rubicon rear locker help - JeepForum.com
post #1 of 17 Old 04-06-2013, 07:09 PM Thread Starter
jeeprubi2005
ok here's the facts
front locker engages light doesn't flash
rear locker engages light flashes wont stop flashing
both pumps working all air lines look good and electrical connections tight and corrosion free
any ideas what would cause the locker to work but the light to flash???
jeeprubi2005 is offline
post #2 of 17 Old 04-06-2013, 07:16 PM
Necko2529
Necko2529's Avatar
It locks/unlocks without much effort?
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #3 of 17 Old 04-06-2013, 07:19 PM
pete1986
I have the same issue with my 04, its gotta be a sensor error somewhere in the system. As long as im locked I don't care if the lights blinking or not, but it would be nice to have a CLEAR indication whether the air locker has locked, or if it is in the process of locking.
pete1986 is offline
post #4 of 17 Old 04-06-2013, 07:20 PM Thread Starter
jeeprubi2005
Yes locks and unlocks fine had it up on jack stands to check and in the yard it skids the tires while turning
post #5 of 17 Old 04-06-2013, 09:46 PM
MJBinNM
Does the pump continue to run while it's flashing? If it does, you probably have a small leak somewhere. Mine had the little spring clamp fail inside the diff. I replaced it with a small zip-tie 4 years ago and haven't had any problems since.
You must have grown up in the no winners no losers generation where everyone gets a participation trophy and a pat on the butt for just showing up with their clothes on right side out.
MJBinNM is offline
post #6 of 17 Old 04-07-2013, 04:45 AM
brianmlove
Same with me on the spring clip.i put a ziptie on both sides of the hose inside the diff
brianmlove is offline
post #7 of 17 Old 04-07-2013, 06:45 AM
Piratejonh
Piratejonh's Avatar
Did you remove the gears by any chance. They can be installed with the end of the sensor on the wrong side of the plate and cause the light to flash a malfunction.
Jeep took another piece of my finger today...
Piratejonh is offline
post #8 of 17 Old 04-07-2013, 10:38 AM Thread Starter
jeeprubi2005
No its completely stock
post #9 of 17 Old 04-07-2013, 04:48 PM Thread Starter
jeeprubi2005
Bump
post #10 of 17 Old 04-07-2013, 04:54 PM
brianmlove
Airline inside the diff. Also try to plug off the air hope by the diff to see if the compressor cuts
Off
post #11 of 17 Old 04-07-2013, 05:07 PM Thread Starter
jeeprubi2005
The compressor doesn't run all the time
post #12 of 17 Old 04-08-2013, 09:55 AM Thread Starter
jeeprubi2005
Bump anyone
post #13 of 17 Old 04-08-2013, 10:59 AM
Timido
There is a plunger sensor that tells the jeep when the locker is locked. My guess is the sensor is bad or the wiring is damaged. If you try to replace that switch you have to remove the differential. There is alot more to it than replacing the switch
Timido is offline
post #14 of 17 Old 04-08-2013, 11:47 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
I think you can test that switch by crossing the 2 wires & see if the light stops flashing. If not, it is probably a broken wire or bad connection between the switch & the cluster or ground. Make sure the black wire has a good ground.
Rubi4MyMrs is offline
post #15 of 17 Old 04-08-2013, 12:00 PM
ops5
ops5's Avatar
Have you changed the diff fluid recently? If you tighten the fill plug too far in, it can stop the locker ring from moving and cause the flashing lights
Edit- after re-reading your post, you say the rear are in fact working/engaging. How do you know that?
ops5 is offline
