rubicon speedometer gear - JeepForum.com
post #1 of 4 Old 07-12-2010, 09:17 AM Thread Starter
jeepy01
so when i went to 35's and 4.88 my speedo became off. at first it i didn't have a problem with it but its now beginning to annoy me. i know that rubicons dont use a actual gear. so im wondering what you guys have been using to get your speedo's set back. thanks alot
my build thread:
jeepy01 is offline
post #2 of 4 Old 07-12-2010, 09:37 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You just need to install an external electronic speedometer calibrator like a Truespeed. That is what is on my Rubicon and it works fine. The Truespeed isn't cheap but there is another out there that is much less expensive, someone else will have to come up with that brand name for you.
Edit: I just found the less expensive speedometer calibrator in my bookmarks, it's from Dakota Digital ... http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=126/category_id=287/home_id=59/mode=prod/prd126.htm
Gone on vacation until August 25.
Jerry Bransford is offline
post #3 of 4 Old 07-12-2010, 09:53 AM Thread Starter
jeepy01
thanks jerry thats what i was looking for. whats the install on these things like?
my build thread:
jeepy01 is offline
post #4 of 4 Old 07-12-2010, 10:01 AM
Jerry Bransford
Administrator
I didn't do the original installation but I just rewired it this weekend to better protect the wiring. Looks like you just snip a wire coming out of the VSS on the t-case & splice the calibrator's wiring into the wire just snipped.
speedo , speedometer , rubicon , tj , wrangler , gear , 4.88 , 35
Speedometer Gear cubewhiz YJ Wrangler Technical Forum 2 11-08-2009 07:58 PM
speedometer gear tiayiti YJ Wrangler Technical Forum 3 05-06-2006 04:56 PM
Speedometer Gear JoeGreene58 YJ Wrangler Technical Forum 2 05-06-2006 01:59 PM
Is a speedometer gear available?!?! Neener Neener YJ Wrangler Technical Forum 5 12-30-2005 05:26 PM
Stock Gear Ratio - Speedometer Gear Moxley YJ Wrangler Technical Forum 2 06-06-2003 09:52 AM
