rubicons - JeepForum.com
post #1 of 19 Old 10-16-2003, 09:28 PM Thread Starter
Savage4x4
rubicons
please post likes and dislikes key board broke cut\pasteing letters
2003 Inca Gold Rubicon
Cobra CB, 4' antenna, Garmin III Plus GPS, Herculined, new DZP rear bumper
Plan for the worst, Hope for the best.
Savage4x4 is offline
post #2 of 19 Old 10-16-2003, 09:36 PM
steelerman
Rubicons are okay, I just say save the $6000. Lift it, get lockers, and it will look better. Oh yah, I love pulling my buddy(with a rubi) over the tuff stuff with my Sahara.
2001 Sahara, tera long arms,5.5 RE springs, 1' body,Curry sliders,Belly up,SYE ,CV,35x12.50x15 MTR's, ARBs,KC slimlites,WarnXD9000i.GO STEELERS!!!!!
steelerman is offline
post #3 of 19 Old 10-16-2003, 11:05 PM
04Willys
04Willys's Avatar
The main thing I don't like about it are the lockers. They can only be used in 4Lo and under 10mph. My dad's 94 YJ has lock-rite lockers front and rear, they are locked all the time in the rear and all the time in the front during 4wd, they can be used at any speed, and they unlock when going around turns on dry pavement.
-=John=-
2004 Willys TJ, 4.0L I6
1994 3000GT VR-4, twin turbo 3.0L V6
"The no-mind no-thinks no-thoughts about no-things." - The Buddha
04Willys is offline
post #4 of 19 Old 10-16-2003, 11:29 PM
blupupher
blupupher's Avatar
There is an easy fix for that to let you use it anytime. Just a quick re-wire. DC had to do that because too any people who have no clue what a locker is would be locking them all the time on dry pavement and breaking stuff.
And stock, they can be engaged in only 4lo and under 10mph, but stay engaged even if you go faster than 10mph.
But I agree with if you like to tinker and build a Jeep, You could do just as well or better than the Rubi for the same price. But if you want something that is ready out of the box, the rubi is it.
blupupher is offline
post #5 of 19 Old 10-17-2003, 12:22 AM
PrfctAggression
PrfctAggression's Avatar
My guesstimation ss that if you took a Wrangler X, then bought D44s, lockers, gears, a NV241OR t-case, tires, and wheels, you would spend at least as much as the sticker on the Rubi, and you would have no factory warranty on all these parts. I wanted something very capable from the get-go, and the Rubicon delivers. Plus, all I really need to add is a lift, and maybe do a belly-up and I'll have a very nicely equipped trail rig.
PrfctAggression is offline
post #6 of 19 Old 10-17-2003, 07:02 AM
SlinkyTJ
This space for rent.
SlinkyTJ's Avatar
2009 JK Wrangler
Exactly. There's nothing that says a Rubicon can't be built up. I'm just starting from a higher point. The Rubicon had pretty much everything I was going to add anyway, so I just financed it all together and it's under warranty... well, at least most of it is. I may have voided parts of my warranty.
'09 JK
Lockers and stuff
SlinkyTJ is offline
post #7 of 19 Old 10-17-2003, 08:12 AM
DaveFL
DaveFL's Avatar
I hear this all the time...."For the price you paid for the Rubicon I could build up a better Jeep"
I say to each there own, half the time I think folks try to be arrogant about my Rubi just beacuse they don't have one There will always be attitude good or bad but then again I always say Wheeling is 80% Driver and 20% vehicle.
Okay lets go through a few things.
So you buy your base TJ SE or X model with the 4.0 engine I'll leave out AC just to save you money also leave out a hard top.
Your out the door at 18-20K. You have a 30/35 Axle set up and rear Drum brakes.
Okay we will not take into account suspension since either Jeep will most likely recieve a lift.
To put Dana 44's front and rear, If you do the work your looking at a Min of 1500$ if not more. Hopefully your rear dana Replacement will have disc brakes.
Lockers, front and rear selectable to compare to rubi you have the Electra Trac, and Arb both make units for the 44 axles Min for both and again considering you do the work your self $1500
Side Rocker panels $200
Atlas or NV241 Again you do work yourself $1300
Gears $500
That alone you have at least 5K$ invested and I think I was pretty generous with pricing. So now you have a X or SE model nicely built for 23-25K but you've voided the crap out of your factory waranty.
Now You can buy a base Rubi No AC soft top 5sp with the 1500 Cash back, and if your a current Jeep/Chrysler owner get another 1K in incentives for around 24-25k And even lifted your warranty covers your drivetrain to an extent.
