Rubicon Speaker Pods - JeepForum.com
post #1 of 10 Old 01-25-2005, 11:50 AM Thread Starter
joedirt88
Has anyone taken out their speaker bar and replaced it with the Rubicon Speaker Pods? Do they attach easily? Any extra fabricating to add these?
joedirt88 is offline
post #2 of 10 Old 01-25-2005, 11:57 AM
jeep32mudtaman
Quadratec has a set that is supposed to just drop right in. You may have to do a bit of wireing. Shouldn't be to tough.
2001 TJ
1.75" superlift lift
Airaid
Stainless hindges
30" Wrangler GSA tires
jeep32mudtaman is offline
post #3 of 10 Old 01-25-2005, 02:42 PM
DarKGifT06
the wireing in my sound bar is -=-=-=-=-=-=-=-=ty and cuts out all the time how hard is it to re-wire the bar??
Mud Every day.
Drive it like u stole it
1998 Jeep TJ 5spd. 2" BL 31" Yok MT's and lots of Trail time.
DarKGifT06 is offline
post #4 of 10 Old 01-25-2005, 02:47 PM
DazedRangerFred
i am guessing that by the "rubicon speaker pods" you are meaning all 03+ speaker pods?
2004 Rubicon
Electric Lime Green
RE 5.5 LA and 35's, TxT front Bumper, Jeeperman Rear Bumper/ Tire Carrier
DazedRangerFred is offline
post #5 of 10 Old 01-25-2005, 03:21 PM Thread Starter
joedirt88
Yup...just was wondering how hard it would be to put those in...and if anyones has done it.
post #6 of 10 Old 01-25-2005, 03:54 PM
erickpl
erickpl's Avatar
My TJ didn't have a soundbar at all. I went aftermarket with edgeauto.com's 6x9 soundbar. Holds 6x9's with NO problems or mods required.
erickpl is offline
post #7 of 10 Old 01-25-2005, 04:55 PM
TXST8tj
TXST8tj's Avatar
i'm sure they would be a similar install compared to the soundbar. probably screw into the rollbar, like the soundbar does, and has wires that run to it. if i didn't have a soundbar already, i'd get those pods.
Patrick
TXST8tj is offline
post #8 of 10 Old 01-25-2005, 07:04 PM
DazedRangerFred
the wiring should not be a problem, but bolting them in could cause some problems since i think the sound bar just goes across the back bars or the roll cage with out connecting to the center cage bar at all, now the pods connect to the center bar. The holes my not be exsist on the older jeeps. good luck.
2004 Rubicon
Electric Lime Green
post #9 of 10 Old 01-26-2005, 07:02 AM
TXST8tj
TXST8tj's Avatar
the soundbar on 'older' jeeps is screwed into the rollbar.
Patrick
TXST8tj is offline
post #10 of 10 Old 01-26-2005, 07:10 AM
blacksheep1
there is two bolts per side plus a stud that comes off the center roll bar per pod. im not sure they will mount securely if you dont have the stud or a means to make one. there are however a lot of after market pods/bars available. vertically driven products makes pods and bars, and outland, bestop, omix, make bars. prob a few others if you search.
http://www.4wd.com/shop/productlist....n=6&category=9
another thing: the 03 & up pods may be "clearanced" for the roll bar pad and cover - may show a gap if you have no pad or cover. hth
3 Jeep family again.
MINE 1999 TJ sport, HERS 2004 KJ Renegade and 2005 Rubicon
Wind Tunnel Tested . . . FAILED
blacksheep1 is offline
Homebrew speaker pods bradyman1 Wrangler General Discussion 11 06-08-2009 07:35 AM
Halftops that Fit Speaker Pods missionAvs TJ Wrangler Technical Forum 11 04-15-2009 03:53 PM
Speaker bar vs pods and/or opinions OH-ZJ-IO Wrangler General Discussion 8 02-26-2009 02:43 PM
speaker pods damian H YJ Wrangler Technical Forum 9 12-27-2007 07:36 PM
Factory Speaker Pods Wheels4186 TJ Wrangler Technical Forum 2 06-27-2006 09:18 PM
