Rubicon Stock Lockers??? - JeepForum.com
post #1 of 4 Old 06-02-2008, 10:07 AM Thread Starter
XJ Rocker
XJ Rocker's Avatar
1992 XJ Cherokee
I got my rubi its 100% stock and i want to know where the air compressor intake is for my lockers. Some one told me that the compressor was down by the x-fer case skid and that if you go through water deep enough you can pump water into your diffs via you LPA compressor. First is this true second if so what the heck was jeep thinking, and third does any one know if there is a way to cange where the compressor is mounted or make a "snorkel" of sorts to pull the air from the engine compartment.
Thanks again
Jay B. Owner of JFAB industries
Spent so far: 12,500 bought for $900
1992 XJ Laredo
Installed:
Rubicon Express 5.5" Long arm lift | Diamond plate trunk and lift gate | Herculined Floors | Wilderness Rack | JFAB hi-lift mount | JFAB tire Carrier | Uniden Bear Cat CB w/ firestick | 33x12.50 R15 | AWC 15x8 Steelies | Rugged Ridge 1.25 wheel spacers. |JCROffroad front pre-runner bumper |JCRoffroad Rear stage 2 bumper.
2006 TJ Rubicon
Stock (for now)
Check Out United Aggression Offroad Associates At
XJ Rocker is offline
post #2 of 4 Old 06-02-2008, 10:14 AM
Crashnburn80
Crashnburn80's Avatar
No, that is not true.
The locker pumps are located down behind the Tcase (there is a pic in the 'Nth TT' link in my sig), the pumps have an intake air hose that goes to a much higher location to intake air (like a snorkle). The can intake air no problem being completely submerged.
| 1.25" BL |
| Riddler diff covers |
| 33" MTRs | Warn M8000 |
and much more...
Crashnburn80 is offline
post #3 of 4 Old 06-02-2008, 10:20 AM
Bigbob
Bigbob's Avatar
Some folks who run the Rubi in a lot of water re-locate the pumps to the ABS tray under the hood. I have no issues with mine as I stay pretty dry. I don't think people have problems with the pumps sucking water as those pumps usually are not running, once they get up to 5psi they shut off. But water in the wiring can be an issue sometimes.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #4 of 4 Old 06-02-2008, 10:32 AM Thread Starter
XJ Rocker
XJ Rocker's Avatar
1992 XJ Cherokee
then where does the intake hose end at?
1992 XJ Laredo
Installed:
2006 TJ Rubicon
Stock (for now)
Rubicon Air Lockers vs ARB Lockers MLA 97TJ TJ Wrangler Technical Forum 17 07-09-2012 04:37 PM
Rubicon AIR LOCKERS, badassjeep04 TJ Wrangler Technical Forum 22 12-05-2008 03:59 PM
rubicon air lockers 03rubiconMG TJ Wrangler Technical Forum 15 09-16-2006 11:42 AM
Rubicon Lockers ua_who TJ Wrangler Technical Forum 6 08-12-2006 11:39 PM
Rubicon Lockers RedRubiconLJ TJ Wrangler Technical Forum 34 08-08-2005 09:40 PM
