Rubicon Unlimited shocks, springs in TJ SE? - JeepForum.com
post #1 of 9 Old 07-27-2006, 03:47 PM Thread Starter
Myers97TJ
I came accross an opportunity to purchase some shocks and springs out of a rubicon unlimited, and I was wondering how much lift it would give my stock 97 SE. Im looking for a one to two inch lift, which I think it should provide, but i was wondering if anybody else had done this. Im only planning on running 31 inch tires too, if that helps.
Thanks
Mike
Myers97TJ is offline
post #2 of 9 Old 07-27-2006, 04:01 PM
Rocky529
Rocky529's Avatar
If anything, .5" gain... don't expect much as they are the same size as other springs, just stiffer. The lighter engine will help though.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 9 Old 07-27-2006, 04:08 PM
redhat6161
From what i understand, you'll only experience "Lift" if you've got a 4 cylinder and the new springs that you put on were used with a 6 cylinder. This is due to the different stiffness of the springs. With this said, your original springs are probably sagging a bit because of their age. Either way, whether you've got a 4 or 6 cylinder, I think you can expect about 1-1/2 inches if you put the Rubicon springs on (assuming they're relatively new), which is what you're looking for. You should be able to run the 31's with no problem at all. If for some reason this doesn't work out you can always put on a Budget Boost (BB) for around $200 and be done with it. This will give you about 2" of lift.
redhat6161 is offline
post #4 of 9 Old 07-27-2006, 05:20 PM
awarsoca
HAH I was 5 minutes away from posting this same question as to my 4.0.
Will the stiffer springs and shocks make the ride more or less comforatble? I never can remember )c:
Clint
2002 TJ X
Rubicon fender flares, 16x8 MOAB wheels, 245/75/16 Goodyear MTR, Rubicon Coils, BDS shocks
2000 WJ Stock Laredo
awarsoca is offline
post #5 of 9 Old 07-27-2006, 06:02 PM
jeepin_man
ride quality is really a matter of opinion, I have a Rubi and it rides a bit stiffer, but that is what I like. some folks like to float a bit on a softer ride.
jeepin_man is offline
post #6 of 9 Old 07-27-2006, 06:13 PM
Rocky529
Rocky529's Avatar
90% of that ride is based on your tires' PSI. What are you currently running?
Rocky529 is offline
post #7 of 9 Old 07-27-2006, 07:17 PM Thread Starter
Myers97TJ
Yeah im thinking about running rubi springs with an re budget boost, so probably about 2.5 inches of lift, thanks everybody
post #8 of 9 Old 07-27-2006, 07:28 PM
ytodd
ytodd's Avatar
I would attribute the stiffer ride more to the E rated stock tires on a Rubi. Those bastids are stiff.
ytodd is offline
post #9 of 9 Old 07-28-2006, 02:17 AM
exc911ence
exc911ence's Avatar
I had a 2001 SE that I swapped Rubi springs/shocks (swb hardtop) onto and let me tell you, it rode STIFF. The back end wouldn't give at all and hammered over every bump. It was horrible... so I bought a Rubi to replace it! Haven't swapped in an SE suspension yet though.
Oh yeah, got an easy 1-1 1/4" lift from the set-up. With that and a BB, I fit 32's on it.
exc911ence is offline
Are JK Rubicon and JK Unlimited shocks the same??? xjfan JK Wrangler Technical Forum 8 02-27-2011 11:10 AM
Unlimited Rubicon Springs on 2dr Sahara dvdsjk JK Wrangler Technical Forum 9 06-23-2009 08:14 AM
Rubicon unlimited springs VS Rubicon 2 door springs sheriff1 JK Wrangler Technical Forum 1 11-27-2008 03:58 PM
Unlimited springs and shocks on a SE jeeptj19992001 TJ Wrangler Technical Forum 4 02-03-2006 09:39 AM
Rubicon and Rubicon Unlimited Springs ClemsonJeepGC TJ Wrangler Technical Forum 7 01-11-2006 09:30 AM
