Rubicon TJ vs. Sahara TJ -- Rubicon owners chime in! - JeepForum.com
post #1 of 45 Old 12-10-2009, 07:29 PM Thread Starter
retromag123
Ok so planning for the future....
I currently have a 99 Sahara 5spd with a 4" suspension lift running 33x12.50s, and stock gears and axles. I bought the jeep this way and I know running the 33s makes my rear end a potential ticking time bomb... What my question is, and trying to get advice is should I invest the money into beefing up my 99 with 108k to dana 44s and whatnot or buy a newer model rubicon with the gears and axles already there...
Opinions please! Thanks in advance
retromag123 is offline
post #2 of 45 Old 12-10-2009, 07:31 PM
mcg311TJ
Buy the rubi, turn your Sahara into a trail rig The only thing better then 1 Jeep is 2
mcg311TJ is offline
post #3 of 45 Old 12-10-2009, 07:33 PM
rob78
There's a low mileage (40k and change) 04 Rubicon around here priced at $13.8.
I'd get a rubi, but I'm a little biased...
rob78 is offline
post #4 of 45 Old 12-10-2009, 07:33 PM
Sobie
Bolt-on Maniac
Sobie's Avatar
Might want to check your rear axel. Saharas has a dana 44 option. But the 35 is fine on 33s.
USAF
Sobie is offline
post #5 of 45 Old 12-10-2009, 07:35 PM
BadJeep2006
It really depends on how far you are going. If you want a rig that is offroad ready and can handle 35's, go Rubicon. If you plan on going bigger than that, invest the cash into axles on your old TJ. The Rubicon is a great out of the box Jeep. The front and rear lockers are hard to beat and you get the D44's. The Rubicion is not the be all rig though. It has limitations and becomes just another Jeep if you expect to exceed them in the future. So if you are going mild to moderate, go Rubicon. If you see extreme in your future, build your current Jeep.
Joe
BadJeep Build: D60 front W/ARB and 5.38 gears, Sterling 10.5 rear W/ARB and 5.38, 3 Link front, 4 link rear, 14" ORI Struts, Atlas II transfer case, A to Z Fab full cage, Genright fenders, A to Z Fab front bumper, and Warn M8000 winch. Thinking stroker in the future.
BadJeep2006 is offline
post #6 of 45 Old 12-10-2009, 07:37 PM
kuebelwagen
Buy the Rubi, D44's and lockers!
In love with, Suki.
Pain is weakness leaving the body.
2004 Rubicon
1995 Cherokee
kuebelwagen is offline
post #7 of 45 Old 12-10-2009, 07:41 PM
dcope17
Joe
Very well said.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #8 of 45 Old 12-10-2009, 07:42 PM
mcg311TJ
That would make no sense what so ever if his current Jeep has a 44 in the rear... D44 Front vs. d30 front, is a zero point. If it has a 44 in the rear, get a Aussie up front and a selectable in the rear. besides a TC he'll have him self a rubi.
mcg311TJ is offline
post #9 of 45 Old 12-10-2009, 07:43 PM
JeepnBlake
How big of tires are you planning on running?
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #10 of 45 Old 12-10-2009, 07:44 PM
JeepnBlake
Lower gears in the axles and limited slip/locked rear moot point yes
And the fact the rubi would be atleast 4 years newer.
-Blake-
Build Thread:
Dad's Build Thread:
post #11 of 45 Old 12-10-2009, 07:45 PM
DBLJ
DBLJ's Avatar
Buy it. Better yet get an LJ Rubi. Its what I did.
What part of the SS are you from?
Buy my transmission cooler. Derale TJ cooler.
DBLJ is offline
post #12 of 45 Old 12-10-2009, 07:46 PM
msiefer
Eat, Sleep, Jeep...
msiefer's Avatar
I faced the same delima with my 2000 TJ. Ended up picking up a 2005 Rubicon w/37k for $15k, best move I could have made. Look for a Rubi...
msiefer is offline
post #13 of 45 Old 12-10-2009, 07:47 PM Thread Starter
retromag123
I do want to beef it up quite a bit, at least run 35's... but the benefits of the rubicon are really just the lockers, 44s, gearing... anything else???
I appreciate the fast responses guys
post #14 of 45 Old 12-10-2009, 07:48 PM
blkbetty02
Depends on what you want to do with it. A D35 can handle 33's. Especially if you gear up. But if you want to go any bigger you would need the D44. You can build you Sahara up to have everything the Rubi has, it's just up to you whether you want to do the wrench time or if you want to spend the money on the Rubi and get the lower miles. I wouldn't do it just for the rear axel though. Just my
In Florida? EPJCFL.com
blkbetty02 is offline
post #15 of 45 Old 12-10-2009, 07:48 PM
MisterO
the OP claims to have the 35, so buying Rubi axles Will actually make a difference as far as his main concern (running 33's)
yes you are correct about the fact that a rubi44 front has the same inners but as of now he has no locker or 4.11's up front..
MisterO is offline
??? For '07-'09 Sahara & Rubicon Owners! Blackbeard JK Wrangler Technical Forum 5 07-24-2009 06:28 PM
difference between 05' rubicon and 05' rubicon sahara nyrblseats TJ Wrangler Technical Forum 4 11-15-2007 09:40 AM
for rubicon owners rubiconobi TJ Wrangler Technical Forum 19 10-13-2006 10:16 AM
FYI Rubicon Owners RussT TJ Wrangler Technical Forum 0 10-28-2003 08:53 AM
For Rubicon Owners Instaurare TJ Wrangler Technical Forum 0 06-13-2003 04:59 PM