So I personally think the Rubi is the way to go. I am sure you can build cheaper, and its easier to build over time so in cases you get a lower model cheaper with that in mind thats fine as well.
But if you can afford it, get the rubi.
Oh and BTW yes you can buy a slightly used Jeep for cheaper, but you can also buy a used Rubicon, I paid 21K for mine with 4k miles on it So tell me how your gonna build a comparable 03 Jeep to mine for 21K unless your Jesse James and the companies are giving you "FREEBIES"
Dave
______________________________
03 Rubicon
Nth 6"LA lift, TT, Stinger/Slider Combo, Superwinch EPI9000, Durango Front & Rear, ORF Tire Carrier, Independent Locker Mod, 15x8 Crager Locks, 35" MT MTZ,Rock Hard Parts trail Cage, AEM Dry Flow, Viking Fastback Top.
DaveFL is offline
post #8 of 19 Old 10-17-2003, 08:14 AM Thread Starter
Savage4x4
ThanX
\The Rubicon had pretty much everything I was going to add anyway\ easy fix for that to let you use it anytime---define \anytime\.......But if you want something that is ready out of the box, the rubi is it.
eXactly everything I want stok And factory warranty gas mil 5spd
only gripe is lockers then
sorry key board broke cut\pasteing letters -not a moron need 25000 dollars
post #9 of 19 Old 10-17-2003, 09:58 AM
n2audio
if you can swing it then go for the rubi.
i was shopping for one when i found my sport.
saved about 14 grand so for me it was a no brainer (sport was used)
Red Jeep Club #60
99 TJ
n2audio is offline
post #10 of 19 Old 10-17-2003, 11:20 AM
KaiserJeep
The $6000 is baloney. The Rubicon package costs $3800 list price above an identically-optioned TJ Sport. Of course, many people do not pay list price, so the actual price premium is less than that. Try to add lockers, HD transfer case, HD front axle, rocker guards, and MT/Rs on alloy wheels to a Sport for $3800 or less - the Rubicon is a bargain, and comes with a warranty.
If you must have the ultimate Jeep, buy a used SE model and give it all new powertrain and suspension and tires. If you want a moderately built Jeep with a factory warranty, wheel a Rubicon in stock or near-stock form.
Gary
1967 Kaiser Commando
2001 Grand Cherokee WJ
2003 Wrangler Rubicon TJ
KaiserJeep is offline
post #11 of 19 Old 10-17-2003, 03:00 PM
Rogue
Not to mention the cool 16" wheels are standard, and if you were to replace wheels and tires on each, you would get more coin for the Rubi wheels, so it is NOT a wash!
04 RUBICON - Some call it stock, I call it "PRE-UPGRADED"
Banks Stinger System - Cat Back
AC,Full Doors,7 Spkr w/ Sub,Deep Tint
Sienna Pearlcoat/Khaki Roof and Guts
Rogue is offline
post #12 of 19 Old 10-17-2003, 03:21 PM
Lipstud
Lipstud's Avatar
noob question incoming....
is Rubicon just a separate company that adds on their own gadgets and modifies jeeps like how Saleen is to a mustang?
'03 Lauracon #0250
Automatic, 16x8 Alcoa wheels, 31" Goodyear MT's, Air Lockers, Light Bar, Riveted Fender Flares
BigWaylon Fan Club Member #4
Lipstud is offline
post #13 of 19 Old 10-17-2003, 04:01 PM
ncragains
ncragains's Avatar
Rubi rewire
Any info on that rewire? Love to see it. Are there conversion kits to access the air pump for re-airing the tires and other uses?
ncragains is offline
post #14 of 19 Old 10-17-2003, 04:14 PM
04Willys
04Willys's Avatar
Nope, Rubicon is just the name of an edition, like Sahara or sport.
-=John=-
04Willys is offline
post #15 of 19 Old 10-17-2003, 09:58 PM
blupupher
blupupher's Avatar
Here it is:
http://rockcrawler.com/techreports/j...pass/index.asp
Just remember this would probably void alot of warrenty stuff though.
I don't think the compressor would have enough pressure to air tires. The locker on the Rubi activates with like 9 psi of pressure.
Differences between 07-10 rubicons? jgorm JK Wrangler Technical Forum 26 08-23-2011 07:43 PM
Don't Rubicons come with... 2_Salukis TJ Wrangler Technical Forum 7 01-19-2009 04:18 PM
Rubicons mfm22 TJ Wrangler Technical Forum 3 11-23-2006 06:42 AM
Are All Rubicons 4.0 ?????? jmiller TJ Wrangler Technical Forum 10 07-07-2005 04:12 PM
Rubicons in 04? mopar01 TJ Wrangler Technical Forum 7 01-29-2003 11:43 PM
