TJ, the 22 is for JK....of course the cheaper one isn't for me :P
brianarrr is offline   Reply With Quote
Old 12-29-2007, 06:03 PM   #36
kb9qdi
I installed mine today. I love it so far. I have it all adjusted and no rattles of any kind. I went to Auto Zone and wired a $2.99 red light for my 3rd brake mounted with a self tapper and water proofed with silicon
I paid $350.00 shipped from 4WheelParts.com
[SIZE="3"][FONT="Comic Sans MS"][URL="http://www.facebook.com/kb9qdi"]K B 9 Q D I[/URL]
06 TJ D30/8.8 Aussied, 4.88's, 35" KM2's
Hill Top ORV Harrison,Ohio
Terrain Stompers Cincinnati,Ohio
[COLOR="Red"]RED JEEP CLUB MEMBER #443[/COLOR][/FONT][/SIZE]
kb9qdi is offline   Reply With Quote
Old 12-30-2007, 06:28 PM   #37
Rocky5
does that tire carrier rest against the factory rubber stops on the tail gate? I only ask because I trimmed mine to fit my spare on the factory tire carrier and need to get some if that's the case...
oh BTW...Thanks for the great pics, you answered a lot of questions for me.
2006 [COLOR=Yellow]Solar YELLOW[/COLOR] UNLIMITED-6-Speed
-Rusty's 2" spring kit w/Skyjacker Hydro 7000 shocks, 1" coil spacers up front and 3/4" coil spacers in rear, 32" BFG AT KO's on Ravines
-Spidertrax 1.25" wheel spacers, Clear Turn Signals and Markers, Custom Front Bumper Hoop with upgraded hooks, Delta 50 Flowmaster, Code Alarm CA-670 Paging-Alarm with Motion Detector, K&N FIPK, JKS Discos, Procomp LCAs, Airaid TBS, Tuffy 055 rear section sub console, 4-Hella 500's, Fumoto Oil Drain Valve, Olympic Reverse-a-bars, Delta Headlight kit with black bezels, Edge Trail Jammer kit, Smittybilt Classic Tire Carrier, WARN Oil Skid, Skid Row steering skid, JKS adj. rear track bar, RC front adj. track bar.
Rocky5 is offline   Reply With Quote
Old 12-30-2007, 06:59 PM   #38
kb9qdi
They give you an extra one with the bumper hardware so you should be ok.
No trimming at all on mine, it rested on the stock lower stop perfect
I'll get ya another pic's in a few.
Old 12-30-2007, 07:11 PM   #39
kb9qdi
Lower stock stop, no trim at all. It rests on the carrier perfect.
The two higher stops are useless as you can see but I left them there.
Hinge with grease fitting.
Old 12-31-2007, 12:38 AM   #40
spyderbyte
Is anyone dissatisfied with this bumper/carrier? Including any minor inconveniences you might overlook because it was only $300?
I'm really considering ordering this bumper tomorrow, but if I might have any regrets with it I'd much rather pay more for something else.
Also, is the bottom of the receiver flush with the bumper? It looks like it hangs down a little.
Thanks!
Spyderbyte
Go with quality and cry once. Go cheap and cry often.
Originally Posted by Willys2004
Better to live with a little honor and class than die with a few extra greenbacks in your pocket.
spyderbyte is offline   Reply With Quote
Old 12-31-2007, 06:51 AM   #41
el guapo
I received mine and installed over the weekend. No complaints, really. It does come with a small frame tie-in for each side that goes over the frame rail, and requires you to bend the body pinch weld a bit. Since I don't have a BL, and I already have a set of beefy frame tie-ins, I decided not to use the ones that came with the bumper/carrier.
Also, the grease fitting that came on mine was broke, so I had to extract some of the threaded part.
el guapo is offline   Reply With Quote
Old 12-31-2007, 09:00 AM   #42
Rocky5
Thanks!
Spyderbyte
same here...well said!!
Old 12-31-2007, 09:41 AM   #43
Danegerous
USAF Trained Killer
Danegerous's Avatar
the only things to really consider with deals this cheap (one was already said) 1.) the Hinge is most likely only rated at a few hundred pounds, compared to the 2,000lbs that others are made with. that would lower building price by $15 or so. also, the thickness of the steel. with steel prices skyrocketing the way they are, the thicker steel jacks the other bumpers way up. it's all defined by what you wheel or plan to wheel. It seems the rugged ridge would be fine for trail riding. anything more treacherous than that, though and I wouldn't exactly trust it.
also keep in mind there are no shackle mounts or d-rings, whichever you call em. this might not be an issue, but how do you get towed from behind?
lastly, it was also mentioned that there are no frame tie-ins, this is one of the most important factors to a stout bumper, front or rear. (EDIT: i guess it comes with some tie-ins, but they require some fab)
bottom line, rugged ridge has always seemed like the mall crawler version of rock crawling gear. no offense meant by that statement. my thing is, they always make gear that looks like the offroad competitor, but never functions like it. So, if you want the looks, go for it. if you want the function, talk to someone like Bzerk here at the forums, he can hook you up for a tad over that price with killer gear that will last a lifetime.
Dane
Danegerous is offline   Reply With Quote
Old 12-31-2007, 09:45 AM   #44
el guapo
actually, mine came with a set of frame-tie ins that bolt to one of the 2 holes in the frame on each side, and runs over the frame rails and out to the top of the bumper. They're not as beefy looking as some of the other frame tie-ins out there, and they only utilize one of the 2 frame holes available...
Old 12-31-2007, 12:07 PM   #45
spyderbyte
Originally Posted by Danegerous
The Hinge is most likely only rated at a few hundred pounds, compared to the 2,000lbs that others are made with. that would lower building price by $15 or so
That's really what I was worried about, especially since it's said to only be welded in one spot.
The thickness of the steel. with steel prices skyrocketing the way they are, the thicker steel jacks the other bumpers way up.
It sounds like this is actually 1/4" steel, does anyone know if the entire bumper is built this heavily, or if it's just parts?
Keep in mind there are no shackle mounts or d-rings, whichever you call em. this might not be an issue, but how do you get towed from behind?
I have my stock tow hook, will I have to remove that to install this bumper? And I thought receiver mounted shackles were suitable for recovery?
If you want the function, talk to someone like Bzerk here at the forums, he can hook you up for a tad over that price with killer gear that will last a lifetime.
That's what's holding me back. I think I'd rather support a fellow jeeper and get exactly what I want. He says he's backed up at least a few weeks right now, but I'm patient.
Then again, this is very close to what I think I want, and if it is 1/4" steel throughout, it'd be hard to get that much raw material for very much less than $270. I think I like the latching system on it too.
At least I have all day to think about it.
Thanks again!
Spyderbyte
Glock Forum
