Quantcast Rubicon Transfer case into non rubicon - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Rubicon Transfer case into non rubicon
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 02-09-2009, 03:23 PM   #1
hughes16
I might be able to get a good deal on a rubicon transfer case. And I have a few questions before I buy it: how hard is it to change t cases? If I do this it will eliminate my need for an sye so I would need a cv drive shaft, correct? I have a d35 if that matters. Thanks in advance
'01 Sport I6
4" procomp SA, 33 x 12.5 BFG A/T's, OME shocks
d30/35 4.56 gear
Warn m8000
hughes16 is offline   Reply With Quote
Old 02-09-2009, 03:39 PM   #2
NikVallens
Swapping a 241 t case is not difficult. You will need to buy a 03+ transmission mount or modify your current one. I was able to modify mine in about 30 minutes with a grinder.
A rubicon t case comes with a sye from the factory.
The lower range is going to make your already vulnerable D35 even more prone to breakage. That aside, my 241 swap has been one of my favorite mods.
00 TJ with a few mods. Hopefully more someday...
NikVallens is offline   Reply With Quote
Old 02-09-2009, 03:47 PM   #3
Savvy
Savvy Off Road
Savvy's Avatar
It is best if you replace the rear output flange with a yoke so you can get a longer drive shaft with a CV.
Email me for the fastest response: gman@savvyoffroad.com
Follow us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
PM MrBlaine for Black Magic Brakes!
http://www.savvyoffroad.com
2006 LJ Unlimited Black Hole
2005 LJ Test Mule
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote
Old 02-15-2009, 12:47 PM   #4
tppilot
I want to perform the same swap on my '05 X-model. I found a Rubi xfer case mounted to an automatic transmission, but I have the 6-speed manual. Any issues there? Is the x-fer case the same regardless of the tranny it's mounted to?
tppilot is offline   Reply With Quote
Old 02-15-2009, 07:33 PM   #5
Gymguyjeep
Easy swap. Get a rear CV driveshaft from Tom Woods. He has an exact fit for your application.
2004 TJ Wrangler Rubicon - 5.25" Total Lift, Antirock, Various Skids, Winch, 35" MT tires, Roof Rack. Matching Off-Road Teardrop Trailer.
1993 XJ Cherokee - 3" Lift, 31" tires
Previous Jeeps - 1981 CJ-5, 1985 CJ-7
Gymguyjeep is offline   Reply With Quote
Old 03-01-2009, 12:23 AM   #6
Mario53
i am looking for a rubicon transfer case (NVG241OR).
Mario53 is offline   Reply With Quote
Old 02-27-2010, 12:07 PM   #7
472cid
the 03 newer mount did not line up with the holes in my skid plate. it is about inch farther foward as in the mount to the is one inch closer to the trans mission mount than my 97 mount
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline   Reply With Quote
Glock Forum
